RS232 Steering
Archiver
Jay-
Is the PC<-->device data in small enough chunks that your Stamp
could serve to relay the data between the two? If so, the Stamp
could sandwich its own data between the PC's data and use flow
control pins to turn the PC and device data xmit functions on/off as
needed. In essence, you'd be implementing an analog OR via your
Stamp program.
Steve
On 19 Nov 00 at 17:05, Jay Kay wrote:
> I need to talk to a device with a 232 port with the Stamp. I also
> need to talk to this same 232 port with a PC since it has other
> software running that the device understands. So I am stuck in an
> analog OR situation. (Note..I'm not concerned about levels since I
> can use the Maxim 232A chip to get everything to 5VDC)
> I need a chip (or circuit) that can be set to be enable to pass the
> 232 data from the PC to the 232 port and disable the Stamp output
> during the XMIT time...and visa versa. I was thinking of using the
> RTS line of the PC to disable any Stamp data being sent and using a
> port on the Stamp to create an RTS to disable the PC path to the 232
> port.
> Maxim has a family of chips (MAX200-250) that may perform these
> functions.
> Has anybody been this way? Any suggestions?
> Thanks in advance
> Jay
Stamp program.
Steve
> port.
> functions.
> Thanks in advance
> Jay
talk to this same 232 port with a PC since it has other software running
that the device understands. So I am stuck in an analog OR situation.
(Note..I'm not concerned about levels since I can use the Maxim 232A chip to
I need a chip (or circuit) that can be set to be enable to pass the 232
data from the PC to the 232 port and disable the Stamp output during the
XMIT time...and visa versa. I was thinking of using the RTS line of the PC
to disable any Stamp data being sent and using a port on the Stamp to
create an RTS to disable the PC path to the 232 port.
Maxim has a family of chips (MAX200-250) that may perform these functions.
Thanks in advance
Jay
>I need to talk to a device with a 232 port with the Stamp. I also need to talk
to this same 232 port with a PC since it has other software running that the
device understands. So I am stuck in an analog OR situation. (Note..I'm not
concerned about levels since I can use the Maxim 232A chip to get everything to
5VDC)
>I need a chip (or circuit) that can be set to be enable to pass the 232 data
from the PC to the 232 port and disable the Stamp output during the XMIT
time...and visa versa. I was thinking of using the RTS line of the PC to disable
any Stamp data being sent and using a port on the Stamp to create an RTS to
>Thanks in advance
>Jay
Hi Jay -
>Take a look at the MAX-334 that may work.
Bruce Bates
I got the following regarding handling 2 RS232 ports into one.
"If you want a two input, out output device that automatically connects an
active input to the output, it's a commonly used item known as a modem
sharing device or MSU. These are available in passive or active versions,
with the passive one being a simple diode network, the active ones actually
have some electronics in them."
Anyone familiar with the diode approach?
Jay
help me with the interface of the microcontroller to a computer? also we are
planning to use tranceivers to send and receive data at the computer. so my
question is where do i start?
thank you.
>From: "S Parkis" <parkiss@e...>
>Reply-To: basicstamps@egroups.com
>To: "Jay Kay" <pcb4u@e...>, basicstamps@egroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] RS232 Steering
>Date: Sun, 19 Nov 2000 19:21:52 +0800
>Jay-
>Stamp program.
>Steve
> > port.
> > functions.
> > Thanks in advance
> > Jay
________________________________________________________________________________\
_____
Get more from the Web. FREE MSN Explorer download : http://explorer.msn.com
