BS2SX baud rate limitation...
After perusing the _new_ Stamp docs (tnx Phil!), I see that the BS2SX
basically chokes on any inbound data rate higher than 4800 baud. My testing
seems to bear this out. Is there _any_ way to get around this? I've got an
application that will require one stamp updating 14 other stamps (which in
turn will update 14 other devices) and 4800 baud is WAY too slow for this.
Am I stuck with this limitation?
tnx.
g.
tnx.
g.
Hi Gene,
It is not so much of a problem when you have one Stamp talking to
another Stamp of the same type. The SEROUT from one stamp
automatically adds extra stop bits. That gives the SERIN Stamp
plenty of time to react.
The problem arises when you ask a Stamp to receive data from a device
like an instrument or a desktop computer that sends the bytes head to
tail with no extra padding.
See
http://www.emesystems.com/BS2rs232.htm
for additional info and tips about the timing of the Stamp serial commands.
-- Tracy Allen
testing
an
in
this.
> Hi Gene,
> See
commands.
Thanks, I'll check it out!
For those interested, this project of mine is in part to support THIS
project: http://deltasoft.fife.wa.us/f15images.html
g.
> See
commands.
Tracy, do you know where I can find the pinout for the DB9 connector that
the BS2 board uses? I need to build a handshake capable serial cable.
Thanks!
g.
You'll find this on page 212 of the manual, version 1.9.
Phil.
To: <basicstamps@egroups.com>
Sent: Saturday, December 30, 2000 8:41 PM
Subject: Re: [noparse][[/noparse]basicstamps] BS2SX baud rate limitation...
> Thanks!
> g.
Thanks Phil!
g.
