edge detection OOPS!
OOPS There are an error in the previous:
the correct is:
loop:
if inx = 1 then loop: (only wiil goto next line if state is low)
loop2:
if inx = 1 then your routine
goto loop2:
sorry
ACjacques
A.C.Jacques wrote:
> The statment if INx= 1 looks only for a high state no the transition
> itself but if your square wave have a lower frequency than the loop then
> it will go to routine very close with the rising edge. But there are no
> garantee that the first entrance in the loop the statement will be close
> to the edge. To do this you may look for two transitions:
> loop:
> goto loop:
> ACJacques
> djarmis@p... wrote:
> > The signal I'm detecting the edge on is a repetitive square wave. It's
> > possible that at the time the if INx=1 statement occurs the level
> > could be high. Would this satisfy the if statement or does INx only
> > look for a transition from a 0 to a 1? I'm new to Stamps and no little
> > about the language so I may be asking a dump question. Thanks,
> > --- In basicstamps@egroups.com, "A.C.Jacques" <acjacques@i...> wrote:
> > > Then this is very simple:
> > > loop:
> > > if INx = 1 then goto yourroutine (use = 0 if want to detect falling
> > > edge) (x is your pin number)
> > > goto loop
> > > ACJacques
> > > djarmis@p... wrote:
> > > > While it's looking for the edge it won't be doing anything else.
> > The
> > > > program will just wait for the edge to occur. When it detects it I
> > > > will need to go to a routine that will read some serial bytes in.
> > I
> > > > looked at the button command but not sure what it does. Thanks,
> > > > --- In basicstamps@egroups.com, LarryGaminde <lgaminde@t...>
> > wrote:
> > > > > Is this all the chip needs to do, or will it be reading or doing
> > > > other
> > > > > things while looking for a rising or falling edge.
> > > > > djarmis@p... wrote:
> > > > > > I need to monitor an input and detect a rising or falling
> > edge.
> > > > Upon
> > > > > > detection run a serial input routine. The pulse is one input
> > and
> > > > the
> > > > > > serial stream is another.
the correct is:
loop:
loop2:
goto loop2:
sorry
ACjacques
> loop:
> goto loop:
> ACJacques
> > > loop:
> > > goto loop
> > > ACJacques
> > The
> > I
> > > > other
> > edge.
> > > > Upon
> > and
> > > > the
So, Each rising edge is ~60ms apart. I believe your method should work
fine. Thanks,
> the correct is:
> loop:
> loop2:
> goto loop2:
> sorry
> ACjacques
transition
loop then
are no
close
> > loop:
> > goto loop:
> > ACJacques
wave. It's
level
only
little
> > > > loop:
falling
> > > > goto loop
> > > > ACJacques
else.
> > > The
detects it I
bytes in.
> > > I
doing
> > > > > other
falling
> > > edge.
> > > > > Upon
input
> > > and
> > > > > the
