Ack!! Why won''t this thin download (help quick plesase!...
[font=arial,helvetica]Which board are you using for the BS2? ·I had the same problem with a new
INEX board, and found that the solder joints for the BS2 were "COLD" ie: not
connected. ·The connections in my case were the ones which interface with the
serial port. ·Try to check continuity from the BS2 socket to the serial port.
·Maybe you have the same condition that I had. Rob, fiveslo@aol.com[/font]
