sound detection
hello stampers!
I want that my robot reacts at sound, when i clap my hands my robot should
start moving. What kind of hardware do i need, and how to connect it to a
bs2? a simple microfoon gives very few power to trigger a input pin on the
bs2....
many thanks
pieter-jan
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
bs2....
many thanks
pieter-jan
I want that my robot reacts at sound, when i clap my hands/ or make a
loud sound my robot should start moving. What kind of hardware do i
on the
bs2....
many thanks
pieter-jan
>hello stampers!
>on the
>bs2....
>many thanks
>pieter-jan
Hi pieter-jan
The following was offered by S. Premna earlier this month (12-10-2000):
QUOTE
Subject: [noparse][[/noparse]basicstamps] Re: help in design for sound
Whereas this problem is not trivial you could give it
a good start by taking two identical mics and housing
[noparse][[/noparse]as close as possible!] and put the outputs to a
differential amplifier [noparse][[/noparse]op amp connected differentially
with same input impedance per side - or 3 amplifier
instrumentation amp configuration].
You need a preamplifier for each microphone before you
go to the differential amplifier...
Now the diff amp output will be large when the two mics
are not the same input sound... gives you "off center"
signal.
Which side is less? Feed the outputs of the two microphone
preamplifiers also to two rectifiers and look for
which signal is larger [noparse][[/noparse]another diff amp, or comparator]
The audio differential amplifier could also give this
information on it's output but my intuition is that it
would be harder to discern...
Considering the large likely dynamic range of audio input
you may need automatic gain controls etc.... but I'd
give it a try with the preamps, rectifiers, comparator
and differential amp.
Why not just the preamps and rectifiers? Well, the diff
amp could give you a degree of off center reading harder
to extract with a comparator. Remember the two channels
must be as identical as possible and then put in a balance
pot somewhere to trim things out... [noparse][[/noparse]change one preamp
gain should work...]
Hope this is a thought provoking start for you - I apologise
it isn't a simple complete solution.
Good luck - let us know how it works out... premena [noparse][[/noparse]ARS AJ0J]
PS Don't forget to isolate robot motor sounds from your
microphones or locate the microphones symmetrically
with the mics ... :-) You may need to restrict the mic
bandwidth of frequencies you listen for with some bandpass
filtering [noparse][[/noparse]identical per channel].
End QUOTE
Hope that gets you started
This topic was discussed here in the recent past.
I think we ended up saying that a mic preamp would be necessary, followed
by a dual comparator circuit to convert the audio waveform to a logic
signal. The comparator could be an LM393 type, and the hookup is pretty
well documented in National's data sheet. You would operate the comparator
on 5V power, with the first stage allowing a capacitor to charge when sound
is present, and the second stage performing the conversion to a logic
signal. The capacitor insures that your logic signal lasts long enough for
the Stamp to detect it.
It's possible that the mic preamp could be eliminated by biasing the first
comparator very carefully, if your mic has a lot of output voltage when the
clap hits it. Old-fashioned ceramic mics often work best for this job...
>bs2....
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
does anyone know an easy way to detect sound using the BasicStamp? I would
need a rather sensitive device that is able to detect a mumbling person in a
distance of about 30 cm...
I am building a pseudo-brainwave-measuring-helmet and therefore I want to
detect sound, to see if the person is quiet, and movement.
That leads to my second question:
Is there a way to detect motion of a head under a spherical 'hood' without
engaging complicated stuff like ultrasonics or similar? Can I build a huge
capacitor (two plates of metal on either side opf the head) and detect the
capacitive difference when the head moves?
What am I doing here in this job? How crazy is someone who builds a
pseudo-brainwave-measureing-device ?
Have a nice day you all,
uli
There was a thread about sound detection a while back. I'd just get a good
mic, amplify it, and then use a comparator to detect the level going above a
pot reference (so I could adjust the sensitivity).
Have you considered mercury switches in the helmet? That would seem to be
the simple solution. Pin ball machines and similar devices have (used to
have?) tilt sensors. These were large ball bearings held captive on a track
with microswitches at either end. When the ball hit the microswitch you
tilted the machine.
Another idea would be to use a cheap PIR motion detector behind the person?
Al Williams
AWC
* Connect RS232 devices quick and easy:
http://www.al-williams.com/awce/rs1.htm
> From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lKpkfJocaYGpLxN1xsCpNuAM9qMetT6p5YfJFc4Rq-pFrIp9G-aSVYmMO_rIBgMtqcRCEhZv4K0_rW2jLtKxDq200tU3n_mY48yQ0zA]ulibasic@r...[/url
> Sent: Thursday, August 02, 2001 7:08 AM
> Subject: [noparse][[/noparse]basicstamps] sound detection
> Hi Stampers,
> person in a
> uli
> from the same email address that you subscribed. Text in the
Sorry I can't offer anything constructive - other than how about using a
gyro ?
Good Luck !
Justin.
From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qyNjZf_HmKEXpneS3mkmcoGwRsdvcai_I7oX3ax87BKAfghi9KSot9AYUp09rqrA5GZOKkaeH4eH2gsaZNS8D_vBgtBYd0XL3Q]ulibasic@r...[/url
Sent: 02 August 2001 13:08
Hi Stampers,
[noparse][[/noparse]SNIP]
[noparse][[/noparse]/SNIP]
2 cents.
