Switches — Parallax Forums
Switches
edited 2004-03-03 18:14 in General Discussion
Hello Everyone,
I am having a most difficult time using a simple momentary (normally
open) SPST switch. My code seems to be okay, but I'm starting to
doubt the wiring. I have a one leg of the switch going to the I/O
pin. The other leg of the switch connected to 5V+. I have a 10K
resistor connected from I/O pin to ground. I got the connection out
of the book dealing with the button function.
My Code uses the example in the programming manual on page 250 for
those who use it. The state never changes when I press the button.
If false then it is always false, etc...regardless if the button is
pressed or not on the switch.
Can anyone see the error of my ways?
FS
    edited 2000-12-28 05:02
    Hi FS,
    The button command must be in a loop; does your code do this?
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Wednesday, December 27, 2000 11:46 PM
    Subject: [noparse][[/noparse]basicstamps] Switches
    > Hello Everyone,
    > Thanks,
    > FS
    edited 2000-12-28 05:04
    Yes it is in a loop.
    Loop:
    Button .....
    condition code
    goto Loop
    BranchLine:
    condition code ....
    FS
    --- In basicstamps@egroups.com, "Ray McArthur" <rjmca@u...> wrote:
    > Hi FS,
    > Ray McArthur
    > From: <Forbesits@y...>
    > > Hello Everyone,
    (normally
    I/O
    out
    for
    button.
    is
    > > Thanks,
    > > FS
    edited 2000-12-28 05:12
    FS, (funny name, do you have a normal one?)
    Why don't you post your actual code so we can look it over.
    Tim
    [noparse][[/noparse]Denver, CO]
    > Hi,
    > Loop:
    > Button .....
    > condition code
    > goto Loop
    > BranchLine:
    > condition code ....
    > Thanks,
    > FS
    edited 2000-12-28 05:16
    How about posting your code? I'll bet someone on this list will find the
    error, if their is one.
    Good luck,
    Ray McArthur
    Sent: Thursday, December 28, 2000 12:04 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Switches
    > Hi,
    > Loop:
    > Button .....
    > condition code
    > goto Loop
    > BranchLine:
    > condition code ....
    > Thanks,
    > FS
    > > Hi FS,
    > > Ray McArthur
    > > > Hello Everyone,
    > (normally
    > I/O
    > out
    > for
    > button.
    edited 2000-12-28 05:50
    > Loop:
    > Button .....
    > condition code
    > goto Loop
    > BranchLine:
    > condition code ....
    Verify the wiring with a simple loop program:
    loop:
    debug bin1 in0 ' if connected to P0
    goto loop
    Should show 1's only while the switch is pressed, otherwise 0's. It
    is easy to refer to the wrong pin number. The button command adds
    complexity that can mask simple problems.
    good luck,
    --- Tracy
    edited 2000-12-28 15:06
    Here is my code: (The state never changes)
    btnWk var byte
    btnWk = 0
    Loop:
    BUTTON 7,0,255,250,btnWk,0,noPress
    debug "* "
    noPress: goto loop
    Before using the button command I used a loop like this:
    The state never changed.
    Loop:
    debug bin in7,cr
    goto Loop
    out
    > > Loop:
    > > Button .....
    > > condition code
    > > goto Loop
    > > BranchLine:
    > > condition code ....
    > loop:
    > goto loop
    It
    > good luck,
    > --- Tracy
    edited 2000-12-28 21:28
    >Loop:
    > debug bin in7,cr
    >goto Loop
    What state does it indicate, 1 or 0?
    If you have a voltmeter, verify that the voltage on P7 does in fact
    change from zero to +5 volts.
    N.O. switch
    P7
    o----//---- Vdd=5 volts
    '---/\/\--- Vss=0 volts
    10kohm
    Are you sure that the pushbutton and the resistor are connected to P7
    and to the power supplies? Wiring errors are too easy!
    Are the legs of the switch are connected correctly? Some pushbuttons
    have 4 legs, and it is quite easy to mistake which ones to use.
