connecting a 7-segement led to BS
You might try connecting the display to a 7447 driver, using only 3 basic
stamp lines to drive it. Check out
http://www.hcc.hawaii.edu/~richardi/113/c113_2f/2f_2/2f2.htm for more
general display info. You should be able to leave the DP unconnected if you
don't need a decimal point. Using the driver, you simply input a the binary
equivalent of the decimal number you wish to display.
To: <basicstamps@egroups.com>
Sent: Monday, December 18, 2000 3:28 PM
Subject: [noparse][[/noparse]basicstamps] connecting a 7-segement led to BS
> Hi every one,
> I want to display keypad presses on a 7-segment (one digit) led.
> I don't want to use any additional chips and I want to connect
> the
> led directly to the basic stamp
> I already wrote the keypad-scanning program on the basic stamp 2 and
> it's working properly.
> I don't know what to do with the led though!
> The pins on the led are as follows:
> Pinout:
> Pin 1: ................ Anode F
> Pin 2: ................ Anode G
> Pin 3: ................ N/C
> Pin 4: ................ Common Cathode
> Pin 5: ................ N/C
> Pin 6: ................ Anode E
> Pin 7: ................ Anode D
> Pin 8: ................ Anode C
> Pin 9: ................ RHDP (Right Hand Decimal Point)
> Pin 10: ............... N/C
> Pin 11: ............... N/C
> Pin 12: ............... Common Cathode
> Pin 13: ............... Anode B
> Pin 14: ............... Anode A
> NOTE: Pins 4 & 12 are internally connected
> All anodes will be connected to the I/O pins of the BS through
> resistors
> Common cathode will be connected to ground
> What about the RHDP pin? Should it be grounded or left floating?
> And I'm not sure how to send data to the anodes using pbasic.
> If anyone has a program or can help, I would appreciate it.
> Hi every one,
> the
> Pinout:
> resistors
Thanks for your reply David, but I don't want to use a driver.
So is it possible to connect the led directly to the BS?
--- In basicstamps@egroups.com, "David Peterson" <robodave1@h...>
basic
more
unconnected if you
the binary
> From: <ohnaf@y...>
> > Hi every one,
> > the
and
> > Pinout:
> > resistors
>Hi all
>More than anything, that will depend on the current it draws, and
>the voltage it requires. Which display chip is it ?
>Bruce Bates
The led that I'm using is from Radioshack and these are some of its
specifications:
Type: ...... S321R
Maximum Volts (forward): ..... 2 V
Reverse Voltage : ...... 5 V
Maximum Amperage (forward): ..... 20 mA
Wavelength: ......660 nM
Brightness: ...... 125 micro candlepower
Material: ....... GaAsP
Power Dissipation: ...... 100 mW
--- In basicstamps@egroups.com, Bruce Bates <bvbates@u...> wrote:
> At 05:43 PM Tuesday 12/19/2000 +0000, you wrote:
> >Hi all
> >Bruce Bates
