Help for LCD
Hello
I want to use an LCD serial 2X16 I have bout from the French parallax
representative. The reference is HAC-162J. I use a BS2SX.
My problem is on the LCD panel I have
1 VSS
2 VDD
3 CS
4 SID
5 CLK
6 SOD
7 Power Supply for led
8 Power Supply for led
If I refer to the book of Christian Tavernier I can make it with
Serout 0,N2400,(254,1) but it's does ok
If i refer to scott Edwards I can use
n2400 con 16780 '2400 8 n 1 for the BSX
'n2400 con 16468 ' use this instead for the BS2
I con 254
clr con 1
x var byte
high 8
pause 1000
low 8
pause 1000
high 8
pause 1000
low 8
pause 1000
high 8
pause 1000
low 8
pause 1000
high 8
main:
serout 8, n2400, [noparse][[/noparse]I, CLR]
pause 500
serout 8, n2400, [noparse][[/noparse]I, 207]
serout 8, n2400, [noparse][[/noparse]"What are you looking at?"]
gosub scroll
goto main
scroll:
for x = 1 to 39
PAUSE 200
serout 8, n2400, [noparse][[/noparse]I, 24]
next
return
If I refer to you I have to change N2400 in 16624.
I have tried many thinks but nothing is OK
Do you have programs to help me
Thank's
I hope you can help me
Buy and have a good day
1 VSS
2 VDD
3 CS
4 SID
5 CLK
6 SOD
I con 254
clr con 1
x var byte
high 8
pause 1000
low 8
pause 1000
high 8
pause 1000
low 8
pause 1000
high 8
pause 1000
low 8
pause 1000
high 8
main:
pause 500
gosub scroll
goto main
scroll:
for x = 1 to 39
PAUSE 200
next
return
Thank's
>Hello
>1 VSS
>2 VDD
>3 CS
>4 SID
>5 CLK
>6 SOD
The line above is fine for a BS-1 as it stands. "N2400" has meaning as the
baudmode.
I Suspect you intended to say BS2-SX, and if that's the case, the correct
baudmode would be n2400 con 17408. This baudmode data comes from the
REVISED Parallax BS-2SX manual Ver 1.5 which is a quite recent revision.
In the instance shown above, n2400 is being used as a CONSTANT and NOT a
KEYWORD as it is in the BS-1 example above.
See above regarding the baudmode constant.
>I con 254
>clr con 1
>x var byte
>high 8
>pause 1000
>low 8
>pause 1000
>high 8
>pause 1000
>low 8
>pause 1000
>high 8
>pause 1000
>low 8
>pause 1000
>high 8
>main:
>pause 500
>gosub scroll
>goto main
>scroll:
>for x = 1 to 39
>PAUSE 200
>next
>return
Try changing the baudmode, as noted above. This was a recent change in the
manual, since the manual was in error. You may also want to download the
new BS-2SX manual from the Parallax website site
[noparse][[/noparse] http://www.parallaxinc.com ] in the documentation section.
>Thank's
I hope I did : )
Bye, and you as well
Bruce Bates
I don't know this LCD serial display but, because it has a CLK pin,
I think that this is a synchronous serial device.
Try to use Shiftout in place of Serout.
Regards
ECO
To: <basicstamps@egroups.com>
Sent: vendredi 24 novembre 2000 07:44
Subject: Re: [noparse][[/noparse]basicstamps] Help for LCD
> At 09:14 PM 11/23/2000 +0100, you wrote:
> >Hello
> >1 VSS
> >2 VDD
> >3 CS
> >4 SID
> >5 CLK
> >6 SOD
> baudmode.
> >I con 254
> >clr con 1
> >x var byte
> >high 8
> >pause 1000
> >low 8
> >pause 1000
> >high 8
> >pause 1000
> >low 8
> >pause 1000
> >high 8
> >pause 1000
> >low 8
> >pause 1000
> >high 8
> >main:
> >pause 500
> >gosub scroll
> >goto main
> >scroll:
> >for x = 1 to 39
> >PAUSE 200
> >next
> >return
> >Thank's
> I hope I did : )
> Regards,
> Bruce Bates
The LCD is from BG Micro, part number LCD 1012.
It has a 2x40 character display.
I need LCD board pinout information.
It has two ribbon cables with 14 wires soldered to the board.
This LCD was probably originally in a copier.
The controller chip is a Sanyo LC7985NA.
Anyone have this running on a Stamp?
-Mike
A suggestion, how about if its possible, you take a photo of the
thing, and upload the photo to that section of the group site, and
provide a pointer to it? Someone might recognize it. For example that
controller name seems to be one I know, but I can't remember where. It
might be, that it is a touch-screen enabled device, that's a good
thought. BG Micro just makes embedded controllers. Or made, I haven't
seen them around lately. The actual LCD might be made by any of
several thousand names.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
> From: Trygve Henriksen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Ft03FtEoR2ocF_oE-QD1dk05_SwcntH3wowF6TtIROnboUB6HUborF6J6v18IUTOjaorFXEnhFQhWpZNhQHYaaalfOXs]trygve.henriksen@v...[/url
> Sent: Wednesday, April 14, 2004 5:55 AM
> Subject: SV: [noparse][[/noparse]basicstamps] Help for LCD
> Greetings!
