Midi interface
Howdy stampers.
I'm wondering if anyone has built a stamp interface to a MIDI device. I
messed with MIDI programming back in the 80's, so I'm somewhat familiar
with the protocol, but I've never actually built an inteface. I found a
schematic that seems to be a very simple op-amp circuit tagged "TTL to
midi". Has anyone done something like this with a stamp?
Thanks!
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
Thanks!
I'm also interested in this. Concerning MIDI Out, you just need two
resistors....
This web page should answer your question:
http://www.interaccess.org/arg/arg-knowledge/MIDI.BS2
Concerning MIDI IN, you need more circuitry but unfortunately, it's not really
possible with the stamp because there are no interrupts to warn you that new
MIDI data has arrived, and the serial port is unbuffered, so you will loose
information. Even by adding a buffer, I'm not sure it's possible because the
Stamp is too slow...
Tell me if you find something interesting for the MIDI IN....
Nicolas
>>> "Sean T. Lamont .lost." <lamont@a...> 12/10/00 02:34PM >>>
Howdy stampers.
Thanks!
resistors....
I found a spec at http://www.art.net/~troika/schematic.html ;
This seems peculiar because they invert the output (why not just use the
inverted bits?) and use a NPN transistor, but I have no idea why. The
stamp2 should be able to natively do 31.25 kilobaud.
>really possible with the stamp because there are no interrupts to warn
>you that new MIDI data has arrived, and the serial port is unbuffered, so
>you will loose information. Even by adding a buffer, I'm not sure it's
>possible because the Stamp is too slow...
I don't really need it, but it seems to me that the stamp could pull 31
baud data. Especially since a large amount of midi is very low-bandwidth
(note on and off). The only thing which consumes lots of bandwidth is
wheel modulation and timing information. You'd basically have to have a
dedicated stamp to midi in, though.
Check out that schematic...
each other, which is why the schematic at art.net has an optotriac (I
think that's what that is...)
On Mon, 11 Dec 2000, Nicolas Fournel wrote:
> Hi,
resistors....
> Nicolas
> Howdy stampers.
> Thanks!
Yes, this is part of the MIDI spec.
I found the web site below very interesting:
http://devices.sapp.org/program/stamp/
It explains pretty well the speed and buffering problems and you can see a few
nice sample programs.
Nicolas
>>> "Sean T. Lamont .lost." <lamont@a...> 12/11/00 07:42PM >>>
By the way, it's in the midi spec that the devices are optoisolated from
> Hi,
resistors....
> Nicolas
> Howdy stampers.
> Thanks!
optoisolated, it's because musicians end up cabling them together,
potentially with large voltage amounts flowing down it. For a stamp, it
just doesn't matter. As per another schematic , I did it with two 220 ohm
resistors at 31.25 kilobaud, and it worked just fine. I had my stamp
acting as a little drum machine. [noparse]:)[/noparse]
On Tue, 12 Dec 2000, Nicolas Fournel wrote:
> Hi,
> Nicolas
> > Hi,
resistors....
really possible with the stamp because there are no interrupts to warn you that
new MIDI data has arrived, and the serial port is unbuffered, so you will loose
> > Nicolas
> > Howdy stampers.
> > Thanks!
I've recently acquired the pedal board to an old electric organ that
I would like to MIDIfy. I've found a few resources online
(http://www.audiomulch.com/midipic/ mainly) that lead me to believe
this could be done with a BASIC Stamp. I haven't worked with these
before, but I've done some programming and learn relatively fast. I
think this project seems like a good first with the Stamps.
The page I mentioned earlier (http://www.audiomulch.com/midipic/)
talks mainly about creating a MIDI control-signal sending device. I
want to be able to hook up about 26 switches or contacts from the
pedals and send MIDI note on/off info. I might be able to modify the
source code (http://www.interaccess.org/arg/arg-knowledge/MIDI.BS2)
that was provided to work with the switches/contacts I speak of
rather than analog inputs (potentometers, etc) which it currently
does. I could likely work the software end if I could have a little
help hooking up the switches. I know the BASIC Stamp II only has 16
pins, but could I hook up more inputs? There are 26 pedals, and I
would like to utilize them all, if possible. The Stamp II seems the
Stamp most in my working price range, but if it doesn't fit the bill,
I would consider something with more capabilities.
