Sonar Code...
Hi John and Everyone,
Here is the code that I am using with the 6500 sonar module:
Thanks for your time,
Tim
' POLAROID RANGING TEST PROGRAM - 11/26/2000
'BSII CONFIGURATION OF PINS USED
Output 0 'Serial out to LCD display.
Output 14 'Ranging module control.
Input 15 'Input from ranging module.
'INITIALIZE LCD DISPLAY
Pause 2000 'Pause for the LCD display/driver backpack to initialize.
'VARIABLES
TIMEOFFLIGHT var word 'Echo variable from ranging module.
DISTANCE var word 'Working variable for calculating distance.
'CONSTANTS
ECHO con 15 'Ranging module echo result.
INIT con 14 'Ranging module control.
SETTLE con 1 'Delay to ensure proper ranging module initialization.
DELAY con 2000 'Time between sonar samples - in milliseconds.
CONVFACT con 74 'Result in inches. See CONVERSION FACTORS below.
OFFSET con 700 'Delay between start of sonar reading and measurement of result
- prevents false measurement.
MAIN_LOOP:
Gosub PING_CALC
Serout 0,$4054,[noparse][[/noparse]254,1] 'Clear the LCD display and reset cursor position.
Pause 2 'Pause for LCD display to clear and cursor position to reset.
Serout 0,$4054,[noparse][[/noparse]"DISTANCE: ",dec3 DISTANCE,"in"] 'Send the title and distance
result to the LCD display.
Pause DELAY 'Time between sonar samples.
Goto MAIN_LOOP
PING_CALC:
High INIT
Pause SETTLE
Rctime ECHO,0,TIMEOFFLIGHT
Low INIT
'DISTANCE FORMULA AND CONVERSION FACTORS
'Distance = (timeofflight + offset time) / (conversion factor)
'Use 74 as a conversion factor for inches. (73.764 microseconds per in.)
'Use 29 as a conversion factor for centimeters. (29.033 microseconds per cm.)
DISTANCE=(TIMEOFFLIGHT+OFFSET)/CONVFACT
Return
Tim
'VARIABLES
'CONSTANTS
MAIN_LOOP:
Gosub PING_CALC
Goto MAIN_LOOP
PING_CALC:
High INIT
Pause SETTLE
Low INIT
Return
Thank you for sharing that code. Verrrrrrrrry interesting!
Is that 2 second delay between sonar samples required
for proper ranging? Is it there to let the batteries 'rest'
between firings?
I'm wondering, given a supply with enough oomph, how
fast one can get back to back readings.
Steve
As I mentioned, this code is an example from Acroname Robotics. I've added
the 2 second delay for testing purposes - the module is capable of taking
samples every 20 miliseconds.
Tim
From: PicProgrammer@a... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9KUdF9SPQIMYd4o17S29oXgq86RjT6KUs_BlQZTtdvLEx9U0SyEGmRfPGm6uK63gkh0RgiKFwAwCsOs]PicProgrammer@a...[/url
Sent: Wednesday, November 29, 2000 11:46 AM
To: basicstamps@egroups.com
Subject: Re: [noparse][[/noparse]basicstamps] Sonar Code...
Tim,
between firings?
Steve
