help please!
could anyone give me a hand please, I am a first time robot person and
cannot decide how to go about starting. I could get a Basic stamp, BOE-Bot,
OOpic, or i don't know what else. I need some help to figure what else to do
next. mechanical stuff is not a problem, and right now i am taking Qbasic
and C++ programming in school. some help would be great.
Dave.
>From: "john & lisa" <johnlisa@c...>
>Reply-To: basicstamps@egroups.com
>To: <basicstamps@egroups.com>
>Subject: [noparse][[/noparse]basicstamps] FAO Bruce Bates
>Date: Tue, 5 Dec 2000 13:08:06 -0000
>Hi Bruce here's the two programes I have for my setup the first one is for
>the Polaroid 6500 sensor the second for the PaK VIII which I use to drive
>the servo's. All I want to do is take the out put from the 6500 and use it
>to tell the Pak VIII to stop the motors, turn them until path is clear or
>move forward until the path becomes obstructed. Sorry I could not send them
>as a zip file I tried but it did not appear to work. Once again thanks very
>much for your time it's very much appreciated.
>John
>__________________________________________________________
>'Polriod 6500 set-up programme
>TIMEOFFLIGHT var word
>DISTANCE var word
>ECHO con 13
>INIT con 14
>SETTLETIME con 1
>CYCLE_DELAY con 2
>pause 20
>X VAR WORD
>pause 1000
>gosub forward
>pause 5
>gosub back
>pause 5
>gosub left
>pause 5
>gosub forward
>pause 5
>gosub right
>forward:
>for x=1 to 10
>pulsout 8,850
>pulsout 9,650
>pause 20
>back:
>next
>return
>for x=1 to 10
>pulsout 8,650
>pulsout 9,850
>pause 20
>next
>return
>left:
>for x=1 to 10
>pulsout 8,850
>pulsout 9,850
>pause 20
>next
>return
>right:
>for x=1 to 10
>pulsout 8,650
>pulsout 9,650
>pause 200
>SENSE:
>high INIT
> 'see the 6500 app notes for timing info
>pause SETTLETIME
>rctime ECHO,0,TIMEOFFLIGHT
> 'waits for ECHO to go low,
> 'which signals a return ping.
> 'threshold is 1.4 volts
>gosub ECHORECEIVED
>low INIT
>pause CYCLE_DELAY
>ECHORECEIVED:
>DISTANCE = TIMEOFFLIGHT * 7 / 200 + 22
> ' this conversion approximates centimetres,
> ' accounting for the offset imposed by the
> ' blinking signal generated by the 6500
>debug dec? DISTANCE
> 'print distance on screen
>return
>____________________________________________________________
>' Servo BoE-BoT demo for PAK-VIII
>'Data on BSII pin0, Clk on pin 1
>datap con 0
>datapin var in0
>clk con 1
>' Register names
>DURLOW con %000
>DURHIGH con %001
>HIGHDUR con %010
>LOWDUR con %011
>PSCALE con %100
>PSBASE con %101
>N con %110
>CTRL con %111
>center0 con 150
>center1 con 152
>output clk
>output datap
>fpx var word
>fpb var byte
>' parameters for Fcommand
>chan var nib
>register var nib
>debug "reset",cr
>gosub freset 'always reset!
>gosub FTotalReset 'hard reset
>top:
>' disable channel 0 and 1
>chan=0
>register=6
>fpx=1
>gosub Fcommand
>chan=1
>gosub Fcommand
>gosub servocenter
>'turn on and enable chan 0 and 1
>for chan=0 to 1
>fpb=3
>gosub FJam
>next
>'set both servos to 2mS (200)
>'since servos are "back to back"
>'the robot will rotate
>chan=0
>register=1
>fpx=200
>gosub Fcommand
>chan=1
>gosub Fcommand
>pause 10000 'rotate for 10 seconds
>chan=1
>register=1
>fpx=100 'go in one direction (reverse servo#1)
>gosub Fcommand
>pause 10000
>gosub servocenter
>stopp:
>goto stopp
>end
>'center both servos
>servocenter:
>chan=0
>register=1
>fpx=center0 '150 x 10 = 1.5mS
>gosub Fcommand
>chan=1
>fpx=center1
>gosub Fcommand
>register=2
>fpx=2000 '2000 x 10 = 20mS
>gosub Fcommand
>chan=0
>goto Fcommand 'let Fcommand return
>' reset the PAK-VIII I/O
>Freset:
>LOW DATAP
>LOW CLK
>HIGH CLK
>HIGH DATAP
>LOW CLK
>return
>' 0 is 0, 1 is 1, 2 is hi-z, 3 is normal
>' note: 3 enables channel to run!
