Polaroid Sonar
Hi Everyone,
I just can't help but believe that some of you have an answer or to, to
the Polaroid 6500 sonar questions asked a few days ago - and so I must ask
them again:
-- What kind of ouput does the 6500 ranging module produce? Proportional
resistance or voltage?
-- Will I be able to take distance measurements to within +/- 1/8 inch?
I sure would appreciate any help,
Tim
them again:
Tim
me and connected it to an oscilloscope I received a clocked input that
varied faster or slower depending on the distance of an object in front of
the sensor, but bear in mind that I've no experience of oscilloscopes and
the one I used is waiting to go off for calibration coz it fell of the back
of a landrover (no that does not mean its stolen, it really did fall off the
landrover) but it did appear to clock at + & - 5v, if you have anyway of
confirming this I would, like I say I don't have any experience at using Osc
and this one does appear damaged.
hope this helps
John
To: Basic Stamp List <basicstamps@egroups.com>
Sent: Friday, December 01, 2000 3:30 AM
Subject: [noparse][[/noparse]basicstamps] Polaroid Sonar
> Hi Everyone,
to
> them again:
> Tim
Thanks so much for taking the time to put the 6500 module on the scope!
I guess what you describe as the output, is something like I expected, but
that doesn't add up in my mind with using the RCTIME command to read it on
the BS2 end. That's why I wondered if the output was a resistance
proportional to the distance measurement. Can you explain why the RCTIME
command works to read this type of signal?
Sorry to hear about the oscilloscope damage - that hurts.
Thanks again and yes, that does help.
Tim
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Friday, December 01, 2000 1:38 PM
Subject: Re: [noparse][[/noparse]basicstamps] Polaroid Sonar
>Hi Tim and Jo in ref to your question I took my 6500 module in to work with
the
Osc
>hope this helps
>John
>From: Tim and Jo <dema@t...>
>> Hi Everyone,
>to
ask
>> them again:
>> Tim
My stamp manual version 1.9 states that RCtime can also be used as a very
precise stopwatch.
I believe this is the manner which it is used with the sonar application
Steve
At 05:54 PM 12/01/2000 -0800, you wrote:
>Hi John,
>Tim
>From: john & lisa <johnlisa@c...>
>the
>Osc
>>hope this helps
>>John
>>> Hi Everyone,
>>to
>ask
>>> them again:
>>> Tim
I should try to answer your question!
Rctime waits(and counts) for a change of state(0 to 1 etc) much as the
pulsin function does.
good luck,
Steve
At 08:02 PM 12/01/2000 -0600, you wrote:
>Tim,
>precise stopwatch.
>Steve
>>Hi John,
>>Tim
>>the
>>Osc
>>>hope this helps
>>>John
>>>> Hi Everyone,
>>>to
>>ask
>>>> them again:
>>>> Tim
Thank you for that additional and ever so helpful information!
That explains alot,
Tim
Date: Friday, December 01, 2000 6:05 PM
>Hi Tim,
>good luck,
>Steve
>>Tim,
>>precise stopwatch.
>>Steve
>>>Hi John,
scope!
but
on
>>>Tim
with
of
and
back
>>>the
>>>Osc
>>>>hope this helps
>>>>John
>>>>> Hi Everyone,
to,
>>>>to
>>>ask
>>>>> them again:
Proportional
inch?
>>>>> Tim
to find a way to read the output from the 6500 board then use this info to
send commands to the PAK VIII that I'm using to drive my servos. I think
'Sargent' explained the RCTime command to a 'T'. Anyway good luck hope
between the replies you've had regarding the Polaroid Sonar board you get
your project up and running.
John
To: <basicstamps@egroups.com>
Sent: Saturday, December 02, 2000 1:54 AM
> Hi John,
scope!
> Tim
with
of
back
> the
> Osc
> >hope this helps
> >John
> >> Hi Everyone,
to,
> >to
> ask
> >> them again:
Proportional
> >> Tim
any infomation would be apreciated.
Regards
Peter Rogers
Spectra series electronics. They also wrote the BS code for you.
http://www.seattlerobotics.org/encoder/200010/dlcsonar.html
--- In basicstamps@y..., "Peter Murray" <molly7@o...> wrote:
> Does anyone out there have any info on the sonar ranging board from
a spectra model camera. it seems to have a different chip than the
standard sonar board.
> Regards
> Peter Rogers
be useing a bs2 to control it.)
Sent: Wednesday, June 13, 2001 7:31 PM
Subject: [noparse][[/noparse]basicstamps] Re: polaroid sonar
> The following link has info on wiring both the 600/660 and the
> > Regards
> > Peter Rogers
> from the same email address that you subscribed with. Text in the Subject
