Programming
Can anyone help me, I'm getting real desperate now. You see its all to do with programming. I have a BSII connected to a Polariod 6500 module and a PAK VIII which is connected to the Stamp and two servo's. Now I have programmes for running each piece of kit individually, but I have no idea how to get them to work together, I've tried reading through the Basic Stamp manual, and from them I can pretty much work out how each programme works, but I can't figure out how they work together. Here's what I'm trying to do :-
Switch on Robot
Robot uses Polariod Sensor to detected objects
If objects are close by it sends a command to the PAK VIII to change direction
it keeps doing this until there are no objects in its path.
When path is clear of any close object (i.e any objects within 30cm) it takes another reading from the sensor to judge how much the path is clear. Lets say the distance is 100cm then the BSII sends instructions to the PAK VIII to move the robot forward 90 cm or until the sensor detects an object 10cm in front of it.
It then repeats the programme.
I know this requires a lot of programming, as I say I can control each circuit individually, I just can't seem to tie them together. I'm pretty sure someone out there has a similar set-up, if so please help, I've spent a lot of time and money for something that whizzes around making clicking noises and well just bangs into things.
Many, many thanks in advance to all that can help
John
Switch on Robot
John
John -
I'm not sure : (
I'm NOT SURE that is true ! I suspect it has MORE to do with the
capabilities (or lack thereof) of the Polaroid 6500 board !
IF they work properly apart, that SHOULD be all that you need. It ALMOST
sounds as though there is a problem passing data internal to the program.
E.g. You are "reading" binary, and presuming it is ASCII, or something of
that nature.
>Switch on Robot
This MAY BE never, if the objects in question are too close OR too far away.
There are TWO opportunities for NO ECHO within the time frame. One occurs
when the echo is TOO LATE, and the other occurs when the echo is TOO EARLY.
The 6500 Board documentation says " Accurate Sonar Ranging from 6" to 35 FT
". Add to that what you will find below regarding ringing time, and this
may not be as accurate a method as you may suspect. There is also a
question as to how you are using the board - it has more than one mode of
operation.
IMHO, that would take accuracy and repeatability greater then the Polaroid
6500 board has, when you consider delays in the software - which we
presently DON'T SEE. Just by way of reference, the ARobot documentation on
the Arrick Robot web site
[noparse]/noparse][url=http://www.robotics.com/arobot]http://www.robotics.com/arobot[/url shows a 9 second ringing period which must
be considered on that platform (excerpted from the ARobot Sonar Documentation):
QUOTE
sonar:
high init ' hit transducer.
pause 1 ' pause for ringing.
high binh ' raise inhibit.
rctime echo,0,dist ' wait for echo.
dist=dist/73+9 ' dist has number of inches.
' offset for ringing is 9 inches.
' sound travels 1 inch in 73us.
' rctime increments 2us.
pause 40 ' give it a rest.
low init ' reset sonar pins.
low binh
return ' done.
END QUOTE
A copy of your present program would SURELY help.
>John
We keep trying : )
Bruce Bates
>Thanks Bruce for your reply, I've glanced over it very quickly as I've just
>come of nightshift, and will look over it properly once I've had a good
>sleep. As for sending you the programmes I have, well there are two of them
>and they are quite long, I don't mind spending time typing them in, if you
>don't mind downloading seriously long emails.
Long emails are NO problem, but why type them ? Use cut-and-paste into an
email, or zip the programs and send them as an attachment. FAR F A
R easier then typing them !
>Thanks again for your help and time Sure !
>John
John
To: <basicstamps@egroups.com>
Sent: Monday, December 04, 2000 10:38 AM
Subject: Re: [noparse][[/noparse]basicstamps] Programming
> At 09:13 AM Monday 12/4/2000 +0000, you wrote:
> John -
> I'm not sure : (
manual,
> that nature.
> >Switch on Robot
direction
away.
EARLY.
FT
> operation.
clear.
PAK
object
must
Documentation):
> QUOTE
> sonar:
inches.
> low binh
> return ' done.
> END QUOTE
spent
> >John
> We keep trying : )
> Regards,
> Bruce Bates
I am having a similar problem. I am designing a robot that appears to
move within its program ok, but it won't access the navigation routines.
The robot uses standard DC motors attatched to a home-made motor controll
circuit. Would some kind person please take a look and tell me what is
wrong. The program is designed to take user input and let the pilot steer
untill the robot hits something then the robot executes an evasion routine
except when the "special modes" are active. Heres the program.