I guess I'm just a little fuzzy about how inputs and such interface
with the pins on the controller and then the software. If anyone has
any advice or expertise they can offer, I would appreciate it. If
anyone has attempted a MIDI pedalboard/keyboard type controller,
their wisdom would be immensely helpful.
Thanks!
~Sam
P.S. I think if this works, I might try to salvage the rest of this
organ... I guess it works fine except some idiotic kids bashed up all
the keys. I was thinking maybe a MIDI-in device so I could run the
thing from an external MIDI keyboard. Maybe something else is in line
there, though.
resources that should help:
http://www.parallax.com/dl/docs/cols/nv/vol4/col/94.pdf
http://www.parallax.com/dl/docs/cols/nv/vol4/col/95.pdf
-- Jon Williams
-- Parallax
From: captaink1234 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mmfkGp5yWP9bUOBKgf_X9i26kVjwgUMJpOkck6ZSzMXJ3qPiHjn8pOU419XAW7chw3fpy4vGt8nNMGGes4Y]captaink1234@y...[/url
Sent: Thursday, March 04, 2004 11:10 PM
Subject: [noparse][[/noparse]basicstamps] MIDI Interface
Hello all,
Thanks!
~Sam
there, though.
with these devices. 9600 is tops for a BS2, it looks like the BS2SX
might do double that. You'll need to go to micro controller that
doesn't do the language interpretation, that usually means learning
assembly or something more difficult than P Basic.
--- captaink1234 <captaink1234@y...> wrote:
> Hello all,
> Thanks!
> ~Sam
> there, though.
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Search - Find what you’re looking for faster
http://search.yahoo.com
Please reference the following url:
http://www.zenchemical.com/burningman/lightwave/
This was a project I put together that was at number of art events ; the
most recently was a little over year ago at the string cheese incident
show in san franscisco. The fundamental basis for it is converting
optical / electrical signals into midi. The conversion boxes are
completely based on BS2.
What I would recommend for the original poster is that he figure out some
way of multiplexing the inputs. (shift registers or something) The midi
output should be very straightforward. For your reference, instead of
using 31.25 kbaud, which is the spec, I had to use "32768" baud on the
BS2. I'm not precisely sure why, but there it is.
On Fri, 5 Mar 2004, John Remington wrote:
> MIDI needs something like 31.8k baud, I don't think you'll get there
> > Hello all,
> > Thanks!
> > ~Sam
> > there, though.
> > Yahoo! Groups Links
> Do you Yahoo!?
> Yahoo! Groups Links
Sean T. Lamont, Chief Mad Scientist |-- lamont@a...
Zen Chemical Productions |-- http://www.zenchemical.com
Fabricators of Unnecessary Amazement
Perhaps one of our competitors.... When in doubt, consult the Help
file. We put it there so you'd have the facts at your fingertips.
The BS2 can handle MIDI with no trouble at all; BASIC Stamps are used by
artists and musicians quite frequently.
-- Jon Williams
-- Dallas Office
From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IflTtZzVr0mfO8UH9W6d3iXi8xt6ztCw-Ujp1remJutFlAq_7AAszNX1TvWWlOW8n5Hx7kCohw]jrem123@y...[/url
Sent: Friday, March 05, 2004 1:45 PM
Subject: Re: [noparse][[/noparse]basicstamps] MIDI Interface
this case. When you're sending data bits out, you're not interpreting any
more, you're (presumably) in a tightly-coded assembler routine to do
serial output, and it would very much surprise me if this were any slower
on a stamp than on an equivalent PIC or assembler-based microcontroller.
baud rate table), not from one of your competitors. I guess I don't
understand what "open baud networking" means. But I'm willing to
listen and learn . . .
--- Jon Williams <jwilliams@p...> wrote:
> Where in the world did you get that 9600 baud is tops for a BS2?
> by
> -- Jon Williams
> -- Dallas Office
> From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UCIBG7-aDa820o7rsbjkIEl8u8pMrVaDTYf7lE8P7jqGwM_tUk33LMjM-SNTkktdfMGo5Vy-h8Zr]jrem123@y...[/url
> Yahoo! Groups Links
Do you Yahoo!?
--- "Sean T. Lamont .lost." <lamont@a...> wrote:
> I would also argue that the 'language' interpretation is irrelevant
> in
> any
> slower
> microcontroller.
> there
> BS2SX
> lamont@a...
> Yahoo! Groups Links
Do you Yahoo!?
key being common. Turn back a few pages to the quick facts table and
you'll see that the BS2 has a baud range of 243 baud to 50 kBaud.
