Multiplexing (?)
On 26 Dec 00 at 18:25, Yanroy wrote:
> Is it possible to put more than one I/O device on a pin for a
> BS2/2sx?
Yes.
> If so, how do you do it (or could you point me to a tutorial).
It would depend to a very great extent on the devices involved. If
you would be more explicit regarding what it is you want to do, your
chances of getting a useful answer are bound to improve.
> I read that the new stamp has support for one-wire devices, is
> that what I am talking about?
The 1-Wire bus is designed to accomodate several 1-Wire devices via
one I/O path. However, running multiple 1-Wire devices off one
BS2SX+ I/O pin may offer some daunting programming challenges
depending on how you would access the devices. Again, it depends on
what you mean to do...
Steve
> BS2/2sx?
Yes.
Steve
think this is called multiplexing, but I am not sure. If so, how do you do
it (or could you point me to a tutorial). I read that the new stamp has
support for one-wire devices, is that what I am talking about? I don't feel
like waiting and then spending a lot more money to get the new stamp if I
can do it with my current BS2.
______________________________________________
FREE Personalized Email at Mail.com
Sign up at http://www.mail.com/?sr=signup
writes:
think this is called multiplexing, but I am not sure. ·If so, how do you do
it (or could you point me to a tutorial). ·I read that the new stamp has
support for one-wire devices, is that what I am talking about? ·I don't feel
You CAN'T do 1-Wire with the current Stamp (BS2, BS2e, BS2sx) and doing I2C
and parallel LCD I/O takes a lot of work. ·The BS2p is definitely worth the
money and will become the default Stamp for my Nuts & Volts column.
-- Jon Williams
-- Dallas, TX
[/font]
parkiss@earthlink.net writes:
one I/O path. ·However, running multiple 1-Wire devices off one
depending on how you would access the devices. ·Again, it depends on
It's not too tough. ·Yes, you have to send the 10-byte ROM ID, but the
structure of OWOUT makes it pretty easy. ·Here's a snippet (the ROM patterns
for known devices are stored in DATA statements):
GetTemp:
·FOR idx = 0 TO 7 ' load ROM pattern
···READ (eeAddr+idx),romData(idx)
·NEXT
·OWOUT DS1820pin,OW_FERst,[noparse][[/noparse]MatchROM,STR romData\8,ConvertTemp]
WaitForConversion:
·PAUSE 25
·OWIN DS1820pin,OW_BitMode,[noparse][[/noparse]tempIn]
·IF tempIn = 0 THEN WaitForConversion
·OWOUT DS1820pin,OW_FERst,[noparse][[/noparse]MatchROM,STR romData\8,ReadScratch]
·OWIN ·DS1820pin,OW_BERst,[noparse][[/noparse]tInLow,tInHigh]
-- Jon Williams
-- Dallas, TX
[/font]
If you simply need more than 16 I/O pins, you may use the 74HC165 and/or the
74HC595 to add respectively input and/or output.
They are shift registers. The 165 is a parallel in - serial out register,
and the 595 is a serial in - parallel out register. They both are
cascadable, so you can add a lot of I/O pins, if your process is not too
fast (serial in and out require time...). You only need 4 or 5 Stamp lines
to manage 8 more inputs AND 8 more outputs.
Let me know if this is what you need. I'll let you know more of my own
experience about that.
Best regards,
Phil.
Subject: [noparse][[/noparse]basicstamps] Multiplexing (?)
> Is it possible to put more than one I/O device on a pin for a BS2/2sx? I
do
feel