DIRS = %0000000000001111
front_left_whisker var in4
front_right_whisker var in5
rear_left_whisker var in6
rear_right_whisker var in7
forward_march var in8
march_left var in9
march_right var in10
backward_march var in11
manual_only var in12
auto_only var in13
' forward_march var in8
' march_left var in9
' march_right var in10
' backward_march var in11
' manual_only var in12 This overides the whiskers
' auto_only var in13 This ovverides the pilot to
let the robot wander forward
' these variables all are attatched to normally closed buttons and are
activated when
' they = 0
' all the whisker variables when their switches close = 1
main:
debug "main",cr
if manual_only=0 then manual_control
if auto_only=0 then auto_forward
goto scan
'---- the evade functions are named for where the object is relative to the
robot --
scan:
debug "scan",cr
if front_left_whisker=1 & front_right_whisker=1 then u_turn
if rear_left_whisker=1 & rear_right_whisker=1 then forward
if front_left_whisker=1 then evade_forward_left
if front_right_whisker=1 then evade_forward_right
if rear_left_whisker=1 then evade_reverse_left
if rear_right_whisker=1 then evade_reverse_right
goto manual_control
auto_forward:
debug "auto forward",cr
gosub forward
if auto_only=0 then scan
goto main
'---- this detects the pilots
orders
manual_control:
debug "manual control",cr
if forward_march=0 then manual_forward
if march_right=0 then manual_turn_right
if march_left=0 then manual_turn_left
if backward_march=0 then manual_backward
goto main
'---- navigation functions and
subroutines
evade_forward_left:
debug "EFL",cr
gosub backward
gosub turn_right
goto scan
evade_forward_right:
debug "EFR",cr
gosub backward
gosub turn_left
goto scan
evade_reverse_left:
debug "ERL" ,cr
gosub forward
gosub turn_left
goto scan
evade_reverse_right:
debug "ERR",cr
gosub forward
gosub turn_right
goto scan
u_turn:
debug "u-turn",cr
gosub backward
gosub turn_right
goto scan
'---- these are the evasion
subroutines
'---- the bits go as
follows
'---- forward left motor, forward right motor, reverse left motor, reverse
right motor-
forward:
outs = %1100
pause 2500
outs = %0000
return
backward:
outs = %0011
pause 5000
outs = %0000
return
turn_right:
outs = %1001
pause 2500
outs = %0000
return
turn_left:
outs = %0110
pause 2500
outs = %0000
return
manual_forward:
outs = %1100
pause 1000
outs = %0000
return
manual_backward:
outs = %0011
pause 1000
outs = %0000
return
manual_turn_right:
outs = %1001
pause 1000
outs = %0000
return
manual_turn_left:
outs = %0110
pause 1000
outs = %0000
return
'---- the
end
Sent: Monday, December 04, 2000 4:38 AM
> John -
> I'm not sure : (
manual,
> that nature.
> >Switch on Robot
direction
away.
EARLY.
FT
> operation.
clear.
PAK
object
must
Documentation):
> QUOTE
> sonar:
inches.
> low binh
> return ' done.
> END QUOTE
spent
> >John
> We keep trying : )
> Regards,
> Bruce Bates
Sent: Monday, December 04, 2000 4:48 PM
> Hi Everyone,
> march_left var in9
> auto_only var in13
> activated when
> ' they = 0
> main:
> debug "main",cr
> goto scan
the
> robot --
> scan:
> debug "scan",cr
> goto manual_control
> auto_forward:
> gosub forward
> goto main
> orders
> manual_control:
> goto main
> subroutines
> evade_forward_left:
> debug "EFL",cr
> gosub backward
> gosub turn_right
> goto scan
> debug "EFR",cr
> gosub backward
> gosub turn_left
> goto scan
> evade_reverse_left:
> debug "ERL" ,cr
> gosub forward
> gosub turn_left
> goto scan
> debug "ERR",cr
> gosub forward
> gosub turn_right
> goto scan
> u_turn:
> debug "u-turn",cr
> gosub backward
> gosub turn_right
> goto scan
> subroutines
> follows
> right motor-
> forward:
> outs = %1100
> pause 2500
> outs = %0000
> return
> backward:
> outs = %0011
> pause 5000
> outs = %0000
> return
> turn_right:
> outs = %1001
> pause 2500
> outs = %0000
> return
> turn_left:
> outs = %0110
> pause 2500
> outs = %0000
> return
> manual_forward:
> outs = %1100
> pause 1000
> outs = %0000
> return
> manual_backward:
> outs = %0011
> pause 1000
> outs = %0000
> return
> manual_turn_right:
> outs = %1001
> pause 1000
> outs = %0000
> return
> manual_turn_left:
> outs = %0110
> pause 1000
> outs = %0000
> return
> '---- the
end
> From: "Bruce Bates" <bvbates@u...>
> > John -
> > I'm not sure : (
which
> manual,
I
program.
