Interface via RS-232
This isn't strictly a Stamp question but I could be applicable, I
think.
I have a device called Weather Jack that records temperature and
barometric pressure. The values are stored in the device and can be
called by the supplied program.
I would like to make a program that retrieves the values at the
interval that I choose and manupilate the data in the way that I need
it.
I am using Power Basic to write the program and I can not get
the "OPEN COM(x):" function in basic to get the data back out.
All of the parameters, "2400,N,8,1" are correct as well as the cable
to the device. All I really need to do is send a command, "GC" and
wait for a return string of 19 characters but the return characters
never arrive!
Since someone out there probably has experience with RS-232
communications, I am hoping that I can get some answers to this
dilema.
The device in question has just 3 wires to it so there are no control
signals for handshaking. I have tried "OPENING FOR OUTPUT" then
sending the command then "CLOSING" and "OPENING FOR INPUT" but that
did not work.
Any help with this problem would be greatly appreciated.
Thanks in advance for the help.
Dick
think.
it.
never arrive!
dilema.
did not work.
Dick
I am using PowerBasic to communicate between my PC and the bs2:
open "com1: 9600,n,8,1,ds,cs" as #1
'output to bs2
print #1, [noparse][[/noparse]data to transmit goes here]
'input from bs2
if loc(1)>0 then
delay .1
Input_Data$ = input$(loc(1),#1)
end if
Have you tried using the tests for line status (CS, DS, and CD
options) to troubleshoot the problem?
I don't think you can use the "open for input/output" statements.
They only select a com port as the active serial port.
Adolph Stumpf
astumpf@q...
> think.
need
> it.
> never arrive!
> dilema.
control
> did not work.
> Dick
COM(x):2400,N,8,1,CD0,CS0,DS0,RS
I had a similar problem with a particular hardware set-up and this seemed
to solve it. The hardware wouldn't pass data unless software told it to
ignore the handshake lines. You could also tie the handshake lines at
the connector if this is what is causing your problem.
On Sun, 26 Nov 2000 17:21:23 -0000 n2toy@e... writes:
> think.
> need
> it.
> never arrive!
> dilema.
> control
> did not work.
> Dick
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
Can you please send me a example of yours program.I think I can help you.
Regards.
To: <basicstamps@egroups.com>
Sent: Sunday, November 26, 2000 6:21 PM
Subject: [noparse][[/noparse]basicstamps] Interface via RS-232
> think.
> it.
> never arrive!
> dilema.
> did not work.
> Dick
