Fwd: v 2.0 manual
>The manual ... may be
>downloaded for free from www.parallaxinc.com. Like all of our documentation
>this requires the PDF 4.0 viewer from www.adobe.com.
>Free BS2-IC for finding errors!
>Though we aim for technical perfection the possibility for errors always
>exists. Just like our other documentation, if you identify technical errors
>in our manual we'll give you a free BS2-IC. No nitpicking here, please - put
>in a fair effort and give us a list of technical corrections. We reserve the
>right to decide if you qualify for a BS2-IC, and respectfully ask that you
>agree to this before submitting comments.
>Please send your comments to Jeff Martin (jmartin@p...).
Hi Jeff,
Here are a couple more comments on the version 2.0 manual, the
SEROUT/SERIN section.
--- Table 5.72 and table 5.81. Huh? Isn't the baud rate determined
by bits 0-12, not bits 0-11? The minimum baud rates are then.
BS2 & BS2e & BS2Pe: 122 baud to 50 kbaud
BS2sx & BS2P: 304 baud to 50 kbaud
I wouldn't swear to it, but all the earlier manuals referenced bits 0-12.
--- I am puzzled about the "baud limit with flow control" in table
5.79? That hasn't been in previous documentation. I was sure flow
control would work at any baud rate, between stamps of the same speed.
--- Re The timeout parameter: to get a timeout of N milliseconds the
timeout parameter has to be N+1. E.g., to get a timeout of 1
millisecond use timeout parameter=2. It can be a bug if the timeout
parameter is 0 or 1.
http://www.emesystems.com/BS2rs232.htm#timeoutbug
best regards,
-- Tracy
Hi Jeff,
best regards,
-- Tracy
