timing problem
Here's one for timing gurus:
I need a 38.5 kHz clock for a subsystem that a BSII is controlling. While
the Stamp is running a very simple program, can I use it to also generate
reliable clock pulses at the above rate? What considerations are there, and
what tolerance on the rate can I expect?
Thanks in advance?
Chris Loiacono
Thanks in advance?
Chris Loiacono
without having to make pot adjustments.
Besides, the 555 is pretty sensitive to temperature, no?
> From: Elmer Bataitis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uaPUqkoVrHYptEQs3gm3KG90mj10o_F56FfJZzTZm42tuupriWkBcRHRfFdo4jdbbs1Djq_byGC28c3QQjc]elmerbataitis@y...[/url
> Sent: Friday, December 22, 2000 4:18 PM
> To: chris01@t...
> Subject: Re: [noparse][[/noparse]basicstamps] timing problem
> --- "Chris Loiacono (E-mail)"
> > Thanks in advance?
> > Chris Loiacono
> The stamp prolly isn't the solution. A 555 timer is
> your best bet. Check some the solutions and stamp
> timing info here:
> http://www.emesys.com/BS2index.htm
> The BS2 is probably not the thing to use. A 555 timer
> chip is the best here.
> __________________________________________________
> Do You Yahoo!?
> Yahoo! Shopping - Thousands of Stores. Millions of Products.
> http://shopping.yahoo.com/
