updated-program
hello again :-)
here is my program now, pretty much the same but implementing the
branch statement as several of you suggested instead of the IF..THEN
statements i previously used....
i'm trying to write a program for the BS2 where i connect LED's to the
pins to demonstrate the algorithm i programmed in. When i built this i
will have actual external circuits connected to the pins but for now
i just want to have the controller run through different scenarios
any suggestion would be great.....
'=== constanst and pin
motion con pin 0
noise con pin 1
glass con pin 2
door con pin 3
buzz con pin 7
light con pin 8
light1 con pin 9
alarms var nibble
motion var alarms.bit0
noise var alarms.bit1
glass var alarms.bit2
door var alarms.bit3
motion = 0
noise = 1
glass = 1
door = 0
GOSUB check
motion = 1
noise = 0
glass = 1
door = 1
GOSUB check
motion = 1
noise = 1
glass = 1
door = 1
GOSUB check
end
check:
Branch INA,[noparse][[/noparse]check,,message,message,alarm,message,alarm,alarm,alarm,light]
RETURN
LED:
low light
pause 250
high light
RETURN
Message:
FOR counter 0 to 3
GOSUB blink
NEXT
blink:
low light1
pause 50
high light1
pause 50
RETURN
Alarm:
low buzz
pause 50
high buzz
RETURN
does this look correct? i'm confused about the declaring the direction
of the pins and the input and output pins?? i have the scott edwards book
and the manual from the website but it's not clear to me
saying low light -- does that automatically make it a output?
also my friend told me to be careful when touching the stamp ....
something about it being static sensitive or something and the static
in my body.... do i have to be careful or do something before i touch
the carrier board?? Will i damage the chip if i have too much static
in me or something??
thanks for your patience.... my questions must seem soooo basic to
most of you.... :-)
ps- i'm actually a student trying to use the stamp in my senior
design project... for my home security system..
- LaQuida
motion con pin 0
noise con pin 1
glass con pin 2
door con pin 3
buzz con pin 7
light con pin 8
light1 con pin 9
alarms var nibble
motion = 0
noise = 1
glass = 1
door = 0
GOSUB check
motion = 1
noise = 0
glass = 1
door = 1
GOSUB check
motion = 1
noise = 1
glass = 1
door = 1
GOSUB check
end
check:
RETURN
LED:
low light
pause 250
high light
RETURN
Message:
FOR counter 0 to 3
GOSUB blink
NEXT
blink:
low light1
pause 50
high light1
pause 50
RETURN
Alarm:
low buzz
pause 50
high buzz
RETURN
most of you.... :-)
- LaQuida
>motion con pin 0
>noise con pin 1
>glass con pin 2
>door con pin 3
>buzz con pin 7
>light con pin 8
>light1 con pin 9
The syntax is wrong. (The BS2 does not use the word PIN.) Your
outputs are buzz, light and light1. Use the following syntax:
buzz con 7
light con 8
light1 con 9
Then
low buzz
yes, that will turn P7 into an output, and makes it low.
The other constants, motion, noise, glass and door are inputs in your
program. That syntax there is wrong too. The way to give another
name to an input pin is the following, using alias name:
motion var in0 ' when used as a variable, as in [noparse][[/noparse]if motion=0 then alarm]
motion_pin con 0 ' as a pin reference, as in [noparse][[/noparse]pulsin motion_pin,0,x]
etc
But if you do that, you can't use the same names as part of a
variable, as you did nicely later in your program:
>alarms var nibble
I like that. Then you can command:
alarms=inA ' to get the current value at the input port
' or use your test patterns, like [noparse][[/noparse]alarms=1111]
Branch alarms,[noparse][[/noparse]check,,message,message,alarm,message,alarm,alarm,alarm,light]
You might want to start off your program with a couple of statements
that define all your outputs and inputs:
outs=%1110000000 ' makes buzz, light and light1 outputs, high to start.
dirs=%1110000000 ' and all other pins inputs to start.
good luck,
-- Tracy
dir=%11100000
is this saying that every pin is an output so i don't have to specify any
inputs??
i don't have to name them either?
if i use the same code below where i say
alarms var nibble
noise var alarms.bit1 ...
i don't have to specify which set of 4 pins are going to hold the alarms?
only specify the pins for the outputs i have to send a signal out to another
circuit?
>===== Original Message From basicstamps@egroups.com =====
>Hi LaQuida,
>>motion con pin 0
>>noise con pin 1
>>glass con pin 2
>>door con pin 3
>>buzz con pin 7
>>light con pin 8
>>light1 con pin 9
> buzz con 7
> light con 8
> light1 con 9
>Then
> low buzz
alarm]
>or
> etc
>>alarms var nibble
> good luck,
> -- Tracy
alarms.bit0 con 0
alarms.bit1 con 1
alarms.bit2 con 2
alarms.bit3 con 3
light con 7
message con 8
light1 con 9
alarms var nibble
do i need to specify which direction everything is ? what's an input and
output?
out = %00000001110000000
dir = &00000001110000000
so 16 I/O's all together and only 7, 8, and 9 are outputs?
I suggest that you try out a few short programs before you get too
deep into writing a your complicated program. Here are a few
resources that can help:
- the recently updated FAQ from <www.parallaxinc.com>
- Scott Edwards' book, "Programming and Customizing the BASIC Stamp"
- "What is a Microcontroller" text downloadable from
<www.stampsinclass.com>.
- the version 2.0 manual downloadable from <www.parallaxinc.com>
(try the examples)
- the new Microcontroller Allication Cookbook from Parallax
>alarms var nibble
>alarms.bit0 con 1
>alarms.bit1 con 2
>alarms.bit2 con 3
>alarms.bit3 con 4
The second group of definitions is bad syntax. You can't redefine
variables, much less chunks of variables. STAMP2W.EXE will tell you
that that is a syntax error. That is why you need to build your
program a little bit at a time.
Here is another snippet from one of the programs you posted:
>alarms = [noparse][[/noparse]0100]
>GOSUB check
>end
>check:
>alarms =INA
>RETURN
When the program hits the check subroutine, it will read the input
port A (The four bits for your security inputs) and put those values
in the variable alarm., replacing the value you put there in the
earlier statement. Then the Branch command ignores the value of
alarms anyway, and instead acts directly on the state of the input
port. Here is a modification:
alarms = %0100 <---note the change in syntax
GOSUB check
alarms =INA
GOSUB check
end
check:
RETURN
You see, the Branch now uses alarms, so that you can use either your
fabricated test data, or, by setting alarms=inA, the actual data at
the input port. Note also the %0100 form of the binary data.
Please, before you ask any more (specific) questions, try to run some
simple programs interactively from the reference materials. I think
then things will make more sense then. The syntax is not too
difficult, but like most computer languages, it is picky.
good luck,
-- Tracy
Don't forget the unofficial FAQ at
http://www.al-williams.com/wd5gnr/stampfaq.htm
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller at
http://www.al-williams.com/awce/pak1.htm
Or Microcontroller Projects with Basic Stamps by Al Williams [noparse]:)[/noparse]