    Are you sure that P7 is configured as an input? (it will be an input
    by default when the BS2 is reset)
    input 7
    loop:
    debug bin in7
    goto loop
    good luck
    -- Tracy
    http://www.emesystems.com/BS2fsm.htm <-- more info on button command
    edited 2000-12-28 23:15
    On 29 Dec 00 at 13:40, Forbesits@y... wrote:
    > Hello,
    > input 7
    > Loop:
    > debug bin in7,CR
    > goto Loop
    > Actually, the state reports mostly ones, but it is sometimes erratic
    > and reports a mixture of 1's and 0's.
    This is usually a pretty clear indication that your input pin is
    "floating" i.e., not being driven to a high or low logic level,
    probably because the pin is not connected to anything.
    Let's review some basics. Your Stamp has 28 pins, including 16 I/O
    pins. If you orient your Stamp so that the largest chip is to
    the right, then I/O #7 is at the extreme right of the 14 pins on the
    bottom.
    It looks like you have good power and ground to the Stamp or it
    wouldn't be accepting your programs and sending DEBUG data back.
    With the program you have shown above, try this simple test. Take a
    wire and carefully touch one end to physical pin #4 (fourth from the
    left on the the bottom row). Touch the other end to I/O #7. This
    creates a direct path to ground (a "low" logic level) for that I/O
    pin. You should see the DEBUG display indicating zeroes whenever
    the wire connection is made.
    When you have this working, connect your resistor between I/O #7
    and physical pin #21 (fourth from the left on the top row). This
    connects the I/O pin to a "high" logic level. In this case, you
    should see ones on the DEBUG screen when the connection is made.
    When you have this working, leave the resistor connected as above
    and use your wire again to make momentary contacts between I/O #7 and
    ground on physical pin #4. This configuration causes the I/O pin to
    see a default high logic level through the resistor, but a low logic
    level if the wire connection is made. In essence you are doing with
    the wire what the switch would do if it's working right. The DEBUG
    display should show solid ones when the wire is not connected, and
    solid zeroes when it is.
    Finally, substitute your switch for the wire. If the wire worked
    OK but the switch doesn't you probably have a bum switch.
    Steve
    edited 2000-12-29 13:40
    Hello,
    input 7
    Loop:
    debug bin in7,CR
    goto Loop
    and reports a mixture of 1's and 0's. Pressing the button has no
    effect :-(
    The voltmeter did reflect some light. The voltage went from 0 to 4.8
    volts. I used a smaller resistor other than the 10K one but still to
    no effect. The voltage was up to 5V. I stopped using the stamps
    power source and used a seperate power source and still no effect. I
    even changed to a different switch button. (By the way, the button
    has only two legs.)
    I've been working on this a long time and I'm at the point of giving
    up for a while because something so simple should not be so hard.
    Before I do, below I have described again my wiring. Hopefully
    there's a simple error there.
    Here's a breadboard illustration incase I am not interpreting the
    schematics correctly:
    _______ ______ ______
    row 1 | | | _|_ | _|_
    row 2 I/O pin _|_ _|_ _|_ 5V _|_ GND
    > >Loop:
    > > debug bin in7,cr
    > >goto Loop
    > N.O. switch
    > P7
    > 10kohm
    P7
    pushbuttons
    input
    > input 7
    > loop:
    > debug bin in7
    > goto loop
    > good luck
    > -- Tracy
    command
    edited 2000-12-29 17:44
    >input 7
    >Loop:
    > debug bin in7,CR
    >goto Loop
    >effect :-(
    As Steve P. pointed out, the erratic response indicates that the pin
    is open, not connected to anything.
    >volts.
    That is a good sign!
    Where did you probe the (+) voltage? Do it right on the Stamp pin.
    Logical P7 is actually pin 12 of the 24-pin BS2 carrier. Or as
    Steve said, it is also physical pin 14 on the SX28 chip that is
    mounted on top of the carrier. I guess I should ask, are you using
    the 24 pin BS2 module--and what breadboard?
    I do not quite understand this diagram. Which line is which part?
    The real test is the voltage probed at the I/O pin, pin 12 on the
    physical carrier board for logical P7.
    -- Tracy Allen
    I have a basic on/off switch thats normaly off. I am wiring it to
    work with a basic stamp revb that will control when a servo will move.
    I got it to work with a switch like the reset button.
    When i wire the other the servo just moves back and forth constaly.
    Can someone help??
    reopeadres@y...
