BS2E?? — Parallax Forums
BS2E??
edited 2000-12-09 20:26 in General Discussion
What in the world is the BS2E? Did I miss something?
-William
    edited 2000-12-09 03:46
    [font=arial,helvetica]In a message dated 12/8/00 9:44:39 PM Central Standard Time,
    william@characterlink.net writes:
    The BS2e is very identical to the BS2sx (8 program slots and scratchpad RAM)
    except that it runs at 20 MHz (standard BS2 speed) and, consequently,
    consumes less current. ·You can distinguish a BS2e from the others by its red
    PCB.
    [/font]
    >>-William
    >Jonwms:
    >consumes less current. You can distinguish a BS2e from the others by its red
    >PCB.
    Hi William,
    The only difference between the BS2e and the BS2sx is that the BS2e
    runs slower. Why would you want a chip to run slower?
    1) The BS2e is compatible with the original BS2, for example, the
    timing of the SEROUT or PULSOUT commands are the same on the BS2e and
    BS2, so that the same program will work the same on either one.
    Moving a program from the BS2 to a BS2sx usually requires changes in
    the timing parameters.
    2) The BS2e runs much cooler, lower power than the BS2sx, important
    if you are running a project from batteries or solar.
    You might want to take a look at the recently updated FAQ on the parallax site:
    http://www.parallaxinc.com/downloads/Documentation/Basic%20Stamps/stam
    p_faqs.pdf
    regards,
    -- Tracy Allen
    http://www.emesys.com/BS2index.htm <-- more BS2e ap-notes
