servo problems
Archiver
I have a Futaba Servo FP-S3003 a light weight standard servo. I want
to turn this servo into a motor. I already snipped off the black tab
inside of the 2 servos. The servos are not moving when I send them a
current. They are making humming noises. Does anyone have any
suggestions or tips that will make these servos work?
fractal
fractal
shaft. That will turn the pot, which won't do a full revolution. For more
info on hacking this type of servo visit
http://www.gorobotics.net/servohack.shtml
-William
GoRobotics.net
To: <basicstamps@egroups.com>
Sent: Monday, December 18, 2000 8:56 AM
Subject: [noparse][[/noparse]basicstamps] servo problems
> Hi,
> Thanks
> fractal
Just to clarify, the main shaft is the big black gear inside the servo
that the allows the wheel to connect to the servo, Right?
If I do scrape out the "+" from the inside of the main shaft, then
will the servo still be able to turn the main shaft gear? If the "+"
is removed from the inside of the main shaft won't this kill the
servo?
fractal
--- In basicstamps@egroups.com, "William Cox" <william@c...> wrote:
> You will also have to drill out the "+" shaped formation inside the
> main shaft. That will turn the pot, which won't do a full
> revolution. For more info on hacking this type of servo visit
> -William
> GoRobotics.net
> From: fractal <fractal@w...>
> > want to turn this servo into a motor. I already snipped off the
> > black tab inside of the 2 servos. The servos are not moving when
> > I send them a current. They are making humming noises. Does
> > anyone have any suggestions or tips that will make these servos
> > work?
At the bottom of the page is a link to a PDF file for modifying the
servo for continuous operation. I like this document because it shows a
little picture of the "resistor package" that will replace the pot, AND
it is specifically for the S3003.
I'm assuming that when you say "turning it into a motor" that you mean a
motor you can control forward/backward, right? The S3003 has two stop
mechanisms; 1) the tab on the black gear, and 2) the pot itself.
I've modified these servos using the instructions in the document above,
and everything went fine. I did cheat a little by only cutting off the
pot and leaving the legs in place. Then soldering the resistors to the
remaining pot legs, but the theory is the same.
fractal wrote:
> Hi,
> servo?
> Thanks,
> fractal
> > -William
> > GoRobotics.net
> > > work?
