Alternatives
Check out the CDP68HC68P1E Peripheral I/O IC, this gives you 8 bit bi-
directional I/O using the SPI bus. You can have 4 devices attached
to the same 4 pins from the stamp, and select each one by selecting
one of the addresses 00, 01, 10, 11. Data is only sent to the O/P's
when you cycle the enable pin.
Regards
Jon
Regards
Jon
>Hi,
>Regards
>Jon
Hi Jon -
> From what I can find on the web the CDP68HC68P1E is only available from
Dial Electronics in the UK. I've no idea what the chip might ordinarily
cost, but Dial want $ 9.95 just to ship anywhere but the UK. Would you happen
to know of another source ? Additionally, Dial offers no data sheets, would
you happen to know where they might be found ?
Thanks in advance
Bruce Bates
Found small stock here:
http://www.advanced-tech.com/Inv/webinvtxt.txt
They look like OLD Harris Semi parts.
If I got the # correct, it appears that Intersil has picked the part up. It
is in their Oct 2000 catalog and can be found at http://www.intersil.com.
Sorry, I didn't look for a source to sell them.
Hope that helps, Bruce.
At 01:13 PM 1/3/2001 -0500, you wrote:
>At 1/3/2001 Wednesday 04:25 PM +0000, Jonathan Millard wrote:
> >Hi,
> >Regards
> >Jon
>Hi Jon -
>Thanks in advance
>Regards,
>Bruce Bates
_________________________________
Mike Walsh
walsh@i...
California Institute of Technology
Biology Electronics Shop
MS 216-76
Pasadena, CA 91125
>Bruce,
>Mike
Hi Mike -
I found that text file too. I looked on the Itersil site and got NOWHERE.
No biggie - I was more curious than anything. It's tough any more being a
data sheet junkie : )
PAK-III will add 8 and both are readily available.
Al Williams
AWC
> > >Regards
> > >Jon
It does look like an interesting part. With a little digging, I did find
them at Arrow and Future. Both have online ordering. The Future part is
$4.50 in 1-49 parts and is in stock. They get $7.00 to ship UPS ground in
the US. Sounds like an affordable price to try a few of them out. I
couldn't figure out if Arrow has them in stock. They were quite a bit
cheaper there, but they wanted $17 to ship it, so I'm going to give them a
miss this time. It may make sense if I use them in quantity.
Hope this helps Bruce, too.
At 04:25 PM 1/3/2001 +0000, you wrote:
>Hi,
>Regards
>Jon
Mike Walsh
walsh@i...
MS 216-76
Pasadena, CA 91125