-- Jon Williams
-- Dallas Office
From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G_G570moz1G4mf36A8Za_zfD2LbgUMwPS69y024VHnHtP70d3-IdyqzF2B4oPOrcUDS8TnBfmWR0]jrem123@y...[/url
Sent: Friday, March 05, 2004 7:14 PM
Subject: RE: [noparse][[/noparse]basicstamps] MIDI Interface
I perceived that info from page 297 of the 2.0 ref manual (the serout
understand what "open baud networking" means. But I'm willing to listen
and learn . . .
> by artists and musicians quite frequently.
> -- Jon Williams
> -- Dallas Office
> Yahoo! Groups Links
Do you Yahoo!?
Yahoo! Search - Find what you're looking for faster
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
EEPROM; on the order to 150 microseconds, depending on the Stamp version
and instruction (for those that are interested, Dr. Tracy Allen has done
a study on instruction execution speeds).
Sean was right, however, once SEROUT (or any other PBASIC instruction)
is loaded and running, assembly code is what is doing the work. This is
why instructions like PULSOUT and PULSIN can have a resolution of 2
microseconds -- that would not be possible without assembly code speed.
-- Jon Williams
-- Dallas Office
From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ImCBsClj2Vi2Od6fR0gN4w2ZQoJ78V7Xni2QN-zTdTW95-33JLUYqCAthiVwty5ZIkyr8sscawRddpY]jrem123@y...[/url
Sent: Friday, March 05, 2004 7:17 PM
then why is the minimum delay in serout 1ms?
> I would also argue that the 'language' interpretation is irrelevant in
> any
> slower
> microcontroller.
> there
> BS2SX
> lamont@a...
require a pull-up/pull-down to move the line in the other direction (the
BASIC Stamp pin floats at this point to allow the pull-up/pull-down to
do its job). This is very useful when you want to connect a bunch of
devices to the same serial line.
If, for example, you use an open, non-inverted baud mode. This would
require a pull-up on the serial line since the BASIC Stamp (and other
compliant devices) will pull the line low for state 0, let the line
float (under control of the pull-up) for state 1. Even if two devices
try to talk at the same time they will not be conflicting with each
other since they can only pull the line low.
But, if you were using a driven baud where the Stamp and other devices
drive both directions, the possibility exists that one device could
drive the serial line high while the other drives it low -- this would
create a conflict [noparse][[/noparse]direct short] and damage a device.
-- Jon Williams
-- Dallas Office
From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uh4MJxkqzDgQbhMUFIjlAeMcCzxYHvYjJqzhC3PxPyhIEISRaU5EY0QktRiVRPh_90V5W76UyC7zDA]jrem123@y...[/url
and learn . . .
> -- Jon Williams
> -- Dallas Office
> The open baud modes will only drive the serial line in one direction
> and
> (the
> to
> devices
> devices
> would
> -- Jon Williams
> -- Dallas Office
> From: John Remington [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sFZzXAgygPCzAcyRx2JtX01N52oMELXa8w_3D5hkGbDafaQieR0ol7QkNllzOOMfjpMhY-qhhGCnww]jrem123@y...[/url
> listen
> and learn . . .
> used
> > -- Jon Williams
> > -- Dallas Office
> there
> BS2SX
> Yahoo! Groups Links
Do you Yahoo!?
called a 'wired-or' buss. This gives a
multi-master communication line. As long as
only one 'talker' is talking at a time,
multiple 'listeners' can listen on the line
and get the data.
You CAN have multiple talkers without damage,
but the data will be garbled if two talk at
the same time. Your protocol will have to
provide some way around this -- typically,
a sync byte at the start, and a checksum
at the end.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
direction and
(the
to
of
would
other
devices
devices
would
> -- Jon Williams
> -- Dallas Office
> From: John Remington [noparse][[/noparse]mailto:jrem123@y...]
serout
listen
> and learn . . .
Help
used
> > -- Jon Williams
> > -- Dallas Office
there
BS2SX
learning
way of multiplexing the inputs. (shift registers or something)"
I think that's what I'm looking for... The 26 pedals/keys cannot be
connected completely individually, correct? So, by "shift registers",
do you mean to have each key trigger one of twelve inputs for the
correct note name and then simultaneously switch the correct octave to
play? This wouldn't do very well with polyphony, but I think it could
work. Of course, if you meant something entirely different, share
that, too :-)
Now, before I buy one of these seemingly wonderful microcontrollers, I
want to understand how it would work in conjunction with what I'm
looking to do. I'm looking at the BS2 which has 24 pins. To have a
"switch" type event, would I simply connect one wire to one pin, and
another to a ground pin, and upon contact of the two wires the program
could read it? How many of these switcherthingies could I have on one
BS2? Would I need any fancy resistors or anything between the switches
and pins?
