1 or 2 chip stepper controllers...
I'm trying to find a one or two chip stepper controller that I can use
serout or shiftout commands to talk to. I've seen the 8 pin chip that
FerretTronics sells, but it's too slow (2400bps only).
BTW, the search engine for the stamp list is broken. [noparse]:)[/noparse]
g.
g.
I recommend using a Stamp along with a ULN2003 darlington driver chip, as
described in Note 6: A Serial Stepper Controller, BASIC Stamp Manual 1.2, by
Parallax. It uses only 2 stamp pins, and relies on the 2003 to provide the
4-bit stepping sequence. My addition to this design was to add a relay,
controlled by one of the unused 2003 channels, to switch the motor on just
befor rotation, and off just after rotation. Otherwise, it's always
activated.
Dennis
From: Gene Buckle [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8DCy16OgqPlQGsnZs_APrebVF4p5Hox8O0d6WrbjQkvTgy4qLH_ZhmjMm3NrPVbYU8i4-RZ6mwh05nGL]geneb@d...[/url
Sent: Thursday, January 11, 2001 9:29 PM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] 1 or 2 chip stepper controllers...
g.
to a stepper motor. [noparse]:)[/noparse] I suppose I could use a BS1 for that though...
Does that controller circuit allow for quarter stepping?
Thanks.
g.
On Fri, 12 Jan 2001, Dennis P. O'Leary wrote:
> Gene,
> activated.
> Dennis
> From: Gene Buckle [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SC9tEMthjSAlZNdVrPL7hFMtZllYTORkyzANXNpvIHUP9M4VJQSGVGSxpypmqNXizwxmm8x_OawzvXXFVx8]geneb@d...[/url
> g.
I've had good luck with the Allegro UCN5804B.
http://www.allegromicro.com/sf/5804/index.htm
I drive size 11 and 17 motors directly in half step and full step mode.There is an output enable if you want to dedicate an extra pin to powerthe motor down when not in use. I have gotten these from Newark (theirpart # 09F1557) for $3.74 each, butthe minimum order of $25 may be a problem for you.
They are in some of the kits sold by H&R and they sell a $10.95 ICthat may be the Allegro part.
http://www.herbach.com/images/stepmkit.pdf.
Hope that helps.
At 09:29 PM 1/11/2001 -0800, you wrote:
serout or shiftout commands to talk to.· I've seen the 8 pin chipthat
g.
this?
g.
On Fri, 12 Jan 2001, MIKE WALSH wrote:
> Gene,
> There is an output enable if you want to dedicate an extra pin to power the
> motor down when not in use. I have gotten these from Newark (their part #
> 09F1557) for $3.74 each, but the minimum order of $25 may be a problem for
you.
> They are in some of the kits sold by H&R and they sell a $10.95 IC that may
> Hope that helps.
> Mike
> >g.
None that I've found. I have the same speed issues (can't live with 2400
baud control) in most of my applications.
Good luck!
At 02:27 PM 1/12/2001 -0800, you wrote:
>Thanks Mike, I'll give this a peek. Are there any SPI chips that can do
>this?
>g.
for bipolar motors). These are excellent controllers as they free up the
stamp to do other tasks after you issue the control commands.
I use them in a production instrument which we still manufacture although we
do not use the BS2 ( we use straight PICS instead).
You can find the ELab inc. site at http://www.elabinc.com/
Cheers
Fritz
To: <basicstamps@egroups.com>
Sent: Friday, January 12, 2001 6:04 PM
Subject: Re: [noparse][[/noparse]basicstamps] 1 or 2 chip stepper controllers...
> Gene,
> Good luck!
> Mike
> >this?
> >g.
g.
> Gene,
> Good luck!
> Mike
> >this?
> >g.
From: Gene Buckle [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2RU_Gl3ubgziobaOKv2kBZngN2labC4uwdIf7fhV5bwaRc_EKW9LpV22xHEJIfsLYf8A3LjZ23aUZw]geneb@d...[/url
Sent: Friday, January 12, 2001 12:08 PM
Subject: RE: [noparse][[/noparse]basicstamps] 1 or 2 chip stepper controllers...
Dennis, the problem there is I'd have a Stamp talking to a Stamp, talking
Gene,
No it doesn't -- not even half-stepping unless you use 4 stamp pins and
modify the driver circuit connections. I agree with Fritz's suggestion to go
with Elabs.
Dennis
>From: Gene Buckle [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xqxsMBC3H8spw-M4259-kQncmRovkMsjA1pJu_1Td41Ik2oo5mnzsJxYroCbr_KWhNns8lNyR2bfQ_yoZ-I]geneb@d...[/url
Gene -- This can actually be useful. I have a PIC(#1) talking to a PIC(#2)
controlling 2 steppers and a laser diode. PIC#2 sends character codes back
to PIC#1 detailing stepper motion and laser on/off states. PIC#1 controls
A/D conversion. It use the info from PIC#2 to sit bit codes in unused bits
in each A/D hi-byte, before uploading a 2-byte word to a VB program on a PC.
Dennis
doleary@h... writes:
<< doleary@h... (Dennis O'Leary) >>
UNSUBSCRIBE......NOW
don't you go back to egroups.com and unsubscribe where you first subscribed?
From: shirmel@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VVCxbqScdFEa973QQ8NaZkp8x5lrTfkaJIzuADjxTeORVxm6LndH003gSdQ4pFZ_AgP5pOFi7j6c]shirmel@a...[/url
Sent: Tuesday, January 16, 2001 3:28 PM
To: basicstamps@egroups.com; Dennis O'Leary
In a message dated 1/16/01 2:41:48 PM Eastern Standard Time,
"didn't like my answer." Sheesh.
From: Stratton Design Studios [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G12Gwpxal-iKkN4Z5bJBX4pr7XxcPK9eIr6wMCQ_R4XtP8saqYjAFlY0Tsg6GLZADJbOcBzgDQMbT8R1BXnn6YV0hhmuVI1u]cory@s...[/url
Sent: Tuesday, January 16, 2001 5:12 PM
Hey buddy, you'll be blue in the face trying to unsubscribe this way. Why
From: shirmel@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wpa-6tEBF3k00PjxpfiGdH7JkEhZkC52rOUaLlYUp3F_Hwm0I02f2ngAXbUDLqq2J7SqMirP]shirmel@a...[/url
hehe
Just wanted to clarify that I am NOT the person trying to unsubscribe. The
perpetrator is: shirmel@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h2RwCzuYpf_cxPu2ATpw7ssnahz75KGHYPsDFUfeK4n8qK4hkOwnB9njNRuWhJqutrOEsR_DqJU]shirmel@a...[/url
Dennis
From: Cy Brown [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vaNzNPaEXQqY0igi1-6bGOiOrzHe67o34fxBf8SW_HHYpSTgfikTk7zWhVd6OvYw8JCQ-bx7bILOwPUhcJw]bushman@t...[/url
Sent: Tuesday, January 16, 2001 9:04 PM
Thats priceless.....
hehe
