Beginners Question
I want to develope my application on a Basic Stamp
IISX. After I have developed my application I want to
produce multiple copies of the code in other stamp
chips. Is my desire feasible?, Can I actually "burn"
instructions into other chips so that I can "mass"
produce my development.
--- basicstamps@egroups.com wrote:
> There are 8 messages in this issue.
> Topics in this digest:
> 1. RE: A beginner's question
> From: "Eric Schettler"
> <schettlee@p...>
> 2. Re: A beginner's question
> From: "Doug Simpson"
> <veewee77@a...>
> 3. Re: BoEBoT & Polariod 6500
> From: "john & lisa"
> <johnlisa@c...>
> 4. RE: (unknown)
> From: Brian Gillis <Brian@G...>
> 5. Polariod 6500 &BSII
> From: "john & lisa"
> <johnlisa@c...>
> 6. Re: Basic Stamp Emulator
> From: "victor faria" <victorf@g...>
> 7. Re: (unknown)
> From: Todd Botner <contacttodd@y...>
> 8. PIC16C505
> From: "Ken J" <kenj@m...>
________________________________________________________________________
> Message: 1
> Date: Sun, 12 Nov 2000 17:24:12 -0600
> From: "Eric Schettler" <schettlee@p...>
> Subject: RE: A beginner's question
> Also, if you continue to have problems, contact
> Parallax. I was having the
> exact same problem. Parallax gave me several things
> to try. None of them
> worked, so I shipped my stamp back to them, and they
> sent me a brand new
> one. This one works wonderfully!! You may want to
> try it. I'm sure they
> will test the new chips they send you since you're
> sending them in once.
> That way you also know that you have working stamps.
> Eric
> From: pgmelton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1ZaaTOlIdPkC6iMoqV97B-Ws-R2QB4BqxMjzlW8eYMbYTu-Y5RR1Kqr8ii_tBdBXvZkkkZ6gHss]pgmelton@m...[/url
> Sent: Sunday, November 12, 2000 4:00 PM
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] A beginner's question
> Hello,
> 1. make sure that your basic stamp editor has com1
> selected ( if so go to
> next step)
> 2. make com1 port of computer is funtional and is
> indeed your active com
> port, before you go trying hardware fixes try using
> com2 in stamp editor
> If those two tips don't work call out the calvary.
> The Stamp pros will come
> to rescue.
> good luck,
> Peter
> From: <jgillman@s...>
> To: <basicstamps@egroups.com>
> Sent: Sunday, November 12, 2000 4:23 PM
> Subject: [noparse][[/noparse]basicstamps] A beginner's question
> > Hello, I have a very basic question. I have 2
> brand new BS2s that I
> > mounted on the educational board that I bought
> from Parallax, and I'm
> > using their serial cable. I had never used one
> before, so I wanted to
> > simply run one of the example programs that I see
> on their website.
> > Unfortunately, I'm having trouble downloading the
> code onto the
> > board.
> > I'm getting an error that says "Basic Stamp 2
> detected but not
> > responding on COM1. Check Power Supply." The power
> supply I'm using
> > is
> > a 9v battery and there's nothing wrong with it.
> I'm also positive
> > that
> > the stamp is oriented correctly on the board.
> > I have tried using both the Win9x/NT editor, and
> the DOS version. I
> > tried these both on a computer running Windows NT,
> and one running
> > Win98. I tried changing the preferences in the
> stemp editor I have (v
> > 1.096) and added the comment that the readme
> suggests ( '{$STAMP BS2}
> > )...When I called tech support they suggested I
> change the editor
> > operation settings and the debug port settings. I
> also went in and
> > made sure that the serial port was enabled rather
> than being auto in
> > the computers setup. None of this worked. I tried
> swapping cables and
> > using a different BS2, but I get the same error
> with both.
> > The baud speed and parity bits etc etc are all
> matched. I closed all
> > programs but the systray and explorer (and the
> editor) and got the
> > same error. I know the COM port works just fine,
> as I was able to set
> > up a hyperterminal connection to a seetron LCD
> that I would
> > eventually like to drive with the stamp.
> > I know this seems like a really stupid question,
> but I'm all out of
> > ideas for what to change to make this work. Any
> suggestions?