Right now, the only experience I have with these Stamps is very
limited contact with the BS2sx in an IFI Robotics Isaac 16 Robot
Controller (http://www.ifirobotics.com) and that seems to read all the
neat little inputs it has set up for me with great ease. I became
interested in the Stamps upon realizing what was inside so many of
these killing machines that we trusted our very lives to.
Well, thanks again,
~Sam Kronick
--- In basicstamps@yahoogroups.com, "Sean T. Lamont .lost."
> I want to completely disagree with this.
some
> > > Hello all,
bill,
> > > Thanks!
> > > ~Sam
up all
line
> > > there, though.
Subject
> > > Yahoo! Groups Links
> > Do you Yahoo!?
Subject and Body of the message will be ignored.
> > Yahoo! Groups Links
shift registers, but basically they allow input and output states to
transmit using TTL pulses over a single I/O line. You could also use octal
latches, which allow you to view switches a bank of 8 at a time (I used a
BS2 and 8 octal latches to multiplex 64 I/O lines off of the 16 I/O
pins...)
Another thing that might be pretty useful to consider is looking at a PS2
driver and hacking a standard keyboard for the 110 switches. You're
unlikely to be able to get velocity or poly-pressure data for any of these
things.
I'm sort of curious why you want to recreate a cheap MIDI keyboard,
though. MIDI is much more interesting to play with, I find, when you're
building devices that are uncommon.
On Tue, 9 Mar 2004, captaink1234 wrote:
> "What I would recommend for the original poster is that he figure out some
> that, too :-)
> and pins?
> Well, thanks again,
> ~Sam Kronick
> some
> > > > Hello all,
> bill,
> > > > Thanks!
> > > > ~Sam
> up all
> line
> > > > there, though.
> Subject
> > > > Yahoo! Groups Links
> > > Do you Yahoo!?
> > > Yahoo! Groups Links
> Yahoo! Groups Links
"Do not fear mistakes, There Are None" - Miles Davis
MIDI keyboard exactly, but a controller based on the pedal board of an
electric organ. I know it's similar, and judging by your projects on
your website, the "uncommon" devices you speak of are laser harps and
such, but I think I'll start somewhere simple. I just think it would
be neat to have some bass tones that I could play and jam along with
while playing guitar or the like. There are MIDI pedals out there, but
I believe they are quite out of my spending range, and to DIY is
always more fun :-)
Based on the application I'm looking at, polyphony would be nice,
velocity sensitivity completely unneccessary. Monophony would be
entirely acceptable if I could reliably play the pedals without
accidentally hitting one on either side of the tone I wished to play.
I'm sure I could program it to not play just the last pedal pressed,
but the last pedal pressed that is still being held down. Due to the
potential complexity of such a system and the number of times it would
need be duplicated, TTL pulses and such seems out of the question. I
would need a device/circuit that would create the right pulse for each
of the pedals, correct? In that case, I think octal latches might be
the best way to go. Judging from your math, I could hook up 8
independent switches at a time on the 16 IO pins. Does that mean there
is no way to have a common ground? If I wanted to represent all 12
tones, I would have to think in "registers" more than octaves, for a
third of an octave would actually be one register higher, if you
follow. I could develop a system with only 8 tones per octave (major
scale) and transpose that to the correct key, as long as all the notes
stayed in that key.
But now I'm just brainstorming in front of all of you. Maybe someone
could help me decide what kind of system to use from the above ideas.
If all this seems a little far-reaching, I can go to my backup plan of
wiring this board to one of my two allmighty Casio SK-1's. An un-bent
unit wouldn't produce tones low enough for what I want, but this is no
un-bent unit... No, my friends, this beast is your new savior.
But that is neither here nor there. Thanks a lot!
~Sam Kronick
> There are many ways to multiplex I/O. I haven't worked extensively with
octal
used a
> pins...)
a PS2
these
> things.
out some
> > that, too :-)
> > and pins?
