BS2 small voltages — Parallax Forums
BS2 small voltages
edited 2001-01-11 16:51 in General Discussion
Hi there.
I'd like some suggested methodologies for reading voltage ranges in the 0
- 200 MV range on the BS2. Ultimately I either need to be able to read a
voltage range or set up an intelilgent "trigger" point of about .1 volt
that triggers a high line ; as it is, the voltage is too small to send the
line high.
Thanks.
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
    edited 2001-01-10 03:33
    Hi Sean,
    An opamp with a gain of 25 would provide 0 to 5 volts. If you only need the
    signal to trigger a logic level, just use a comparator with its reference
    set at the desired trigger voltage.
    Ray McArthur
    To: Basic Stamps <basicstamps@egroups.com>
    Sent: Tuesday, January 09, 2001 8:14 PM
    Subject: [noparse][[/noparse]basicstamps] BS2 small voltages
    > Hi there.
    > line high.
    > Thanks.
    edited 2001-01-10 06:41
    On Tue, 9 Jan 2001, Ray McArthur wrote:
    > Hi Sean,
    I know nothing about comparators - could you please briefly explain or
    give me a URL reference?
    Thanks.
    edited 2001-01-10 19:37
    >only need the
    Hi Sean,
    100k 2000
    +5 ---/\/\--o--/\/\---common
    |0.1
    |volt
    | |\ 1/2 LM358
    | >---P0 stamp
    signal -/\/\---|+/
    1000 |/
    output to Stamp P0 is high when the signal is >0.1 volt, low when
    signal <0.1 volt. Voltage level set by resistors or potentiometer.
    The 1000 ohm resistor protects the input. Also needs power
    connections, pin 8 to +5 volts, pin 4 to common.
    You can use an op-amp, such as the cheap LM358, which gives you two
    comparators in an 8-pin package for 30 cents. Or you can use a
    dedicated comparator chip, such as the LM393, also a dual package for
    30 cents. The LM393 would require a pullup resistor on the output.
    The difference between an op-amp and comparator is, not much. A
    comparator is optimized for speed of operation in switching, while
    the op-amp is optimized for stability as an amplifier. For use on
    the stamp, there isn't going to be a noticeable difference.
    Positive feedback can be added to make the switching snappier:
    100k 2000
    |0.1
    |volt
    | |\ 1/2 LM358
    | >----o--P0 stamp
    signal -/\/\-o-|+/ |
    1000 | |/ |
    100k
    Switches high at 0.101 volt, low at about 0.0.099 volt. Do you need
    to be able to set different thresholds, other than 0.1 volt?
    I recall there is something about comparators in Al William's FAQ.
    I hope this clarifies it a bit,
    -- Tracy Allen
    http://www.emesystems,com
    edited 2001-01-10 20:53
    To add to Tracy's excellent response:
    I have not used the LM358 opamp, but one time we had a design to debug using
    many opamps as comparators. The opamps would sometimes latch high or low
    when driven hard to one rail, (don't remember which rail), and sometimes
    even reverse gain polarity. We fixed the circuit by using genuine
    comparators. Don't remember what the opamps were, but since that time we
    like to use comparators for that function.
    Ray McArthur
    edited 2001-01-11 02:58
    Thanks Tracy,
    That was a fine explanation and sketch.
    Appreciate it.
    Been wondering about comparators for a while now.
    Mark
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Wednesday, January 10, 2001 11:56 AM
    Subject: Re: [noparse][[/noparse]basicstamps] BS2 small voltages
    >>only need the
    reference
    >Hi Sean,
    > 100k 2000
    > |0.1
    > |volt
    > | |\ 1/2 LM358
    > | >---P0 stamp
    > signal -/\/\---|+/
    > 1000 |/
    > 100k 2000
    > |0.1
    > |volt
    > | |\ 1/2 LM358
    > | >----o--P0 stamp
    > 1000 | |/ |
    > 100k
    > -- Tracy Allen
    Good point, and one fine point among many. Both the op-amp and the
    comparator will have a "common mode input range". Operating the
    inputs outside of that range may give bad results and particularly if
    the input goes beyond the power supply rails. The common mode input
    range for either the LM358 or the LM393 on a 5 volt supply goes from
    -0.3 volt up to about +3.5 volts.
    -- Tracy
