connections...
we connect the computer to our carrier board to program and it gives us a
system ground but can it work without the computer being connected. Once i
connect it once, will the chip remember the program and work on it's own.
and i connect a regular ground and leave sout, sin and atn unconnected
just make sure i have all my input pins and output pins specified and then
i can connect actual circuits to the stamp and download the file and when i
disconnect the computer just have a ground from whatever power supply i'm
using.
i can't use the battery then right? because then i'll have two seperate
grounds.... ??
using.
grounds.... ??
