bs2e-ic.....bs2sx-ic conversion please help
okay,
on the bs2sx-ic the pulsout command is whatever number you tell it
times .8us
so pulsout 1,360 means 360* .8us = 288 microseconds
and on the bs2e-ic it is number times 2us
so pulsout 1, 360 means 360* 2us = 720 microseconds
so to make both times pulse exactly the same i should use pulsout
1,144 for the bs2e-ic and pulsout 1, 360 for the bs2sx-ic
both of those pulsout commands should pulse 288 microseconds right?
so asuming my i am right....the bs2e-ic is not doing the same thing
as the bs2sx-ic does is it possible that the bs2e-ic is a bad chip?
heres the code im using...it works absolutely perfect on bs2sx with
pulsout set to 360---then i change the pulsout to 144 and its not
even close on the bs2e-ic. I think i have a bad chip what do you
think?
steve
mSecond var word
Second var word
temp var byte
start 'label
second=0
msecond=0
Button 7,1,255,255,temp,1,go ' will loop until the button is pressed
goto start
go
Button 7,1,255,255,temp,1,show ' will loop until the button is pressed
msecond = msecond + 1 'counts up mseconds
pulsout 1,360
if msecond < 999 then go 'if msecond > 999 goes to next command
msecond = 0 'zeros out msecond
second = second + 1 ' adds 1 to seconds
goto go 'jumps to label
Show: 'label
debug "time"," ",dec second,".",dec msecond,cr
goto start
times .8us
think?
steve
mSecond var word
Second var word
temp var byte
start 'label
second=0
msecond=0
goto start
go
pulsout 1,360
Show: 'label
goto start
>okay,
>times .8us
Steve -
If I'm reading this correctly, there's nothing "bad" about it. They merely
operate at different speeds. Is a Volkswagen "bad" because it can't attain
the speeds of a E-Jag ? I'd think not. I'm not even sure it's a chip
difference - now (see below).
>think?
>steve
Make sure the programs are being loaded. In the BS-2SX one place ' Debug
"BS-2SX" ' and in the other (the BS-2e) place ' "Debug BS-2e" '. Then you
can be assured that the proper program is being loaded AND executed. IF
THEY DO NOT DISPLAY THOSE VALUES, there IS a problem. It can probably be
solved by using the $STAMP operative ' {$STAMP BS2SX} ' as shown in the
BS-2SX V1.5 Manual (which see). What one does with the BS-2E I can't say.
having never used one.
Additionally, you don't mention which Editor you are using (DOS or
WINDOWS). If you are using the DOS Editor, please be aware of the following
caveat from that same manual:
"The DOS editor can only load up one source code file at a time. Each
unique BS2SX program
(of a maximum of eight) to be downloaded to the BS2SX must be downloaded
separately with a
unique program ID. NOTE: The Windows version does not have this
limitation. Pressing ALT+# (where # is a number from 0 to 7) will change
the ID (shown at the top of the window) of the currently
visible source code in the editor.
==>>This ID is not saved with the program and must be set and verified
manually<<==
==>> each time it is loaded from disk and before each
download. <<==
IMHO, this is an Editor problem, NOT a coding or chip problem, but time
WILL tell.
Bruce Bates
>temp var byte '<<<<====== This VARIABLE NEEDS TO BE CLEARED BEFORE USE
>start 'label
>second=0
>msecond=0
>goto start
>go
>pulsout 1,360
>Show: 'label
>goto start
