long numbers
Couldn't you use two words and just multiply them together to get the final
product?
-Rob
To: <basicstamps@egroups.com>
Sent: Tuesday, December 12, 2000 10:34 AM
Subject: [noparse][[/noparse]basicstamps] long numbers
> Hi everyone,
> Can anyone tell me how to use long numbers.
> A word can only store a number upto 65535.
> I have designed a machine that requires 2 counters. One that counts
> the number of operations it has completed in this run, which may have
> upto 5 digits i.e. 99999 and the other that may have millions of
> operations i.e. 99,999,999.
> how do i get past the 65535? And how do I store the results in the
> EEprom?
> The project is late and I'm getting hasle from the MD, so any help
> gratefully recieved.
> Regards
> Jon
product?
-Rob
> Hi everyone,
> EEprom?
> Regards
> Jon
EEprom?
Regards
Jon
There are several ways around this:
1) Detect roll over:
x0 var word
x1 var word
tmp var word
x0=0
x1=0
' add 1 to count
tmp=x0
x0=x0+1
if tmp<x0 then noover
x1=x1+1 ' add carry
noover:
' keep going
2) Change your count to a two parter. Count say 100's of operations
ct100 var word
ct var word
ct100=0
ct=0
' add 1 to count
ct=ct+1
if ct<100 then noover
ct100=ct100+(ct/100) ' save 100s part
ct=ct//100 ' get remainder
noover:
This is nice because you can display the result easily:
debug dec ct100, dec2 ct
To store these in EEPROM you have to get the byte in and out:
WRITE 0,ct.lowbyte
WRITE 1,ct.highbyte
WRITE 2,ct100.lowbyte
WRITE 2,ct100.highbyte
Both of these routines could be simplified by checking for a known number
since you are always adding 1, but I wrote them to be more general-purpose
so you could replace the 1 with anything you want. Didn't test them, so be
careful.
Just for a plug, a PAK-I or PAK-II floating point coprocessor handles 24-bit
integers (as floating point numbers) plus you get floating point.
Al Williams
AWC
* NEW: PAK-I now operates at 20MHz! http://www.al-williams.com/awce/pak1.htm
> From: Jonathan Millard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Oxho8qgM_LpMBxNoJMuvWVFEjX7aKT5Xp-tzhiWOiyy5AK4qIqX2BHTSbA_UUXF1XxVC83AOvKgHB-s]jonm@p...[/url
> Sent: Tuesday, December 12, 2000 9:35 AM
> To: basicstamps@egroups.com
> Hi everyone,
> EEprom?
> Regards
> Jon
Similar to what Al suggested, this one counts up to 10000 in the
low word, and then extends the count up to 655350000 in the high word.
x0 var word ' low word of the count
x1 var word ' high word
x0=9990 ' arbitrary starting value
loop:
x0=x0+1//10000 ' up to 9999, then roll to 0
x1=x1 + 1 -(x0 max 1) ' ten-thousands
' note the term in () is =0 only when x0=0, otherwise =1
debug dec x1,dec4 x0,cr
next
-- Tracy Allen
http://www.emesystems.com/BS2math6.htm <-- more double precision math
> > From: Jonathan Millard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZY0Qf3aisUIGpbCtY2x1tpeTbqUjcOdD-HWNtA-U__jOfQphGi0bA-IddNAs-0BRT5s7vS8NH2Ez1A]jonm@p...[/url
> > Hi everyone,
> > EEprom?
> > Regards
> > Jon
