DC-AC
Use a diode 1N4007 or similar in paralell with relay coil (in reversed
position) to protect transistor from back emf spike when coil is turned off.
ACJacques
At 16:48 20/11/00 +0000, you wrote:
>Hello Everyone,
>I really have not done much with AC before, but now I have a need. I
>want to switch AC on and off using the stamp. What I'm going to try
>is switch it on with a relay. It is a relay that I picked up from
>Radio Shack that turns on at 5V. Its contacts are rated at 120VAC
>and 24VDC.
>I have a transistor switching on the power supply for the relay. Are
>there any precautions I should take when using AC like this? Will I
>blow something up?
>Thanks,
>FS
ACJacques
>Hello Everyone,
>and 24VDC.
>blow something up?
>Thanks,
>FS
and 24VDC.
blow something up?
FS
- The Led of the SSR is connected to a Stamp pin through a resistor, that's
all.
- The load is then driven by the Triac of the SSR.
Reference S212S01 Sharp.