of
> > that nature.
> > >Switch on Robot
> direction
> away.
occurs
> EARLY.
> FT
of
> > operation.
> clear.
> PAK
> object
Polaroid
on
> must
> Documentation):
> > QUOTE
> > sonar:
> inches.
73us.
> > low binh
> > return ' done.
> > END QUOTE
pretty
> spent
clicking
> > >John
> > We keep trying : )
> > Regards,
> > Bruce Bates
book out there if i'm not familiar with BASIC that can let me know how to
go about it?
my code is simple (if - then - else statements)
i have BASIC Stamp by Claus Kuhnel and Klaus Zahnert
i was wondering if anyone could recommend anything else?
LaQuida
>If i want to program the Basic Stamp II, is there a pretty good reference
>go about it?
>- thanks :-)
>LaQuida
Hi LaQuida -
The Parallax web site has a number of fine books, right on the first
page of their web site. The Parallax web site can be found here
[noparse][[/noparse] http://www,parallaxinc.com ].
Any of the books they show will do nicely, based on what your
specific needs should be. Some are for beginners, others are
for more advanced users. Each is so labelled, as you will see.
The book you have, is excellent, although I'm not sure it was intended
for beginners. The books indicated on the web site may be available from
their authors as well. Many of them frequent this list, as you may soon see.
Hope this gets you started, and hope you enjoy Stamping
Bruce Bates
which explains the basics of the bs1 and gives heaps of sample code, circuit
diagrams etc.
Chris
Sent: Sunday, January 07, 2001 2:05 AM
Subject: [noparse][[/noparse]basicstamps] programming
> go about it?
> - thanks :-)
> LaQuida
Scott Edwards has in his book "Programming and Customizing the Basic Stamp"
two chapters called "Basic Stamp Boot Camp" that are *excellent*. I have
been programming for lots of years, in lots of languages, and those chapters
are among the best I've seen. Not only is the language introduced, but also
the electronic interfacing.
Tom O'Brien
It would help if you give me there emial.
thank you.
>From: "Chris Anderson" <fes@g...>
>Reply-To: basicstamps@egroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] programming
>Date: Sun, 7 Jan 2001 09:56:19 +0800
>Scott Edwards electronics have a great first timer book called
>"Counterfeit"
>circuit
>diagrams etc.
>Chris
>From: La Quida Brown <sunset97@S...>
>reference
>to
> > go about it?
> > - thanks :-)
> > LaQuida
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
mercuryhg7@hotmail.com writes:
You can contact the Parallax support staff by writing to:
stamptech@parallaxinc.com[/font]
All of their contact details are on their website
Chris
Sent: Wednesday, January 10, 2001 1:58 AM
> hi im just want to know how to do wrote to the parallax guys??
> thank you.
> >"Counterfeit"
> >circuit
> >diagrams etc.
> >Chris
> >reference
> >to
> > > go about it?
> > > - thanks :-)
> > > LaQuida
i'm very interested in programming microcontrollers and embedded
programming but i dont know a thing about electronics i've read alot
of books but i just cant get it well what i'm asking is this required
for for microcontrollers or should i give up on this field
help a lot).
You can learn a lot in a short while using
the www.parallaxinc.com BasicStamps.
You should get one of their board kits, such as the BOE (Board of Education)
Starter kits,
or maybe the more sophisticated StampWorks kit or NS-1000 board itself.
In any case they have pretty much all their manuals and software online, so
you can
use the manuals and run through all their experiments and lessons and build
up
experience and knowledge with the Basic Stamp MCU's.
