Humidity Sensor
Archiver
Fritz-
This may be too long for you to wait, but the following device is
supposed to be available in April:
http://www.ibutton.com/weather/humidity.html
It looks like it'll be pretty slick--RH, temp, light measurements in
one pkg.
More info on 1-Wire weather devices and other humidity sensor
options currently available:
http://www.ibutton.com/weather/#humidity
Steve
On Tue, 19 Dec 2000, Fritz Braun wrote:
> Can anyone recommend a ( or various) humidity sensor(s) for a
> project that I will be working on after the holidays?
one pkg.
Steve
I've done an internet search and came up blank.
Fritz
[noparse][[/noparse]basicstamps] Humidity Sensor:
>Can anyone recommend a ( or various) humidity sensor(s) for a project that
take your search to http://www.google.com and STAND BACK. It's fast
and quite thorough.
I just got beau coup hits on the two words 'humidity sensor'.
good luck
(I don't have a specific recommendation, but when we were ripping
apart some old microwave ovens, we came across one that HAD a
humidity sensor in it. (a four terminal bridge sensor)
\ / \ / \ N / \ C / \ S / \ S / \ M / \ / \ /
Chuck Britton Education is what is left when
britton@n... you have forgotten everything
North Carolina School of Science & Math you learned in school.
(919) 286-3366 x224 Albert Einstein, 1936
Hih-3605-A (Honeywell).
-Not cheap ($31), but is very easy to use and reliable.
-Linear analog output, you can use any ADC with the stamp to take
a reading.
There are many others, some of them cheaper, but I have
used these quite a bit with success.
Have a nice evening,
Paul
> Thanks
> Fritz
Tanks for the information. Do you know where I can purchase these?
Fritz
To: <basicstamps@egroups.com>
Sent: Tuesday, December 19, 2000 11:13 PM
Subject: Re: [noparse][[/noparse]basicstamps] Humidity Sensor
> Hi Fritz,
> a reading.
> Paul
that
> > Thanks
> > Fritz
www.newark.com
You may want to wait for others' responses, there may be a cheaper
alternative.
Paul
> Paul:
> Fritz
> From: "Paul J. Csonka" <csonka@e...>
> > Hi Fritz,
> > a reading.
> > Paul
> that
> > > Thanks
> > > Fritz
Here is a link to the sensors page at Honeywell/Microswitch.
http://content.honeywell.com/sensing/products/sensors/
This includes the HIH3605, the new HIH3610, and the premium HIH3602.
These are available from
http://www.newark.com/
and from some other Honeywell distributors like Steven Engineering.
Be sure to pay attention to the data sheet, about light sensitivity.
The Vernier RH probe uses the HIH3602L, and comes in a nice package:
http://www.vernier.com/probes/rh.html
I use the premium HIH3602C in my humidity sensors, which include a
built-in RTD for temperature compensation and dew point calculation:
http://www.emesystems.com/RHTD_DAT.HTM
Here is another one that might be of interest to you. I think this
is the one that Matt Parnell uses in the weatherstamp station:
http://www.columbia-center.org/fascinating/obs/instrmnt.html
http://www.weatherstamp.com/
best regards,
Tracy Allen
>Paul:
>a reading.
>Paul
> > Thanks
> > Fritz
the small ceramic sensor, normally glued in a small steel plate. The
sensor itself is a plate about 1/4" x1/4" with two wires . It changes
resistance.
I don't know nothing about sensivity and linearity.
ACJacques
> Thanks
> Fritz
This is a different Paul. You can order them from Newark. Also try
contacting Honeywell. You can order samples.