> > Thanks,
> > Jason
> Message: 2
> Date: Sun, 12 Nov 2000 17:40:26 +0000
> From: "Doug Simpson" <veewee77@a...>
> Subject: Re: A beginner's question
> From the stamp software in windows:
> Edit
> Preferences
> Edditor Operation
> Set to tge model of your stamp.
> doug
> > From: jgillman@s...
> > Date: Sun, 12 Nov 2000 21:23:55 -0000
> > Reply-to: basicstamps@egroups.com
> on their website.
> code onto the
> > board.
> detected but not
> supply I'm using
> > is
> I'm also positive
> > that
> the DOS version. I
> and one running
> change the editor
> also went in and
> than being auto in
> swapping cables and
> with both.
> editor) and got the
> that I would
> but I'm all out of
> suggestions?
> > Thanks,
> > Jason
> Message: 3
> Date: Mon, 13 Nov 2000 02:34:11 -0000
> From: "john & lisa" <johnlisa@c...>
> Subject: Re: BoEBoT & Polariod 6500
> Thanks Tracy, I'm still working on it, I moved the
> 6500 board a fair
> distance from the stamp board and it did sort the
> problem, so a metal
> enclosure it looks like it'll have to be, but
> getting a custom built box is
> impossible due to size limitations, and getting
> sheet metal out here in
> Cyprus is impossible, and so is sheet plastic, so
> making my own custom box
> will be hard to do. I'm currently trying thin card
> with tin foil glued to it
> (mostly my fingers at the mo) I'll keep you posted.
> Many Thanks
> John
> From: Tracy Allen <emesys@c...>
> Sent: Sunday, November 12, 2000 6:23 PM
> Subject: [noparse][[/noparse]basicstamps] BoEBoT & Polariod 6500
> > >Thanks to Tracy Allen with your ideas regarding
> interference from the
> 6500
> > board.
> > >I tried your idea but it seemed to have no effect
> what's so ever.
> > >It was worth a try. I also tried the different
> tie in points for the
> > ground
> > >wire but this has no effect. I just have to keep
> trying. The only ideas I
> > >can come up with is putting the 6500 board in a
> metal enclosure, but
> there
> > just
> > >is not enough room on the BoEBoT for this.
> > >Thanks anyway Tracy.
> > Hi John,
> > Oh, well. Can you detach the 6500 completely from
> the stamp and make it
> > ping on its own power supply and its own wiring.
> Have a program running
> on
> > the stamp at the same time. Does the operation of
> the 6500 still affect
> > the stamp?
> > If so, then it is time to work on that shielding.
> That might be as simple
> > as some heavy duty aluminum foil (with some
> plastic insulator!?) wrapped
> > around it and grounded to the chassis.
> > If you can ping the 6500 without it affecting the
> stamp, then the problem
> > is more than likely coming in through the wiring.
> Put resistors in the
> > leads that go from the stamp pins to the 6500.
> Surges can sneak in
> through
> > the signal lines. Also, run the power line
> through a shield. Also, run
> > the signal and excitation lines through a shield.
> You can purchase metal
> > braided shield that you can attach to ground at
> one end only. Keep at
> it!!
> > -- Tracy
> Message: 4
> Date: Sun, 12 Nov 2000 17:03:21 -0800
> Subject: RE: (unknown)
> Do you know that you are sending out a virus in your
> e-mails??
> Go to
> http://wwww.antivirus.com
> From: bkatakis@m...
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cW2jS7kolu2jEU1Z5jgJsz__5_ZS_r20_ZrAWmY4R4KohV-0NirrKWQf7lcigoa01_iB4jw-87MhnjS8Gg]bkatakis@m...[/url
> Sent: Sunday, November 12, 2000 9:46 AM
> Subject: [noparse][[/noparse]basicstamps] (unknown)
> Message: 5
> Date: Mon, 13 Nov 2000 03:21:47 -0000
> Subject: Polariod 6500 &BSII
> Thanks to all who tried to help with the
> interference problem with the above said items.
> The only way to fix it, well two ways, if you have a
> big enough robot keep the well apart
> if not then seal the 6500 in a metal box. If you
> can't get a hold of any sheet metal as finding a
> small enough box just to shield the 6500 is not
> easy, then do as I did and make a box from thin card
> with a layer of tin foil (baking foil, what ever you
> call it) use a thin sheet of plastic from an ice
> cream tub on the base of the box fitted underneath
> the 6500 board. Then connect a wire from the tin
> foil box, the wire been held in place with a staple,
> to the negative supply of your power pack. Hey
> presto! interference problem sorted.
