Ascii?
Does anyone know how to send an ASCII string via serial port if I
want to send an ASCII letter while holding down the ctrl key..for
example "ctrl V", what is the ascII equalivant? Thanks...
Hi -
I'm just guessing at what you are attempting to do, but I believe
you may need more information that. Here is a reference regarding the
IBM Keyboard, how it operates, what scan codes are issued, a picture
of a keyboard with all keys lettered with their values, and generally
what goes on inside.
[noparse][[/noparse] http://www.beyondlogic.org/keyboard/keybrd.htm ]
As an additional bit of information, you may want to check
Al WIlliams site for the PAK-VI, and using it to interface
with a Stamp. His site is located here:
[noparse]/noparse][url=http://www.al-williams.com/awce/pak6.htm]http://www.al-williams.com/awce/pak6.htm[/url
Hope that helps
Bruce Bates
Chris
To: <basicstamps@egroups.com>
Sent: Thursday, January 11, 2001 7:39 PM
Subject: Re: [noparse][[/noparse]basicstamps] ASCII?
> Hi -
> Hope that helps
> Regards,
> Bruce Bates
codes.
In brief:
Code Decimal Value
^@ 00
^A 01
^B 02
^Y 25
^Z 26
^[noparse][[/noparse] 27
^/ 28
^] 29
^^ 30
^_ 31
Notation:
a "ctrl V" is shown as ^V
Daniel McGlothin
From: mcruz1@t... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xGu5p8zdKO87h6lJzsx245Y-3Isjc0-hiuiPkkfIaZmDJgWdMHVDjPzswbSGBLSpd4etFDycvIpyeqclcO8]mcruz1@t...[/url
Sent: Thursday, January 11, 2001 6:05 AM
To: basicstamps@egroups.com
Subject: [noparse][[/noparse]basicstamps] ASCII?
