Miniature gears
Hello All,
I'm working on my robot that is currently a sort of miniaturized (can be found at http://nagi.crosscity.com/basicstamp/alibe). I'm looking forward to further miniaturizing it with smaller gears. Currently, I'm using the Cirrus's miniature servos.·Recently, I·opened up the servos and got the motors and the gears. From what I see there, it seems that the servo casing is occupying a lot of room. If I can find a mechanism to mount these gears onto something more custom to save that extra space, I can then in effect miniaturize it.
My question are as follows: Please help with any of your comments.
··· 1.··· Is there a dealer who sells miniature gears that I can use off the shelf and hook up the mini-motor ?
··· 2.··· I'd like to use the same gears found in the servo, but, want to get away from the casing. Can you please give me ideas on how to accomplish this.
I have a 1" X 1" space that I can work with, if I can get away from using the casing that will really save me more room.
Thanks a lot in advance.
nagi
nagi
I don't have the servos that you speak of in front of me to look at, so I might be way off base.· My thought is to use a high speed rotary grinder to remove the mechanical and structural non critical spaces in the existing casing.· Then you still have something to hold the works in proper alignment, and possibly come up with some useful room in the un-needed parts of the case.
If you don't like that, Jameco· www.jameco.com and Edmund Scientific's both sell miniature gear sets.
Glad to hear your interesting project is still moving forward,
Greg
To: 'basicstamps@egroups.com'
Sent: Thursday, November 30, 2000 3:51 PM
Subject: [noparse][[/noparse]basicstamps] Miniature gears
Hello All,
nagi
Sent: Thursday, November 30, 2000 2:51 PM
Hello All,
nagi
projects too. I'm glad I'm back on track again [noparse]:)[/noparse]
I'll try jameco.
Thanks much again
nagi
From: Greg Lee Roth [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DAJUR50b1PHB-VhBgy3WXavW_NpL8TFnYjkxOhtrSVl2tilPQewXa26OU5my533rG-D5RAGsJItn59LZ8UcUGw]greg_roth@m...[/url
Sent: Thursday, November 30, 2000 3:28 PM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Miniature gears
Hi Nagi,
I might be way off base. My thought is to use a high speed rotary
the existing casing. Then you still have something to hold the works in
If you don't like that, Jameco www.jameco.com <http://www.jameco.com>
Greg
To: 'basicstamps@egroups.com' <mailto:'basicstamps@egroups.com'>
Hello All,
<http://nagi.crosscity.com/basicstamp/alibe> ). I'm looking forward to
Cirrus's miniature servos. Recently, I opened up the servos and got the
1. Is there a dealer who sells miniature gears that I can use off
2. I'd like to use the same gears found in the servo, but, want
accomplish this.
nagi
I'll check the towerhobbies and bug you guys with more questions [noparse]:)[/noparse]
nagi
From: David Peterson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UNiLlxFEgR_GXqoEgTcffyVBcwjPIsPyT1I6QQX9HSW2bR6FU6cBs3JIHFkK9c4nuBnQ1kF4un-s]robodave1@h...[/url
Sent: Thursday, November 30, 2000 4:27 PM
towerhobbies.com sells servo gear sets, ranging in price form $3 to $30,
mounting them would require you to find appropriate shafts and a pinion
gear for your motor that you want to use. Basically sandwich the gears
between 2 plates with the shafts mounted (with careful measurement) and
mount your motor to drive the gears. But you're winding up with a
gearmotor rather than a servo with the drive electronics associated,
requireing you to drive them with an h-bridge of some type. You might
simply experiment with removing the case of the servo you're using to
see how to fit it together more closely and still retain the drive
electronics, perhaps moved to the side for a better fit. Yet another
possibility involves mounting the servos on top of on another, with a
belt to drive the wheels where they are placed.
Hello All,
accomplish this.
nagi
http://www.servocity.com
ACJacques
Babu, Nagi -*Contractor wrote:
> Hello All,
> using the Cirrus's miniature servos. Recently, I opened up the servos
> accomplish this.
> nagi
chains that I could use for my robot.
Thanks again
nagi
From: A.C.Jacques [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=M2lpIBJ8coNk9xIScqJH0Rgx31IfG2Kxs9hMiRAt15UnIQjxbnNWeLj0wdGc0yvJPQnlvGjRZ7yEXcGIThBylg]acjacques@i...[/url
Sent: Thursday, November 30, 2000 5:03 PM
Look at
ACJacques
> Hello All,
> accomplish this.
> nagi
You could take a look at Microservos used for microlight radio controlled airplanes.
You find these servos at your lokal R/C dealer.
Regards ken J
Sent: Thursday, November 30, 2000 9:51 PM
Hello All,
nagi
I have no relationship to either company but do use a set of these servos in my indoor RC plane.
Tim
[noparse][[/noparse]Denver, CO]
From: Babu, Nagi -*Contractor [noparse][[/noparse]mailto:nags@crosscity.com]
Sent: Thursday, November 30, 2000 1:51 PM
Hello All,
nagi
Homefly has neat stuff....how prompt is their delivery, especially for the
airplane items?
Ray McArthur
To: <basicstamps@egroups.com>
Sent: Saturday, December 02, 2000 1:45 PM
Subject: RE: [noparse][[/noparse]basicstamps] Miniature gears
> Try http://www.idnet.de/homepage/scholl/Englisch/light_ng.htm for the
> smallest and lightest servos available. They do not use a geartrain like
> most, but a single spur and pinion gear driving a screw and provide a
linear
> not rotary output. They are available in the USA from
> http://www.homefly.com/
<< snip >>
service has always been prompt. On one of my orders there was an item that
was out of stock and he offered to either return the money leave the item on
order. I left the item on order and received it in about 4 weeks.
Tim
> Tim, thanks for the reference;
> airplane items?
> Regards,
> Ray McArthur
Looks pretty cool. How good is there delivery time ?
thanks
nagi
From: Tim Goldstein [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=w71ot-GtJ0QPU1bWxtrOC5MnKMie_si7HNXho3eHi9EY-rNmpp92LFPSc3KqEasdqUOmRhTzpp-o3Lo]timg@k...[/url
Sent: Saturday, December 02, 2000 12:45 PM
<http://www.idnet.de/homepage/scholl/Englisch/light_ng.htm> for the
linear not rotary output. They are available in the USA from
http://www.homefly.com/ <http://www.homefly.com/>
Tim
From: Babu, Nagi -*Contractor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PO4G3nFx_-N6Tts2dP0-WRkAsT5kYHNJJZ46wyxYmT3x9ZfuxoMDf5cR82OP47r3XWJZWy36s-FSQA]nags@c...[/url
Hello All,
accomplish this.
nagi
never mind. I missed your earlier response abt their turnaround time
thanks again
nagi
Sent: Saturday, December 02, 2000 8:27 PM
thanks Tim.
thanks
nagi
From: Tim Goldstein [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AgsjLKbw-I42fFkmMAe4lbUqLNXwdOSH0j7uSv3JtBGT2kOCjb7ia1ROpTOMEhmdH1KmluMGIubgzWg]timg@k...[/url
Tim
From: Babu, Nagi -*Contractor [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ky08CvMDshAQRIPfeJxB3ZooD5z1I5OoTmWYzbBFG1CCsBrKHDAh_EXx6eWuTK0b4YXcfoEBZDV4zCNOrQ]nags@c...[/url
Hello All,
accomplish this.
nagi
