Speed Controllers and DC motors
I need help. I am a newbie so take it easy on me [noparse]:)[/noparse]
I have the BS2, a traxxas speed controller, and a dc motor.
All I am trying to do is get the motor working with the BS2. I have
tried pulsouts toggles and many more, but nothing. The pulse line
form the speed controller is on pin one and the motor is hoocked up to
the speed controller. I am getting nothing at all. I know its in the
code, because the motor will run of a straight battery, the speed
contoller turns on and the BS2 is working fine with everything else.
Can anyone help? How would you right a simple code to make the motor
goooo.
Juggernaut911
goooo.
Juggernaut911
you need to write the code exactly like it was a servo. Look at this file
http://www.parallaxinc.com/downloads/stamps%20in%20class/wam3.pdf it covers
how to drive a servo.
Tim
[noparse][[/noparse]Denver, CO]
> From: Juggernaut911@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NXnLCdl0O-TFAHF_Lyb10nrgYNgCS0zkaTY-rEENKeZ6culwshzMGJwViE7S-yi7-UJaE0lCo5_We1Y1ECmtF16W]Juggernaut911@h...[/url
> Sent: Monday, January 08, 2001 10:22 PM
> To: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Speed Controllers and DC motors
> goooo.
> Regards,
> Juggernaut911
works just fine, but when I replace the servo with the (R/C) speed
controller and a motor on the same code, nothing happens. Put the
servo on there again it works fine.... speed controller nope [noparse]:)[/noparse]
Juggernaut911
--- In basicstamps@egroups.com, "Tim Goldstein" <timg@k...> wrote:
> If I recognize the name correctly the speed control is an RC car
unit? If so
file
covers
> Tim
> > From: Juggernaut911@h... [noparse][[/noparse]mailto:Juggernaut911@h...]
have
up to
the
else.
motor
> > goooo.
> > Regards,
> > Juggernaut911
and the (-) is the switched side. the output to the esc is the same as a
servo (+ - signal )but they may be in a different order from the servo.
(red black white) vs (black red white), so be sure you have the (+ - and
signal) on the correct pins. the esc may have to be powered from a
separate battery.
Juggernaut911@h... wrote:
> Well the thing is that when I put a regular servo on the stamp it
> Regards,
> Juggernaut911
> unit? If so
> file
> covers
> > Tim
> have
> up to
> the
> else.
> motor
> > > goooo.
> > > Regards,
> > > Juggernaut911
verify that the speed control works and also how it works? I have some R/C
plane speed controls that have to be taken all the way to low throttle for a
second of two first before they will arm and function. It is a safety
interlock to keep you from flipping on the receiver switch and having a prop
start turning at full throttle.
Tim
> Regards,
> Juggernaut911
require a low impiedance output from the pin. You may try use a
transitor follower as buffer. I alredy have experienced the same problem
before and it was solved with the buffer.
ACJacques
> Regards,
> Juggernaut911
> unit? If so
> file
> covers
> > Tim
> have
> up to
> the
> else.
> motor
> > > goooo.
> > > Regards,
> > > Juggernaut911
