!!!urgent!!!urgent!!!urgent___please_help!!!
···Friends, i am totally in a mess. I have an important project assignment (a final project for graduation) and i fount out that the stepper motor i am using cannot supply the required torque. I am thinking to use a Hitec HS-715BB servo now (able to make three full revolutions) but i·don't know whether i can control it with my BS2. Anyone having an idea please contact me urgently, because i do not have time (last three days, and there is still much work to do.
··· Any help will be appreciated, thanx in advance.
Jeff
To: basicstamps@egroups.com
Sent: Thursday, January 11, 2001 4:46 AM
Subject: [noparse][[/noparse]basicstamps] !!!URGENT!!!URGENT!!!URGENT___PLEASE_HELP!!!
From: Jeff Mitchell [noparse][[/noparse]mailto:EL-JEFE@PRODIGY.NET]
Sent: Thursday, January 11, 2001 3:47 PM
Subject: Re: [noparse][[/noparse]basicstamps] !!!URGENT!!!URGENT!!!URGENT___PLEASE_HELP!!!
I am no pro, but controlling the servo with a bs2 is relatively simple. You will use the "pulsout" command to generate the control signal. A pulsout value of 750 should be neutral or close to it. When the pulsout value rises above neutral (+-750) the servo will go forward and below neutral the servo will reverse. I recommend that you go to·www.Parallaxinc.com·and download the Boebot manual.· This manual has the instructions you need.
Jeff
The Hitec HS-715BB that you mention is a 90 degree servo
(http://www.hitecrcd.com/Catalog/Servos/HS-715.htm).
Did you mean that you are considering the Hitec HS-725BB
(http://www.hitecrcd.com/Catalog/Servos/HS-725.htm)?
In either case, it seems that the servo would respond to standard servo
pulse trains. Unfortunately, I did not find a manual for this servo on
Hitec's web site.
Are you using this servo un-modified (limited to the servo's mechanical
rotation of 3.5 turns) or have you modified it for continuous rotation?
You might consider contacting Hitec directly in you need servo specific
help. Their page http://www.hitecrcd.com/ETC/ask_hitec.html has both e-mail
and phone numbers.
Daniel McGlothin
From: Osman Burak Celebi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MC5xZ9CDv0JIVW_wL5nr2x0dD-uiPOmiBB6llVmiysAjKYjjItYV8wj61qmbc1h69BqNWLgWihpSQ7IpGmxU4Fg]obcelebi@s...[/url
Sent: Thursday, January 11, 2001 12:46 PM
Subject: RE: [noparse][[/noparse]basicstamps] !!!URGENT!!!URGENT!!!URGENT___PLEASE_HELP!!!
but the problem is; the servo i want to use is not an ordinary standard
servo. It is a special sail winch that can return 3.5 turns
From: Jeff Mitchell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gUioj2UDzNGY2rQ8Bc-ttmuMonqv3Q_DqmbSSyKOX__wliJBT60bCg0zelqvy0R0sFHNnkiUQ5-dNtg6WRs]EL-JEFE@P...[/url
will reverse. I recommend that you go to www.Parallaxinc.com and download
the Boebot manual. This manual has the instructions you need.
Jeff
HS-715BB servo now (able to make three full revolutions) but i don't know
much work to do.
from Hitec. Half an hour ago we made some experiments on the servo and
solved the control problem. But there is still one thing i cannot
understand. If no program is loaded on BS2, the servo starts revolution
infinitely, but when i write a program to control its position, it obeys the
3.5 revolution limit and stucks at the end position.
And i have one more question about servos (it may be a little newbie
question). When the servo finishes its work (this one is a HS300BB standard
servo but also the new one does it) that is when it reaches the final
position i give, it tries to move in small strokes and it ruins the
position. What can i do to totally stop a servo in the middle of a big
program (in the robot we are building the standard servo does a subroutine
in several positions)?
Thanx for your advices and help.
Osman Burak Celebi
From: D. Daniel McGlothin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mDqkAVnnUlTDvJc-Mp8sp51inwpVrxAJpPM6RUmSMO68daa7U6xQEgvPdK_TvZQWupozWtWW-vKs]ddm@r...[/url
Sent: Thursday, January 11, 2001 10:52 PM
Jeff might be right anyway.
