PIR
Archiver
Anyone know of anyone who's interfaced a PIR
motion detector to a Stamp? Thanks
Bob Williams
Bob Williams
--Dan
To: basicstamps@egroups.com
Sent: December 20, 2000 7:09 AM
Subject: [noparse][[/noparse]basicstamps] PIR
Bob Williams
BW
interfaced to the BS2..
Any Suggestions
> I'm looking for a Passive infrared detector that can easily be
> Any Suggestions
Sorry I don't have the exact URL handy, but plug "Jesse's
hunting" into your search engine. You're looking for a site
called "Jesse's Hunting Page" I believe. There's some great tips
on hacking PIRs to make game cams. The hacks are pretty easy
and could be interfaced to the stamp easily (haven't done it yet
myself though).
Michael
The rate at which Iraq is sucking up tax dollars...
$158,000 per _MINUTE_.
You can try the ADEMCO 998 PIR... this Pir has a look down feature which
make it great for over a door way
>Any Suggestions
>Rus -
Here is a PIR module (without lenses) that I've been meaning to try. It
appears
as though interfacing it to a Stamp should be a simple matter:
http://www.mpja.com/directview.asp?product=7860+KT
Lenses for this unit are available separately on the same web site.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
yourself.
> appears
>Any Suggestions
Three-pin PIR detector ICs put out a small voltage signal in response
to heat that has to be amplified to give a usable signal. As others
have said, you might be best off with one of the prefab security
modules that you can buy for cheap in almost any home or hardware
store, and hack into the alarm or relay circuit to bring the signal
into your stamp. It is not too hard to amplify the IC output,
though, if you do have some special application that precludes the
modules. PIR ICs are often available from surplus houses.
-- Tracy
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=PIR-
2&type=store
> >Any Suggestions
> >Rus -
Mike DeMetz N9GEZ
Elkhart, IN
mailto:n9gez@q...
http://www.qsl.net/n9gez
building for this Halloween.. Cheap ($4.75) and works great! [noparse]:)[/noparse]
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=PIR-2&ty\
pe=store
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
http://www.txis.com | is up, then we obviously don't need
Austin Office 512 328-8947 | you, so why are we paying you?" VLG
> Any Suggestions
