Error Hardware not Found.
Hi, everone. I am having problems with my BS2. I have
programmed my stamp before( its been awhile ) and didn't have
any problems, until recently. I have verified com port 2 with
other equipment. Sometimes I can get thru and most of the
time I can't. If I access the stamp with a communication
program, I can see the stamp talking. I just can't get it to
re-program at will. I have put a volt meter on RES and watch
it go from +5v to 0v by pressing reset. ATT stays at -12V.
While pressing ALT-I or ALT-R and scoping ATT goes from -12v
to +12v, and RES goes from +5v to 0v in step. But the Computer
Screen shows " Error Hardware not found ! "
HELP
Bruce
HELP
Bruce
>Hi, everone.
Hi Bruce -
Which Stamp Editor are you using and which version of that Editor ?
Are you using a pre-prepared cable, or one of your own manufacture ?
If you have made your own, did you take note of the requirement to add
the JUMPER between pins 6 and 7 (DSR and RTS) to permit auto port detection ?
If you have NOT added the jumper you will NEED to do one of the following,
depending on which Editor you are using -
For the DOS Editor:
You will have to indicate that you are using COM2. You will need to supply
a /2 parameter to the DOS Editor program (STAMP2.EXE /2)
For the Windows Editor(s):
You will have to indicate that you are using COM2. The ORIGINAL Windows Editor
may require the same parameter as the DOS Editor (can't remember) but
Version 1.093+ (Or the current Windows Editor V1.096) SHOULD prompt for it.
If it DOES NOT you need to set the default COM port in the Editor
Preferences area, found under the Editor Operation dialog box.
Is this what you meant by "see the Stamp talking" ? If NONE of the
suggestions above provide a solution, would you explain a little further
what you mean by "see the Stamp talking" ? This would imply that the
program is active within but I don't want to make that presumption before
the fact.
>HELP
HELP is here : )
>Bruce
Bruce Bates
> Is this program keeping the stamp so busy that it is failing
> to reload another program or to get the stamps attention using
> ALT-I ? If so what can I do to prevent this ?
I had a problem like this when I first started stamping. Short program
that started running a tight loop from the first line of code. It was very
hard once this program was loaded to re-program the stamp. It seemed that
the loop was so tight that it was off and running before the programming
interface could catch it. I started putting a pause 500 statement as my
first line of code and all my troubles went away.. ( well that problem
anyway )
Hope this helps,
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
wrote:
> At 1/3/2001 Wednesday 07:15 AM +0000, bsnowde@i... wrote:
> >Hi, everone.
> Hi Bruce -
have
Editor ?
manufacture ?
requirement to add
port detection ?
the following,
> For the DOS Editor:
need to supply
remember) but
prompt for it.
Editor
box.
watch
-12v
Computer
of the
little further
that the
presumption before
> the fact.
> >HELP
> HELP is here : )
> >Bruce
> Regards,
> Bruce Bates
Thanks Bruce for your reply.
First, I may have fixed my problem, but I am not sure, or why.
To answer your questions. I am using the DOS editor, but I
don't know which version. All I have is a F1 HELP key at the
top of a blue screen. Can't find anything that says what
version. I use an older computer to play with under OS/2
Warp.
I have tried several different store bought cables, same
results. I am using the BS2 carrier board. I think the board
has pins 6 & 7 jumpered together.
Yes I have the /2 parameter at the end of my start program. (
bat file )
When I was refering to my "stamp talking" I meant that I can
see data coming from the stamp using a DOS version of ProComm
Plus communication program. AND that may be my problem ?? I
have a test program that I call TESTCOM.BS2 TESTCOM job is to
multiply a couple of numbers and send them back to the
computer via serial cable. It is my way of testing my
communication path. The code looks like this:
length VAR byte
width VAR byte
area VAR word
length = 26
loop:
width = 13
area = length*width
debug "Area =",DEC area,"sq. ft."
length=length + 1
goto loop
While researching your questions, I was able to get thur to
the stamp. In the past I have been reloading TESTCOM, but
this time I reloaded another program. The problem seems to
have disappeared. Or I have a cold solder joint or something?
Maybe too early to tell for sure. I have not reloaded TESTCOM
for fear that it would hang up again.
