serin command
I'm having a little problem but I cant seem to think straight at the
moment. Anyway I have this line of code in a program
SERIN 16,B96,("G")
when I use the syntax check, it always says
Error: expected ','
but in the BS2 manual it has this example
SERIN 0,N2400,("A")
I've never used this command before so I would like to know if it is
just me or is it the editor. What is wrong with it? Please tell me
how to correct it.
Andy
SERIN 16,B96,("G")
Error: expected ','
SERIN 0,N2400,("A")
how to correct it.
Andy
>SERIN 16,B96,("G")
>Error: expected ','
>SERIN 0,N2400,("A")
>how to correct it.
The SERIN command requires the following, per the PBASIC Stamp Manual:
For the BS-1 Stamp -
SERIN pin,baudmode,(qualifier,qualifier,...)
SERIN pin,baudmode,{#}variable,{#}variable,...
SERIN pin, baudmode, (qualifier,qualifier,...), {#}variable,
{#}variable,...
Per the Manual "Pin is a variable/constant (0–7) that specifies the I/O pin
to use." so 16 is an INVALID pin number for the Stamp BS-1.
In all case the BAUDMODE parameter is REQUIRED. ONLY the BAUDMODES AND
SYMBOLS as found in the table below are VALID for the Stamp BS-1 :
# Symbol Baud Rate Polarity
0 T2400 2400 true
1 T1200 1200 true
2 T600 600 true
3 T300 300 true
4 N2400 2400 inverted
5 N1200 1200 inverted
6 N600 600 inverted
7 N300 300 inverted
So B96 is NOT a valid parameter for the Stamp BS-1, NOR is Port pin number 16.
For the BS-2 Stamp -
If you are using a Stamp BS-2 the BAUDMODE parameter can be expressed as a
variable, and the format is:
SERIN rpin{\fpin},baudmode,{plabel,}{timeout,tlabel,}[noparse][[/noparse]inputData]
In this case B96 might be valid, if the syntax had been correct.
SERIN 16,B96,("G") is a copy of your example
| | -- |< -- ambiguous use of a constant
|< -- incorrect bracket
undefined symbol (at present)
So I trust that will give you a start.
Knowing whether the statement was destined for a BS-1 or a BS-2 would be
MOST helpful.
Bruce Bates
>Andy
As well as the i/o No 16 being incorrect.
Chris
To: <basicstamps@egroups.com>
Sent: Tuesday, December 05, 2000 8:37 PM
Subject: Re: [noparse][[/noparse]basicstamps] serin command
> >SERIN 16,B96,("G")
> >Error: expected ','
> >SERIN 0,N2400,("A")
> >how to correct it.
> {#}variable,...
> Per the Manual "Pin is a variable/constant (0-7) that specifies the I/O
pin
> 0 T2400 2400 true
> 1 T1200 1200 true
> 2 T600 600 true
> 3 T300 300 true
> 6 N600 600 inverted
> 7 N300 300 inverted
16.
> MOST helpful.
> Regards,
> Bruce Bates
> >Andy
Check a little closer an you'll find that the example shows SERIN
0,N2400,[noparse][[/noparse]"A"]. You used parentheses instead of brackets. I never understood
why brackets [noparse][[/noparse] ] were chosen. I guess I'm just glad they didn't choose
braces { } .
>SERIN 16,B96,("G")
>Error: expected ','
>SERIN 0,N2400,("A")
>how to correct it.
>Andy
_________________________________
Mike Walsh
walsh@i...
California Institute of Technology
Biology Electronics Shop
MS 216-76
Pasadena, CA 91125
626-395-6825 , FAX 626-584-1654
237 Beckman Behavioral Biology Bldg.