>FJam:
>fpb=chan + (fpb<<3)+%01000000
>goto FsendByte
>Fcommand:
>'inputs chan = channel, register = register
>fpb=(register<<3) + chan
>gosub FsendByte
>fpb=fpx.lowbyte
>gosub FsendByte
>fpb=fpx.highbyte
>goto FsendByte
>FreadReg:
>fpb=(register<<3) + chan + %10000000
>gosub FsendByte
>'fall into FreadWord
>FreadWord:
>shiftin datap,clk,MSBPRE,[noparse][[/noparse]fpx.lowbyte,fpx.highbyte]
>return
>FtotalReset:
>fpb=$FF
>FsendByte:
>shiftout datap,clk,MSBFIRST,[noparse][[/noparse]fpb]
>return
>FreadByte:
>shiftin datap,clk,MSBPRE,[noparse][[/noparse]fpb]
>return
>Fprescale:
>' set fpb to the prescale constant
>fpb = fpb + $c0
>goto FsendByte
________________________________________________________________________________\
_____
Get more from the Web. FREE MSN Explorer download : http://explorer.msn.com
Dave.
>John
>DISTANCE var word
>ECHO con 13
>INIT con 14
>SETTLETIME con 1
>CYCLE_DELAY con 2
>pause 20
>X VAR WORD
>pause 1000
>gosub forward
>pause 5
>gosub back
>pause 5
>gosub left
>pause 5
>gosub forward
>pause 5
>gosub right
>forward:
>for x=1 to 10
>pulsout 8,850
>pulsout 9,650
>pause 20
>back:
>next
>return
>for x=1 to 10
>pulsout 8,650
>pulsout 9,850
>pause 20
>next
>return
>left:
>for x=1 to 10
>pulsout 8,850
>pulsout 9,850
>pause 20
>next
>return
>right:
>for x=1 to 10
>pulsout 8,650
>pulsout 9,650
>pause 200
>SENSE:
>high INIT
>pause SETTLETIME
>gosub ECHORECEIVED
>low INIT
>pause CYCLE_DELAY
>ECHORECEIVED:
>debug dec? DISTANCE
>return
>datap con 0
>datapin var in0
>clk con 1
>' Register names
>DURLOW con %000
>DURHIGH con %001
>HIGHDUR con %010
>LOWDUR con %011
>PSCALE con %100
>PSBASE con %101
>N con %110
>CTRL con %111
>center0 con 150
>center1 con 152
>output clk
>output datap
>fpx var word
>fpb var byte
>chan var nib
>register var nib
>debug "reset",cr
>top:
>chan=0
>register=6
>fpx=1
>gosub Fcommand
>chan=1
>gosub Fcommand
>gosub servocenter
>for chan=0 to 1
>fpb=3
>gosub FJam
>next
>chan=0
>register=1
>fpx=200
>gosub Fcommand
>chan=1
>gosub Fcommand
>chan=1
>register=1
>gosub Fcommand
>pause 10000
>gosub servocenter
>stopp:
>goto stopp
>end
>'center both servos
>servocenter:
>chan=0
>register=1
>gosub Fcommand
>chan=1
>fpx=center1
>gosub Fcommand
>register=2
>gosub Fcommand
>chan=0
>Freset:
>LOW DATAP
>LOW CLK
>HIGH CLK
>HIGH DATAP
>LOW CLK
>return
>FJam:
>goto FsendByte
>Fcommand:
>gosub FsendByte
>fpb=fpx.lowbyte
>gosub FsendByte
>fpb=fpx.highbyte
>goto FsendByte
>FreadReg:
>gosub FsendByte
>FreadWord:
>return
>FtotalReset:
>fpb=$FF
>FsendByte:
>return
>FreadByte:
>return
>Fprescale:
>fpb = fpb + $c0
>goto FsendByte
_____
