RS232 multidrop
Hi all,
I have seen many emails rergarding multiple stamps on one rs232
line. i have seen a cool implementantion of this. In nutshell this is
how it works
each node on the bus has a unique address above decimal 127 the
processor in each node(box) listens to its rs232 recive line for its
address. if it's address comes allong the bus it enables it's rs232
transmitter (some boxes even uses a relay to connect it's rs232
transmitter to the bus. the bus is normally in the highz state where
no rs232 transmitters are connected to the bus) and transfers it's
data with host the only thing is if you need to send data that has a
decimal value greater then 127 from the host to the controlled box
you will have to send the data as two bytes the first byte with most
signifgant bit turned off and then the least signifgant bit of the
second byte turned on (acting as the most sigfigant bit of the first
byte). when the box and the host are done with their data transfer
the box disables it's rs232 transmitter and then the whole thing can
start again.
This might not make any sense to anybody but i can answer some
questions(very busy) privatly or on the list.
All you guys have great and merry Christmas,
Michael Fowler
mikef@l...
Lectrosonics, Inc
581 Laser Road, Rio Rancho, NM 87124 USA
PO Box 15900, Rio Rancho, NM 87174 USA
fax (505) 892-6243 - tel (505) 892-4501
toll free phone in USA and Canada (800) 821-1121
www.lectrosonics.com
how it works
start again.
Michael Fowler
mikef@l...
Lectrosonics, Inc
> From: "Michael Fowler" <mikef@l...>
> Subject: RS232 multidrop
> Hi all,
> on one rs232
> In nutshell this is
> how it works
> decimal 127 the
> recive line for its
> enables it's rs232
> it's rs232
> highz state where
> transfers it's
> data that has a
> controlled box
> bit of the first
> their data transfer
> whole thing can
> start again.
> answer some
With the RS-232 outputs tied together, from what I see
in the schematic, as long as you don't xmit from one
of the outputs it is in a hi-z state.
I run a loop something like this (psudocode):
Wait_For_Select:
' the first stamp is A, subsequent
' stamps are B, C, etc.
serin s_in, baudrate, [noparse][[/noparse]w2]
if [noparse][[/noparse]w2] = "A" then Select_Me
goto Wait_For_Select
Select_Me
' routine to do whatever needs
' to be done, including all i/o.
' then just return to above loop
I've used this successfully with 5V open-drain rs-232
from the regular i/o pins. I'm expecting it to work
when I connect the rs-232 pins together as well.
__________________________________________________
Do You Yahoo!?
Yahoo! Shopping - Thousands of Stores. Millions of Products.
http://shopping.yahoo.com/