Hitec's web site.
and phone numbers.
Daniel McGlothin
From: Osman Burak Celebi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EntGWrMVDO8DcsRydyuArOJ8kkAUTfsSu4gWsOrXaVcYI6pItQUziRAg-frIH5cQaenQphuk70Fdz5zU-VL0dM31]obcelebi@s...[/url
From: Jeff Mitchell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=C9OgQVqviAvsg6O0Gp__96DIfAemaaumGaeBaNH-wF8GLQeP1gUTsXq55yUBbsCLhsU7UHLs5sWi]EL-JEFE@P...[/url
Jeff
much work to do.
think a pulldown resistor would stop that rotation.
As for sticking at the end... are you in fact sending continuous pulse
trains?
To "center" it -- assuming it works like all the servos I've seen (I haven't
used your model), you'd write something like:
again:
PULSOUT 0,750 ' 1500uS
PAUSE 20 ' 20mS -- might be your processing in here instead of
pause
goto again
Note you have to keep sending it pulses.
Al Williams
AWC
*Control 8 servos: http://www.al-williams.com/awce/pak8.htm
> From: Osman Burak Celebi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a-ifSI_dTIDF00cx84Fr97qg_TqpkQ3kzOZAqKke605LuXNe_7vneg8Cmu3ONwhvsI1sMB-oMPCzWJyKK_OC]obcelebi@s...[/url
> Sent: Thursday, January 11, 2001 3:28 PM
> oops... sorry. Yes, i have a Hitec HS-725BB and i am still
> waiting reply
> it obeys the
> HS300BB standard
> Osman Burak Celebi
> From: D. Daniel McGlothin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=I2ZyyUIcUC0z_NMFRqvjLPfNdl6VbTeFefxVLvFd-mPcJlfEWDOXELeTPggameaY1MFJan999UMGSA]ddm@r...[/url
> Hitec's web site.
> both e-mail
> and phone numbers.
> Regards,
> Daniel McGlothin
> From: Jeff Mitchell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UYpIFBOCBh8R3qaHHIc0ktlW0FD9bCM53MhRb1oZAe_VAjZpb4qPHsR9X4gwlNieeipXDZ-YdTyc2ko9fw]EL-JEFE@P...[/url
> simple. You
> value rises
> the servo
> Jeff
> motor i am
> there is still
> much work to do.
things you're reporting.....
first, when you power up a R/C style servo, it immediately expects to
see 1-2 millisecond pulses coming to the pwm wire. a pulse shorter
than 1.5 milliseconds tells the servo to go one direction, a pulse
longer than 1.5 milliseconds tells the servo to go the other way.
when you power it on without any program loaded and running on your
basic stamp to tell it where to go, the servo immediately assumes
that it is getting a 0 millisecond pulse and it immediately pegs to
one side.
i think the easiest way to run a servo connected to a basic stamp is
by using a serial servo controller. that way you can tell the servo
to go to position x and stay there until you tell it to go to another
position. also, the serial servo controller automatically sends the
servo a 1.5 millisecond pulse to center it upon power up. since you
have less than 3 days to finish your project, getting one is probably
impractical.
i have had trouble with hitec servos recently. i just put together a
6 legged robot walker using 12 hitec hs300 servos. about 6 of the 12
servos were extremely inaccurate in their center positions (not
anywhere near the center of the range of motion) and they were very
jerky when they moved. some of them just wouldn't even center
properly. they would attempt to center upon power up but they would
jerk back and forth and never find a stable home position. i ended
up ripping all of them out and buying 300 bucks worth of good ball
bearing servos of a different brand and was immediately relieved. i
don't know what the higher end servos from hitec are like, but i can
say that the low end stuff is poor. there is a BIG difference
between cheap servos and INEXPENSIVE servos. the particular brand i
switched to was HOBBICO. the hitec hs300 servo sells for about 15
bucks apiece and has only 1 crummy nylon bushing supporting the
output shaft. HOBBICO's 15 dollar servo has dual ball bearings on
it's output shaft and more torque and a faster rotation speed.
good luck with your project.