I hope I haven't overloaded you with question, but I would be
interested on any thoughts you have.
Thanks Bruce
> --- In basicstamps@egroups.com, Bruce Bates <bvbates@u...>
> > >Hi, everone.
> > Hi Bruce -
> have
> Editor ?
the
> manufacture ?
> requirement to add
auto
> port detection ?
of
> the following,
> > For the DOS Editor:
will
> need to supply
> remember) but
SHOULD
> prompt for it.
the
> Editor
> box.
> watch
-12V.
> -12v
> Computer
NONE
> of the
> little further
imply
> that the
> presumption before
> > the fact.
> > >HELP
> > HELP is here : )
> > >Bruce
> > Regards,
> > Bruce Bates
why.
the
> Warp.
board
> bat file )
can
ProComm
I
to
> length VAR byte
> width VAR byte
> area VAR word
> length = 26
> loop:
> width = 13
> area = length*width
> length=length + 1
> goto loop
using
something?
TESTCOM
be
> Thanks Bruce
Well shucks, No such luck. My problem is back with another
program loaded. Intermitten Hardware not found error.
Bruce
> > >Hi, everone.
> > Hi Bruce -
>have
>Editor ?
>manufacture ?
>requirement to add
>port detection ?
>the following,
> > For the DOS Editor:
>need to supply
>remember) but
>prompt for it.
>Editor
>box.
>watch
>-12v
>Computer
>of the
>little further
>that the
>presumption before
> > the fact.
> > >HELP
> > HELP is here : )
> > >Bruce
> > Regards,
> > Bruce Bates
You're welcome Bruce (now there a three of us)
>GREAT !
>Warp.
Officially the Stamp software is not supported under OS/2,
but if it's worked before - fine.
stamp.exe /? may provide the version, or knowing the DOS filesize and date.
>bat file )
>Good that should avoid any problems - regardless on pin 6 & 7 being jumpered
Are you using serout or debug in your program ? Is it that type of output ?
Or do you mean control pins are changing state ?
> I
>length VAR byte
>width VAR byte
>area VAR word
>length = 26
>loop:
>width = 13
>area = length*width
>length=length + 1
>goto loop
Okay - you're using DEBUG.
>That's possible. A PAUSE statement inserted anywhere in the loop.
>have disappeared.
That would tend to verify what you suspect, and I would concur.
>Insert the PAUSE which will open that tight lopp up some.
>Nope - no problem - you've got it for the moment.
>Thanks Bruce
Sure
Bruce Bates
wrote:
failing
using
Short program
code. It was very
It seemed that
programming
statement as my
that problem
> anyway )
> Hope this helps,
> internet> dale@h...
Dale,
Yes, it did help. Putting the pause did help most of my
problems. I am still experencing a similar problem but it is
only occurs ever now and than now. I think I had two problems
, tight code and a cold solder joint somewhere(yet to be fix).
I have never been know to write tight code until now. :->
Bruce Snowden
wrote:
wrote:
> > > >Hi, everone.
> > > Hi Bruce -
didn't
> >have
that
> >Editor ?
the
communication
> >manufacture ?
> >requirement to add
auto
> >port detection ?
of
> >the following,
> > > For the DOS Editor:
will
> >need to supply
> >remember) but
SHOULD
> >prompt for it.
the
> >Editor
dialog
> >box.
> >watch
-12V.
> >-12v
> >Computer
NONE
> >of the
a
> >little further
imply
> >that the
> >presumption before
> > > the fact.
> > > >HELP
> > > HELP is here : )
> > > >Bruce
> > > Regards,
> > > Bruce Bates
why.
> >GREAT !
I
the
> >Warp.
filesize and date.
board
> >bat file )
7 being jumpered
can
ProComm
type of output ?
> > I
to
> >length VAR byte
> >width VAR byte
> >area VAR word
> >length = 26
> >loop:
> >width = 13
> >area = length*width
> >length=length + 1
> >goto loop
failing
using
loop.
> >have disappeared.
concur.
TESTCOM
be
> >Thanks Bruce
> Sure
> Regards,
> Bruce Bates
Bruce,
I think I am on the right track now. I think I had two
problems. The pause command did help, and did improve things
about 85%. I think the second problem is a loose connection
somewhere.
Thanks for you help
Bruce Snowden