> Thanks again everybody to tried to help.
> John
> [noparse][[/noparse]This message contained attachments]
> Message: 6
> Date: Sun, 12 Nov 2000 21:30:32 -0500
> Subject: Re: Basic Stamp Emulator
> look here http://www.al-williams.com
> From: "Octavio P Nogueira"
> <octaviopnogueira@u...>
> Sent: Sunday, November 12, 2000 4:24 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Basic Stamp Emulator
> > > Try the download page at Parallax I'm sure the
> source code is there but
> > > can't remember if it's for the BSI or II
> > > John
> > NO, for sure it's NOT!!!!!!!!
> > Friendly Regards
> > Octavio Nogueira
> > nogueira@p... ICQ#
> 19841898
> > ProPic tools - low cost PIC programmer and
> emulator
> > http://www.propic2.com
> > Sent: Sunday, November 12, 2000 6:10 AM
> > > From: <gerry_shand@t...>
> > > Sent: Saturday, November 11, 2000 11:28 PM
> > > Subject: [noparse][[/noparse]basicstamps] Basic Stamp Emulator
> > > > A long time ago, in the foggy recesses of my
> memory, someone had told
> me
> > > that
> > > > "rolling your own" basic stamp II was easy.
> Get the parts, assemble
> and
> > > then
> > > > insert some source code.
> > > > I was wondering if anyone out there had this
> source code available or,
> > as
> > > an
> > > > alternative, knew of a program compiler out
> there that would take in
> BS2
> > > > computer commands and turn them into PIC?
> > > > Did not find anything on the parallax or
> microchip websites so I was
> > > curious.
> > > > Thanks in advance for your help.
> > > > Regards,
> > > > Gerry Shand
> > > > gerry_shand@t...
> Message: 7
> Date: Sun, 12 Nov 2000 19:06:52 -0800 (PST)
> Subject: Re: (unknown)
> Hello,
> Just for your information, you have sent out a
> virus.
> You may want to inspect your computer as you could
> have already done damage.
> Just thought you would want to know.
> Regards,
> Todd
> Do You Yahoo!?
> Yahoo! Calendar - Get organized for the holidays!
> http://calendar.yahoo.com/
> Message: 8
> Date: Mon, 13 Nov 2000 04:14:33 +0100
> Subject: PIC16C505
> Hello
> I wonder if anybody know if there exist any servo
> and dc-motor control schematics that use the
> PIC16C505 chip?
> The reason to use this chip is because it is wery
> cheap where I live.
> Another question where I live there exist only two
> places that sell´s Basic Stamp II products, but they
> do not sell any OEM Basic Stamp II and I was
> thinking about building me one.
> But there have to be a firmware program in the chip
> what I understand, so now to the question´s where do
> I find the Firmware code? And do I have to program
> the chip before I solder or put the chip on to the
> pcb with the rest of the components?
> Regards Ken J
> kenj@m...
Kevin A. Bruff
kbruff@y...
Do You Yahoo!?
> <schettlee@p...>
> <veewee77@a...>
> From: "john & lisa"
> <johnlisa@c...>
> 4. RE: (unknown)
> From: "john & lisa"
> <johnlisa@c...>
> 7. Re: (unknown)
> 8. PIC16C505
> Message: 1
> sent me a brand new
> Eric
> Hello,
> next step)
> to rescue.
> good luck,
> Peter
> on their website.
> code onto the
> > board.
> detected but not
> supply I'm using
> > is
> I'm also positive
> > that
> the DOS version. I
> and one running
> change the editor
> also went in and
> than being auto in
> swapping cables and
> with both.
> editor) and got the
> that I would
> but I'm all out of
> suggestions?
> > Thanks,
> > Jason
> Message: 2
> Edit
> Preferences
> Edditor Operation
> doug
> > From: jgillman@s...
> on their website.
> code onto the
> > board.
> detected but not
> supply I'm using
> > is
> I'm also positive
> > that
> the DOS version. I
> and one running
> change the editor
> also went in and
> than being auto in
> swapping cables and
> with both.
> editor) and got the
> that I would
> but I'm all out of
> suggestions?
> > Thanks,
> > Jason
> Message: 3
> 6500 board a fair
> problem, so a metal
> Many Thanks
> John
> 6500
> > board.
> what's so ever.
> > ground
> there
> > just
> > Hi John,
> on
> > the stamp?
