Sonar Questions...
Archiver
Hello Everyone,
I've just got my first Polaroid 6500 sonar ranging module up and running
w/a BS2. I know that this topic has been covered many times, but I have a
few questions that I haven't seen covered.
1 - None of the documentation explains just what type of output is provided
from the ranging module to the microcontroller host. The code examples
I've seen use "RCtime" to read the result - leading me to believe that the
output is a resistance proportional to the measured distance. Is this
correct? Would I get more resolution using an ADC to read the module
result?
2 - Polaroid says that the typical absolute accuracy is +/- 1% of the
reading over the entire range. Is this optimistic from the module itself
and, is the BS2 capable of performing the math to make this obtainable?
What have your experiences been? I'm measuring a distance of no more than
10 feet and would like a resolution of +/- 1/8 of an inch if possible and
can settle for +/- 1/4 of an inch.
All of the module modifications listed at Acroname have been performed
and it's running well, but my BS2 math is very week and it would be very
helpful to know just what output is comming from the ranging module. Using
the Acroname code example I'm currently reading to the nearest whole inch.
Thanks for the help and support that all of you are,
Tim Medema
CrystaLite, Incorporated
Everett, Washington
timm@c...
result?
Tim Medema
Everett, Washington
timm@c...
I may be able to help.
To: Basic Stamp List <basicstamps@egroups.com>
Sent: Wednesday, November 29, 2000 5:16 AM
Subject: [noparse][[/noparse]basicstamps] Sonar Questions...
> Hello Everyone,
running
provided
> result?
Using
> Tim Medema
> Everett, Washington
> timm@c...
