More EEPROM? More RAM?
Hello All,
Where can I get more storage space? Is there a way to add extra
memory that the stamp can interface with?
Thank You,
FS :-)
Thank You,
FS :-)
>Hello All,
>Thank You,
>FS :-)
FS -
That all depends on where you're starting from, and for what purpose you
need the memory. Stamps can access external EEPROM or FLASH memeory, if you
are looking for additional data storage. Depending on how you chose to
access it, how large a memory bank you need, how fast you need it to be,
and a few other factors, various resorces are avalable, but more
information will be required.
If you're using a BS-1 or BS-2 and need more program memory, you can
migrate from a BS-1 to BS-2 or a BS-2 to a BS-2X. With each advancement the
speed also increases from 4 MHz to 20 MHz and then 50 MHz.
There is a comparison document explaixng all the specs of each units on the
Parallax Web site [noparse][[/noparse] http://www.parallaxin.com ] in the Documentation
section. RAM increases as well, as follows: BS-1 16 bytes BS-2/BS-2E/BS2-SX
32 bytes.
If you need more information, please be a bit more explicit.
Bruce Bates
I really need more physical storage space. I'm working on a project
that logs huge amounts of data. I'll check around to see what I can
find, including the parallax site!
Thanks again,
FS
--- In basicstamps@egroups.com, Bruce Bates <bvbates@u...> wrote:
> At 02:06 AM 11/27/2000 +0000, you wrote:
> >Hello All,
> >Thank You,
> >FS :-)
> FS -
purpose you
memeory, if you
to
to be,
can
advancement the
units on the
Documentation
2E/BS2-SX
> 32 bytes.
> Regards,
> Bruce Bates