From: mozzart22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5QP65YAz7jjOYOTQPFbZKuZU1GQBrPYocSWg-7Hp7O_s8SYVEKHUtR6x5eTbM-5rnPqphWXJRU9Mjgg]mozzart22@y...[/url
Sent: Monday, February 11, 2002 11:56 PM
i just spent 2 years learning c, c++, and basic
From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TP-qfrmXtdbOsywoeoAFb33EnO4SY-_rInEekPELZcU1-GHHIcd4SbFGOKCRt___8iU0ibJZDyge3w]chris@m...[/url
Sent: Tuesday, February 12, 2002 11:18 AM
To: 'basicstamps@yahoogroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] programming
Don't give up. Embedded controllers is one of the few related fields that
actually has a future. Try the previous suggestion and get into the Stamps
In Class Curriculum at the Parallax Inc. web site, purchase one of the
kits...(You've already invested in 2 yrs worth of education, a few more
rubles will enable you to actually use it for something good)
Just jump in with no fear and start trying. All of a sudden it will make
sense. Read all the most basic material you can find on the subject. You
might also try Scott Edwards' book "Programming and Customizing the Basic
Stamp Computer" - it starts out with sections on all the related and
necessary hardware and electronics in a way that you are sure to understand.
And be patient - requirement number 1, IMHO...
I introduced my daughter to Stamps 3 or 4 years ago, and when she put her
formal programming training together with them, she went on to do great
things with all kinds of microcontrollers and makes super $$, often hiring
fellow students to help out because there's so much demand.
The Parallax Stamps are a great place to start, I think the best -
reliable, well documented, and has this list associated with it, where you
will get lots of help just for politely asking....
Chris
From: mozzart22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-h_cufo0HyVrtfsyE5m0XeJCYxf8y8k4D3Ddnono_76SfUJtUhHFdiy-JM7zSGWTdnBA2SqSMpaFFkY6uQ]mozzart22@y...[/url
Sent: Monday, February 11, 2002 9:56 PM
I think the Stamps in Class is excellent tutorial - also this list never
discourages questions from pure beginners.
I bet you'll have more fun learning to program a stamp than you ever did
learning C :-)
Tony Wells
To: "Basicstamps Group (E-mail)" <basicstamps@yahoogroups.com>
Sent: Tuesday, February 12, 2002 7:18 PM
Subject: FW: [noparse][[/noparse]basicstamps] programming
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XAvys95T25HMsuVsOKROK96emYM-mby2IVWoHY6wY6doJSry8r0xmQ1KqU2k6jHioyU7GEU-wIAScYkkdQ]chris@m...[/url
understand.
> Chris
> From: mozzart22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ISmtaU8TiC4xGoqGNWmupqA7ORjVIfMOTceK59ZeWUnmsiNO33h9eIprmIwyRwRVRw-FpC2oKkhktA]mozzart22@y...[/url
graduate from my university. Like you, I have an interest in
programming microcontrollers and I didn't know where to start. I knew
C/C++ and very little assembly. At first I focused on 8051s b/c there
was a book on it in the library. I shopped around and after 20-30
calls ordered an evaluation board. When I got it, I was very upset
and decided to make the switch to the Basic Stamp.
Everyone is saying that Basic Stamps are a good place to start. I say
they are the "BEST" place to start. If you want to learn on your own,
I highly recommend purchase of the Stampworks or Boebot depending or
your application/project. My project was a radio controlled talking
clock so I purchased Stampworks. I know you may be thinking it's too
expensive. I felt that way too when I bought it but it really helped
me get up to speed fast b/c I "learned by doing".
This site is for Stampworks:
http://www.parallaxinc.com/html_files/products/BS_Kits/stampworks.asp
The site has a PDF on Manual as well as source code for experiments.
Jon Williams did a good job in the authoring of the book.
I highly recommend Stampworks. If u can shell out the bucks, it is
worth it.
RP
alot
required
tutorial is released in the Stamp web site. You may need a breadboard for
simple experiment, sometimes soldering a little bit. Since you are in Basic
Stamp interest grp I suppose you are trying out STAMP, right?
helped me a lot in understanding the whole thing. It's aimed at a
high-school level, but I found it very useful, even having gotten a degree
in computer science (and, in fact, taken undergraduate-level electronics
classes. I passed, but I ended up with almost no pragmatic experience.)
On Wed, 13 Feb 2002, rpsu279 wrote:
> I was in your shoes about 9 months ago. I had to do a sr. project to
> worth it.
> RP
> alot
> required
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
