Voltage Meter
I have a BS2e with SEE LCD screen. I am trying to figure out a way so I can
show how much of the battery is left on the screen, and then add a low
battery alarm. Thanks.
Jason Coutermarsh
jasoncout@b...
Jason Coutermarsh
jasoncout@b...
>Jason Coutermarsh
>jasoncout@b...
Hi Jason,
You can do this using the RCtime command.
680k 1%
~9V battery --/\/\---o
P0 on stamp
=== 0.01uf mylar
Vss (common)
bv var word
loop:
low 0
RCtime 0,0,bv
serout lcdpin,lcdbaud,[noparse][[/noparse]home,dec5 bv]
goto loop
will return bv~=1000 when the voltage drops too low to operate the
stamp, and bv~=600 for a fresh battery.
More information about it and how to calibrate bv to read in volts at:
http://www.emesystems.com/BS2rct.htm
-- Tracy Allen