> > Well, thanks again,
> > ~Sam Kronick
events ; the
incident
> > some
The midi
instead of
on the
there
BS2SX
learning
> > > > > Hello all,
organ that
believe
these
fast. I
device. I
from the
modify the
> > > > > source code
currently
little
has 16
and I
seems the
> > bill,
interface
anyone has
it. If
> > > > > Thanks!
> > > > > ~Sam
of this
> > up all
run the
> > line
> > > > > there, though.
> > Subject
> > > > > Yahoo! Groups Links
> > > > Do you Yahoo!?
> > > > Yahoo! Groups Links
> > Yahoo! Groups Links
Bremerton
I think you should probably look into shift registers further, it may
serve your purpose. Remember that midi itself is just a TTL stream at
31.25 Kbaud, and it seems to handle a fairly large degree of complexity.
It is a common ground, the way latching works is, you have, say 8 toggles
and 8 input states on 8 latches. When you toggle the special 'latch' bit
on the latch, the information stored on the latches flows into the 8
inputs, so you have sort of a register/offset approach where you can view
groups of 8 I/O lines in subgroups of 8 at a time.
> stayed in that key.
You always play without accidentals? [noparse]:)[/noparse]
> ~Sam Kronick
> octal
> used a
> > pins...)
> a PS2
> these
> > things.
> out some
> > > that, too :-)
> > > and pins?
> > > Well, thanks again,
> > > ~Sam Kronick
> events ; the
> incident
> > > some
> The midi
> instead of
> on the
> there
> BS2SX
> learning
> > > > > > Hello all,
> organ that
> believe
> these
> fast. I
> device. I
> from the
> modify the
> > > > > > source code
> currently
> little
> has 16
> and I
> seems the
> > > bill,
> interface
> anyone has
> it. If
> > > > > > Thanks!
> > > > > > ~Sam
> of this
> > > up all
> run the
> > > line
> > > > > > there, though.
> > > Subject
> > > > > > Yahoo! Groups Links
> > > > > Do you Yahoo!?
> > > > > Yahoo! Groups Links
> > > Yahoo! Groups Links
> Bremerton
> Yahoo! Groups Links
additional hardware, no? It would also likely require more advanced
programming of the Stamp than I wish to do. I'm thinking simple right now.
Let me know if the following plan has any flaws or if there is a
better way to do the same thing without much more complexity:
I've got 25 or 26 pedals. The BASIC Stamp II has 16 IO pins. Each
pedal would act as a simple switch when depressed. The bottom of the
pedal would contact with the base, completing two circuit. One would
run from one of 12 IO pins (representing the pitch) to the ground pin.
The other circuit that would be completed would run from one of 3 IO
pins (representing the octave) to the ground pin. From the two
complete circuits, the PBASIC program would recieve two switch "on"
signals. It would use these (pitch and octave) to generate the correct
MIDI instruction and send it via SEROUT on the remaining IO pin. If I
figure correctly, I would get three full octaves of 12 notes apiece,
giving me 36 possible pedals. I could, theoretically, program and wire
the extra inputs to generate MIDI control signals.
Once again, thank you for the time you take to answer my questions. I
may not be describing my ideas with complete clarity, but I hope
they're getting across.
Thanks!
~Sam Kronick
toggles
view
> > stayed in that key.
> > ~Sam Kronick
extensively with
> > octal
> > used a
> > > pins...)
> > a PS2
> > these
> > > things.
you're
> > out some
cannot be
registers",
octave to
it could
> > > > that, too :-)
microcontrollers, I
pin, and
program
on one
switches
> > > > and pins?
all the
> > > > Well, thanks again,
> > > > ~Sam Kronick
> > events ; the
> > incident
converting
figure out
> > > > some
> > The midi
> > instead of
> > on the
> > there
> > BS2SX
controller that
> > learning
> > > > > > > Hello all,
> > organ that
> > believe
> > these
> > fast. I
> > device. I
> > from the
> > modify the
> > > > > > > source code
speak of
> > currently
> > little
> > has 16
> > and I
> > seems the
fit the
> > > > bill,
> > interface
> > anyone has
> > it. If
controller,
> > > > > > > Thanks!
> > > > > > > ~Sam
> > of this
bashed
> > > > up all
> > run the
else is in
> > > > line
> > > > > > > there, though.
in the
> > > > Subject
> > > > > > > Yahoo! Groups Links
> > > > > > Do you Yahoo!?
> > > > > > Yahoo! Groups Links
> > > > Yahoo! Groups Links
(ServNet)
> > Bremerton
> > Yahoo! Groups Links
