Need help for my robotics project
Hi all,
Well, I am a final year B.E. student in Electronics and I am
doing my final year project based on the Basic Stamp2. It is a black
line-following robot and I want to know if it is possible for the
robot to go around an obstacle and come back to the black line.
Besides this, my project guide is hell bent on knowing the
applications for this project. I have told him that it can be used
where it is not practical or it is expensive to use conveyor belts
(if the robot is built on a larger scale, of course) but he is not
satisfied. Please help .
Venkatesh Kanchan.
Venkatesh Kanchan.
>Hi all,
Hi Venkatesh -
The following presumes the obstacle has already been sensed, and the
robot merely needs to avoid it.
Generally this is done in one of two ways:
Pure trial and error - where the robot goes forward and reverse, left and
right until the black line is found again. This is often called the
"Wandering Drunk" problem, for somewhat obvious reasons. There is no rhyme
or reason to it, it just keeps wandering until it finds "home". "Home" is
merely the goal. The goal here, is being able to find the black line again.
This takes very little code, is quite inefficient but uses no other parts.
Intelligent wandering - where additional sensors are used to guide the
robot around the obstacle. An example of one which reads signs (bar codes)
can be
found here: [noparse][[/noparse]
http://design.me.metu.edu.tr/robot/RobotS/LineFollowingSign.htm ].
This shows one method, where signs are placed along the Robots path to assist
in knowing where it is. Here is another which uses multiple sensors which
are called far and near. The article is here: [noparse][[/noparse]
http://www.dprg.org/nl_july97.html ]
>satisfed. Please help .
Line seeking robots are used in warehouse situations. often for pick and
pack applications. The robot will traverse the warehouse floor, generally
following
an embedded cable. The cable emits an RF frequency which guides the robot.
Here too. the robot often reads signs; those at the ends of the aisles.
When it finds the correct aisle, it goes down the aisle and finds the
proper shelf and bin.
I hope that helps
> Venkatesh Kanchan.
Bruce Bates
Thanks a lot for your suggestion. I shall
definitely implement it. As for the application, youi
mentioned about the embedded cable while I am in
search of an application for the black line. Please
reply if possible. Thank You once again.
Venkatesh Kanchan
--- Bruce Bates <bvbates@u...> wrote:
> At 1/6/2001 Saturday 06:12 AM +0000,
> v_s_kanchan@y... wrote:
> >Hi all,
> Hi Venkatesh -
> possible for the
> black line.
> sensed, and the
> often called the
> used to guide the
> can be
> knowing the
> it can be used
> conveyor belts
> following
> ends of the aisles.
> aisle and finds the
> I hope that helps
> Venkatesh Kanchan.
> Regards,
> Bruce Bates
__________________________________________________
Do You Yahoo!?
Yahoo! Photos - Share your holiday photos online!
http://photos.yahoo.com/
bvbates@u... writes:
<< Line seeking robots are used in warehouse situations. often for pick and
following
proper shelf and bin. >>
Anyone have a schemtic of a embeded wire following robot? I would like to
figure out a way to do this.