Paul, not the first, just a different one
Does anyone know a humidity sensor for atmosphere use to measure RH
with a BS2
Roberto
https://store.ibutton.com/cgi-bin/ncommerce3/CategoryDisplay?cgrfnbr=809&cgmenbr\
=776&cg=809
Roberto Gomez wrote:
> Hi all:
> with a BS2
> Roberto
pls resend
--- Scott Tappan Contractor
<scott.tappan.contractor@n...> wrote:
> look at
=776&cg=809
> > Hi all:
> > with a BS2
> > Roberto
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
best regards,
Tracy Allen
>From: "Roberto Gomez" <robby@a...>
>Reply-To: basicstamps@yahoogroups.com
>To: <basicstamps@yahoogroups.com>
>Subject: [noparse][[/noparse]basicstamps] Humidity sensor
>Date: Tue, 3 Apr 2001 10:02:05 -0300
>Hi all:
>RH
>with a BS2
>Roberto
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
>with a BS2
>Roberto
Hola Roberto,
Basic sensor elements are based on either resistance or capacitance
transduction, and require a circuit like the 555 timer (Mediciones
Ambientales, chapter 5) to provide AC excitation or transduction to
frequency that can be read by the Stamp.
There are also sensors that output a voltage directly that can be
read by an analog to digital converter.
What environment will the sensor be exposed to, and what accuracy do
you require? That is the big question with humidity sensors. The
cost is related to the accuracy, range, environmental compatibility,
and longevity.
-- regards,
Tracy Allen
I want to thank to all for the help gave me with the humidity
sensor. It has been of a lot of utility.
Roberto
from
radiosondes. Electronic Goldmine used to carry these, but if you check
around different surplus places, you might have some luck. These are not as
rugged as you might think, but they are very easy to read.
Al Williams
AWC
*NEW: PAK-IX Floating Point A/D (5 channels/10 bits):
http://www.al-williams.com/awce/pak9.htm
> From: Roberto Gomez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uBufVC_h9_vUTbL1pOUM9I9uLxCzuXn1H0v92OwGmi_KkxjqYe7495d9jUF8w9JxzUsSDMq3pI4ffppt7Rg]robby@a...[/url
> Sent: Wednesday, April 04, 2001 7:58 AM
> Subject: [noparse][[/noparse]basicstamps] RE Humidity sensor
> At all:
> Roberto
[noparse][[/noparse]basicstamps] RE Humidity sensor:
>We used to get hygristors (humidity-sensitive resistor) that were surplus
>from
>Regards,
>Al Williams
hmm, good source for such things, Any words on how quickly
they respond? These are 'disposable' radiosondes aren't they. Will
they 'wear' well undercover but outside? Will the humidity sensors in
electric clothes dryers work also? THESE sensors have been known to
get flaky. Maybe when coated with antistatic goop?
same problem to find it.
God look
-Bruno-
Mensaje original
De: Roberto Gomez <robby@a...>
Para: <basicstamps@yahoogroups.com>
Enviado: Martes, 03 de Abril de 2001 03:02 p.m.
Asunto: [noparse][[/noparse]basicstamps] Humidity sensor
> Hi all:
RH
> with a BS2
> Roberto
looking for an accurate sensor to monitor humidity levels in an
incubator for reptile eggs. I would like to find one that is easily
connected to a BSII. Any suggestions???
Stampboi
monitor the humidity in a reptile incubator. The sensor should be
accurate, and easily attached to a BSII.
Any Ideas???
Stampboi
easily wired to a BSII.
Any suggestions?
Stampboi
>Stampboi
1) The Honeywell/MicroSwitch sensors are used with an analog to
digital converter:
http://content.honeywell.com/sensing/prodinfo/humiditymoisture/
http://www.emesystems.com/rhtd_dat.htm
The can be obtained with good calibration data, and the second
reference has information on using them with the BS2.
2) General Eastern has several different humidity products, optimized
for different environments:
http://www.geinet.com/html/HumidityTop.asp
3) Panametrics Minicap II capacitive sensor can be used in 555
circuit to give period proportional to humidity.
http://www.panametrics.com/div_pci/pages/products/rehumidity/minicap2.shtml
-- regards,
Tracy Allen
mailto:tracy@e...
www.humirel.com.
-dave
Bring on the revolution, as long as it involves patio furniture (Moby)
dave paton http://www.dpaton.net dave at ieee dot org
I have used Vaisala units to monitor humidity for years. Very good units, but I
have not tried interfacing them
with stamp yet.
Here is the URL on them.
http://www.vaisala.com/thumbnail.asp?Section=5481
Good luck
stampboi wrote:
> Does anyone have any experience with this type of sensor? I am
> Stampboi