Probably the easiest way to do what Al suggests is to connect a
inexpensive dynamic microphone into a LM386. The '386 is intended to
be a power amplifier, to drive a loudspeaker with a line level input.
The LM386 will also function as a preamp. It will be a bit noisy, but
you dont care about this. Connect the microphone to the '386 input.
(if I recall correctly no cap is required at the input) I believe to
increase the gain of the 386 a cap goes between 2 pins. Again, go to
Yahoo and search on LM386, you'll have all the info you'll need.
Anyway, the LM386, with the cap for max gain, will work just fine as
your mic preamp. Very few parts required so far, the mic, the 386, an
output cap, and one other small cap. The data sheet will probably
suggest a snubber on the output, a good idea.
The output of the 386 goes through a diode, from there it goes to a
comparator input, just as Al suggested. A small cap to ground at this
point will add a bit of delay, (prevent false trigger) and will
stretch the comparators output pulse just a bit.
I have used the LM339 comparator in similar applications. Works well,
and is dirt cheap, as is the LM386.
Can't help you with the helmet thingy, I would be curious to know
what you come up with. Al suggested a tilt switch, good idea...
Regards
Rich
--- In basicstamps@y..., "ulibasic" <ulibasic@r...> wrote:
> Hi Al,
> thanks for reply, I didn't explain good enough what this is all
about, sorry
> for my poor language...
> It is not really a helmet, it is more like a hood that will be
fixed and the
> person just put his /her head under the hood, without contact.
(Like the
> strange thjings old ladies use to dry their hair...).
> The problem with pid-devices is that they can only say yes, it
moves or no,
> it doesnot. I would prefer a device that can tell me how quick or
how much
> or how far the head moves.
> Could you go a lil more into detail about the microphone thing?
What kind of
> mic can I use, how do I amplify it and what would this comparator
look like,
> just an op-amp?
> You see, I am not very cool in electronix though I fumble my way
along this
> world for ten years now...;-)
> Thanx again, Al,
> Greetings, Uli
Urspr
Just what Rich said. The LM386 is a staple -- very nice AF amp with
practically no way to mess it up. Then you have a voltage at the output. You
might want to "filter" it with an RC so you'd need some sustained level, but
that will depend on exactly what you want to do.
As Rich points out, you'll probably want to rectify the output with a common
diode so you only get the positive excursions. A 339 comparator is so
versitile that we include one with our lab kit -- would you belive a 339, a
resistor, and a capacitor can make a 4 channel A/D converter for the Stamp?
Yep.
One trick to using the 339 that many people overlook. The output is open
collector. That is to say it goes to ground in one state and floats in the
other. A pull up resistor will take care of that.
As for the "hood" thing, I don't know. I'd be wary of making people's heads
into a dielectric. Beau can shed some light, but I know that electricity and
people take special care. How about a ring of IR LEDs and sensors. You turn
on an LED and "see" which sensors can see it. Then turn it off and turn on
another one. You could triangulate the position of the head pretty well that
way I'd think.
Al Williams
AWC
* Connect your Stamp to the Internet!
http://www.al-williams.com/awce/netporter.htm
> From: ulibasic [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zAFT8_PYnHU54WLZtuim5xh2MXYI7La8XMGCKRUbgDMis3i_GiLnx29b8dMa4pnHe2-NLzQnARVoIHLPjsZXTRhj_Tol778D3A]ulibasic@r...[/url
> Sent: Thursday, August 02, 2001 7:38 AM
> Subject: AW: [noparse][[/noparse]basicstamps] sound detection
> Hi Al,
> about, sorry
> fixed and the
> person just put his /her head under the hood, without contact. (Like the
> moves or no,
> it doesnot. I would prefer a device that can tell me how quick or how much
> What kind of
> look like,
> just an op-amp?
> along this
> Thanx again, Al,
> Greetings, Uli
Urspr
Uli,
This ought to do it. It's a Design Idea from EDN Magazine, November 6, 1997:
http://archives.e-insite.net/archives/ednmag/reg/1997/110697/23di_04.htm
Hi Uli,
I have experimented with simple op-amp circuits to integrate small
voltages so that they can be sensed for magnitude using the RCtime
command. A couple of these circuits both integrate and rectify in
one step, so they are useful for sensing analog sound level. Here is
the URL:
http://www.emesystems.com/BS2rct.htm#SmallV
The ones that rectify and integrate are toward the bottom of the article.
>It is not really a helmet, it is more like a hood that will be fixed and the
>The problem with pid-devices is that they can only say yes, it moves or no,
Maybe the Analog Infra-Red Range-finding System (AIRRS) would help?
http://www.hvwtech.com/sensors.htm
-- regards,
Tracy Allen
mailto:tracy@e...
head is a pretty good IR source after all. I'm thinking like a motion
detector where a single IR detector detects variation in IR level,
except in this case you might want several. You could use lenses or
some other method to narrow their field of view if desired. You could
use horizontal and vertical slits in front of the detectors to
separate horizontal from vertical motion. Feed the output of each
detector into a circuit like the soud detector and then use the Stamp
to sample the activity level of each one.
> Hi Al,
> thanx again for your detailed explanation. I like the IR-idea for
the hood.
> But there is one thing missing: the explanations by "Rich" that you
refer to
> never reached me... Did he post it in the group? I cannot find it...
> Could you forward it?
> Thanx and Hi Ho,
> Uli
Urspr