> I can't help with the BG Micro part number, but the controller's
> datasheet can be found here:
> http://service.semic.sanyo.co.jp/semi/ds_pdf_e/LC7985NA.pdf
> The fact that there are 2 ribbon cables may indicate that it has a
> touch-screen function.
> (Does it have a plastic membrane?)
> If you can't find the pinout anywhere, I suggest you trace the pins
from
> the ribbon cables and see which connects to the controller chip and
to
> which pins.
> (Shouldn't be too difficult if you have a multimeter with a beeper)
> Trygve
Opprinnelig melding
> Fra: Mike [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Uqo5gyIYXzRaCIsJtSct9HUt1uR6LwKrGyfkLZwID1J0S3J3QatCJwW31pJv7_voE7YG_FioJcGvv8tK]mikegotis@y...[/url
> Sendt: 14. april 2004 06:15
> Til: basicstamps@yahoogroups.com
> Emne: [noparse][[/noparse]basicstamps] Help for LCD
> to all:
> -Mike
Thanks for the information, suggestions, and
link to the data sheet for the Sanyo
LC7985NA controller chip that's on the LCD.
Apparently, the chip is HD44780 compatible according to
a use group posting. Today I found the spec sheet sent by
BG Micro for a DMC40218 made by Optrex. I think they're
telling me to substitute. It looks like both data sheets can
be used for pin assignment.
There is no plastic membrane, and each ribbon cable
has 7 wires. Apparently it has no touch screen.
However, the DMC40218 also has 14 controlling pins.
I thought about tracing the pins to the smt chip, but I might
need a microscope to do that! So do you sharpen your
meter probes to a needle tip to trace that? I don't know if
the smt's are getting smaller or if my eyes are getting older
(or both!).
Since BG Micro sold these from bulk surplus in mass
quantities at $5.95 to hobbyists, I was hoping someone had
already interfaced it to a stamp microcontroller.
Here's what I have so far for pinouts, in case someone can
comment on interfacing to a BS1 or BS2. It looks standard
except I'm not sure about pin 3.
1 - Vss (0V GROUND)
2 - Vcc (+5V) SUPPLY VOLTAGE FOR LOGIC
3 - Vee (?V) SUPPLY VOLTAGE FOR LCD DRIVE
4 - RS REGISTER SELECT
5 - R/W READ/WRITE (H: DATA READ L: DATA WRITE)
6 - E ENABLE SIGNAL
7 - DB0 DATA BUS LINES
8 - DB1
9 - DB2
10 - DB3
11 - DB4
12 - DB5
13 - DB6
14 - DB7
-Mike
--- In basicstamps@yahoogroups.com, "Trygve Henriksen" <
trygve.henriksen@v...> wrote:
> Greetings!
> If you can't find the pinout anywhere, I suggest you trace the pins from
> the ribbon cables and see which connects to the controller chip and to
> which pins.
> Trygve
Opprinnelig melding
> Fra: Mike [noparse][[/noparse]mailto:mikegotis@y...]
> to all:
> -Mike
back light, if there is one on the unit). Try a 1meg pot between Vdd
and Vss, center tap to Vee and see where you need to be.
Oh, if there is a backlight watch your current, they suck monster loads
(160ma+) and need current limiting resistors in series with the supply.
Don't run it from the Stamp's onboard voltage regulator.
Regards, John.
--- Mike <mikegotis@y...> wrote:
> Trygve and Gregg,
> (or both!).
> 1 - Vss (0V GROUND)
> DATA WRITE)
> 6 - E ENABLE SIGNAL
> 8 - DB1
> 9 - DB2
> 10 - DB3
> 11 - DB4
> 12 - DB5
> 13 - DB6
> 14 - DB7
> -Mike
> > Greetings!
> from
> to
> > which pins.
> > Trygve
Opprinnelig melding
> > to all:
> > -Mike
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online by April 15th
http://taxes.yahoo.com/filing.html
Cool!
I look forward to implementing the LCD.
You provided the last puzzle piece!
-Mike
jrem <jrem123@y...> wrote:
> Vee is the drive for the display, it controls the contrast (not the
> Vdd and Vss, center tap to Vee and see where you need to be.
> Regards, John
More detective works shows the display is
manufactured by OPTREX
and is model number DMC50037N
-Mike
It's nice know I was right about the whole process, and especially
your display.
Thanks, that confirms one theory about LCD displays. Especially that
one. Okay, here's how I found out about a related device, also an
Optrex one, Google. I then discovered the Optrex site,
http://www.optrex.com/splash.asp After that revolting splash screen,
you'll be able to find out about your display.
A word of warning, their site, was not designed by the same sort of
people who built the Parallax one. I think that one, is a display
that's similar to the big ones used in laptops. Same bitmapped display
process.
You are making good progress, and I believe you should make photos
available when you are done.
> From: Mike [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3C-NyXAYv69pWCQ1CM1L9ytHGw_lZAAUFTbD6tpW5_dKiZ6pQ1o5fY5axLySJBlUgi-t6C5GbNiakWlYHU0]mikegotis@y...[/url
> Sent: Saturday, April 17, 2004 4:24 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Help for LCD
> Greg,
> -Mike