> Surges can sneak in
> through
> it!!
> > -- Tracy
> Message: 4
> e-mails??
> Go to
> From: bkatakis@m...
> Message: 5
> John
> Message: 6
> > > John
> > Friendly Regards
> > Octavio Nogueira
> > nogueira@p... ICQ#
> 19841898
> emulator
> me
> > > that
> and
> > > then
> > as
> > > an
> BS2
> > > curious.
> > > > Regards,
> > > > Gerry Shand
> > > > gerry_shand@t...
> Message: 7
> Hello,
> virus.
> Regards,
> Todd
> Do You Yahoo!?
> Message: 8
> Subject: PIC16C505
> Hello
> PIC16C505 chip?
> cheap where I live.
> Regards Ken J
> kenj@m...
Kevin A. Bruff
kbruff@y...
Do You Yahoo!?
You can check out Tracy Allen's site for the Stache, micro-programmer
for the BASIC Stamp II.
His site : http://www.emesystems.com/
then look for the "Stache micro-Programmer"
I don't know if it is set up for the SX chip, but you can start by
checking out his pages.
If you are wondering if you can prototype on the Stamp IISX then port
your PBasic over to a PIC, the simple answer is NO. PBaxsic is
proprietary to the Stamp product line. You would have to re-code in
another language.
Dave
> > <schettlee@p...>
> > <veewee77@a...>
> > From: "john & lisa"
> > <johnlisa@c...>
> > 4. RE: (unknown)
> > From: "john & lisa"
> > <johnlisa@c...>
> > 7. Re: (unknown)
> > 8. PIC16C505
> > Message: 1
> > sent me a brand new
> > Eric
> > From: pgmelton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6Yw5ug2w1QHZjkbTzXrhnHAYMZQSrMPjEr2W6CTgwBLbi6gcXEJM2gHy48KyVknCHrf5JQRfTg]pgmelton@m...[/url
> > Hello,
> > next step)
> > to rescue.
> > good luck,
> > Peter
> > on their website.
> > code onto the
> > > board.
> > detected but not
> > supply I'm using
> > > is
> > I'm also positive
> > > that
> > the DOS version. I
> > and one running
> > change the editor
> > also went in and
> > than being auto in
> > swapping cables and
> > with both.
> > editor) and got the
> > that I would
> > but I'm all out of
> > suggestions?
> > > Thanks,
> > > Jason
> > Message: 2
> > Edit
> > Preferences
> > Edditor Operation
> > doug
> > > From: jgillman@s...
> > on their website.
> > code onto the
> > > board.
> > detected but not
> > supply I'm using
> > > is
> > I'm also positive
> > > that
> > the DOS version. I
> > and one running
> > change the editor
> > also went in and
> > than being auto in
> > swapping cables and
> > with both.
> > editor) and got the
> > that I would
> > but I'm all out of
> > suggestions?
> > > Thanks,
> > > Jason
> > Message: 3
> > 6500 board a fair
> > problem, so a metal
> > Many Thanks
> > John
> > 6500
> > > board.
> > what's so ever.
> > > ground
> > there
> > > just
> > > Hi John,
> > on
> > > the stamp?
> > Surges can sneak in
> > through
> > it!!
> > > -- Tracy
> > Message: 4
> > e-mails??
> > Go to
> > From: bkatakis@m...
> > [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_JnJbRpWPB5OFFT3gCMmaBC9_ynTV5S7lPvPMvKIFYMyS4xRv5bGZVfZ5kWFNV3swFxP-yXuFO0GLxJbPck]bkatakis@m...[/url
> > Message: 5
> > John
> > Message: 6
> > > > John
> > > Friendly Regards
> > > Octavio Nogueira
> > > nogueira@p... ICQ#
> > 19841898
> > emulator
> > me
> > > > that
> > and
> > > > then
> > > as
> > > > an
> > BS2
> > > > curious.
> > > > > Regards,
> > > > > Gerry Shand
> > > > > gerry_shand@t...
> > Message: 7
> > Hello,
> > virus.
> > Regards,
> > Todd
> > Do You Yahoo!?
> > Message: 8
> > Subject: PIC16C505
> > Hello
> > PIC16C505 chip?
> > cheap where I live.
> > Regards Ken J
> > kenj@m...
> Kevin A. Bruff
> kbruff@y...
> Do You Yahoo!?
