Odd baud rate problem...
Here's the setup:
BS2-SX on a "standard" carrier board with the DB9 connector.
I've got the software in the stamp set up to send an "A" as part of it's
init sequence.
The line is:
SEROUT 16, 16390, [noparse][[/noparse]65]
According to the manual, 16390 is 38400, 8, N, 1 in "inverted" mode which is
what is required when using the DB9 connector on the carrier board.
Unfortunately, all I get is a lower case "u" with a pair of dots over it
(umlauts?) instead of the letter "A" as I expect. I've been pulling my
hair out most of the day trying to figure this out. I'm assuming a related
problem is preventing the board from receiving "normal" serial input as the
device I have connected doesn't respond according to the values I'm sending.
(the connected device is ok. If I send values right from the stamp it works
flawlessly)
Thanks for your time!
Gene Buckle
geneb@d...
init sequence.
The line is:
flawlessly)
Gene Buckle
geneb@d...
You should go to the Parallax site and download the addendum for the BS2-SX
(version 1.5). You'll find lots of important informations to use the SX, and
that will help to keep your hair... :-)
One of the differences between the BS2 and the BS2-SX is the baudmode value.
For the SX, you should replace 16390 with 16429.
I experienced the same problem a few months ago, with an LCD display, but
with the good values, it's OK.
Hope this helps.
Phil.
Subject: [noparse][[/noparse]basicstamps] Odd baud rate problem...
> Here's the setup:
> init sequence.
> The line is:
is
related
the
sending.
works
> flawlessly)
> Gene Buckle
> geneb@d...
of the egroups archives. [noparse]:)[/noparse] I looked on the parallax page but didn't
see it under the documentation/software downloads. Is it hidden
somewhere?
Thanks!
g.
--- In basicstamps@egroups.com, "Philippe Derenne" <derennep@s...>
wrote:
> Hi Gene,
the BS2-SX
the SX, and
baudmode value.
display, but
> Hope this helps.
> Phil.
>somewhere?
>the BS2-SX
> > (version 1.5).
The addendum is no longer there, because all that material has been
rolled into the new version 2.0 BASIC Stamp manual:
http://www.parallaxinc.com/html_files/downloads/download.htm
(2 meg download) The baud rate tables for the BS1, BS2, BS2e, BS2sx
and the new BS2p are all there together on page 277 (279 in acrobat).
You can also find a baud rate table for the BS2SX in the FAQ at Al
William's site:
http://www.al-williams.com/wd5gnr/stampfaq.htm
-- Tracy
> >the BS2-SX
> > > (version 1.5).
> William's site:
Thanks Tracy - now if I can just get around the 4800 baud limitation.... [noparse]:)[/noparse]
g.
I've seen that the addendum is no more on the site. Sorry, I haven't been
there for a few weeks...
Let me know if you can't find the baudrate table, I'll send you the addendum
(PDF document).
Happy New Year !
Phil.
To: <basicstamps@egroups.com>
Sent: Friday, December 29, 2000 7:56 AM
Subject: [noparse][[/noparse]basicstamps] Re: Odd baud rate problem...
> Phil, thanks for the help! I missed your reply and had to dig it out
> somewhere?
> Thanks!
> g.
> wrote:
> > Hi Gene,
> the BS2-SX
> the SX, and
> baudmode value.
> display, but
> > Hope this helps.
> > Phil.
