blood pressure — Parallax Forums
blood pressure
edited 2001-01-15 19:11 in General Discussion
I am rebuilding a blood pressure exhibit at our sciece museum but
would like to know where and if I can get the a sensor. Interfacing
the BS2 to one of the commercial units is rather a mystery.
Any idea where I can find cuffs, pressure sensors, and also if there
is any way of getting other medical sensors such as heart rate, pulse
oximeter etc.
Al
    edited 2001-01-13 18:20
    Hi Al,
    I've seen something years ago, it worked with a light and a LDR. The light
    was on one side of a finger, and the LDR on the other side.
    I think that the blood pulses generate a light variation you may use.
    Maybe I could find this out of my (very) old books... Let me know if you're
    interested.
    Best regards,
    Phil.
    To: <basicstamps@egroups.com>
    Sent: Saturday, January 13, 2001 5:13 AM
    Subject: [noparse][[/noparse]basicstamps] blood pressure
    > oximeter etc.
    > Al
    edited 2001-01-14 19:42
    Hi Al, Suggest using red led to shine through finger to photo transistor or
    light dependent resistor. Suggest you amplify signal with op amp and filter
    out noise and artifacts from finger movements. Pulse oximeters are available
    on the medical marketplace and you may be able to located a used model and
    interface it to your existing system. Obtaining an ECG signal may be a bit
    more difficult (but not impossible) and we designed a specialized chair at
    the University of Missouri that was intended for mass screening that took
    ECG's while the patient sat it in. A physical/ohmic connection is required
    and ECG's are usually obtained in low electrical noise and somewhat
    controlled environments. Do you have any experience in the use of Parallax
    products? I don't and would like to talk with someone about them Where are
    you located? Please Advise. Thanks, Burt
    edited 2001-01-15 01:24
    Yes Please!
    I know that oximeter work somewhat like that. This instrument measure
    oxygen content in the blood, and an LED light transmission is measured
    and calibrated.
    Many thanks
    --- In basicstamps@egroups.com, "Philippe Derenne" <derennep@s...>
    wrote:
    > Hi Al,
    light
    use.
    you're
    > interested.
    > Best regards,
    > Phil.
    > From: <alnajjar@s...>
    Interfacing
    there
    pulse
    > > oximeter etc.
    > > Al
    edited 2001-01-15 01:37
    I am in Shreveport Louisianna, MS Physics and have long experience
    with interfacing, limited experience with Micro-controllers and BS2.
    I do know all the necessary stuff in electronics to "fuge" it.
    I am the VP of exhibits at a Science Center here and get to play with
    hundreds of cool stuff and have the money to make new ones. This is
    not unlike the St. Louis Science center. Incidently, I am building
    few exhibits for them for fun!
    I am not sure how I can help, but send me an e-mail on my personal
    address.
    I would really like to know about your ECG chair, sounds like a cool
    exhibit to have here!
    Al
    transistor or
    and filter
    available
    model and
    be a bit
    chair at
    took
    required
    Parallax
    Where are
    Before designing a human testing device for general use or sale in the US,
    it is a good idea to check into what FDA regulations will govern its use.
    This is especially true for ECG due to electrode contact, and the
    possibility of current delivered to the subject through the electrodes
    through equipment failure. This is considered by the FDA a Class II device.
    Total current leakage should be < 50 uA. Circuitry from power supplies to
    isolation amplifier chips should be UL2601 approved. Circuit boards should
    have a 4 mm air gap separating isolated human circuitry (ground planes,
    etc.) from other circuitry, among many other things.
    Been there done that,
    Dennis
    WSR, Inc (OEM for medical diagnostic equipment)
    Pasadena CA
    From: burtsz@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=146XnvTHIn3r6fQoYKD1IQcHrXLDzciw8OAU5NY7SxBLsNME_pL3VyXVpXgIzuXD1aGJvcY]burtsz@a...[/url
    Sent: Sunday, January 14, 2001 11:42 AM
    To: basicstamps@egroups.com
    Subject: Re: [noparse][[/noparse]basicstamps] blood pressure
    available
