Stamp Inputs
Hello Everyone,
Application:
I'm using two stamp pins as inputs. When pin 0 is high and pin 1 is
high, I'm storing a 3. When pin 0 is high and pin 1 is low then I'm
storing a 1. When pin 0 is low and pin 1 is high, I'm storing a 2.
Problem:
Storing 3 works okay, but I'm getting unreliable results when
checking for 1 or a 2.
Hook-up:
I have a 22K resistor going to pin 0.
I have a diode going from ground to pin 0. (banded end to pin)
I have a SPST momentary switch also going to pin 0. (+5V)
(The same thing is duplicated for pin 1 above)
I have a diode going to the pin 0 circuit with and another diode
going to the pin 1 circuit, both diode with the non-banded ends
conncected to the thrid SPST momentary switch. This swith is also
connected to ground with a diode.
Successful When:
If I press the momemtary SPST switch on pin 0 without pressing the
other two switches, a '1' is registered...etc.
Pressing the thrid switch works great. The third switch makes pin 0
and pin 1 both high.
Question:
Is the probem in the code, or in the hook-up?
Code:
'I have tried many code variations, this is not the most efficient
but simply a desperate variation
INPUT 0
INPUT 1
DEBUG "START",CR
START:
'IF IN0=1 AND IN1=1 THEN THREE
IF IN0=1 THEN ONE
IF IN1=1 THEN TWO
'DEBUG "0",CR
GOTO START
ONE:
debug "At One",cr
IF IN1=1 THEN THREE
DEBUG "1",CR
hold1:IF IN0=1 THEN hold1
'PAUSE 1500
GOTO START
TWO:
debug "At Two",cr
IF IN0=1 THEN THREE
DEBUG "2",CR
hold2:IF IN1=1 THEN hold2
'PAUSE 1500
GOTO START
THREE:
debug "At Three",cr
DEBUG "3",CR
hold3:IF IN0=1 AND IN1=1 THEN hold3
'PAUSE 1500
GOTO START
Application:
Problem:
Hook-up:
Successful When:
Question:
Code:
INPUT 0
INPUT 1
DEBUG "START",CR
START:
IF IN0=1 THEN ONE
IF IN1=1 THEN TWO
'DEBUG "0",CR
GOTO START
ONE:
debug "At One",cr
IF IN1=1 THEN THREE
DEBUG "1",CR
'PAUSE 1500
GOTO START
TWO:
debug "At Two",cr
IF IN0=1 THEN THREE
DEBUG "2",CR
'PAUSE 1500
GOTO START
THREE:
debug "At Three",cr
DEBUG "3",CR
'PAUSE 1500
GOTO START
necessary.
Your program is a lot too complicated, see below.
Input 0
Input 1 'pins 0 and 1 are inputs
loop:
debug dec ? inA & 3 'display input for pins 0 and 1 only
pause 1500
goto loop
To: <basicstamps@egroups.com>
Sent: jeudi 9 novembre 2000 18:57
Subject: [noparse][[/noparse]basicstamps] Stamp Inputs
> Hello Everyone,
> Application:
> Problem:
> Hook-up:
> Successful When:
> Question:
> Code:
> INPUT 0
> INPUT 1
> DEBUG "START",CR
> START:
> IF IN0=1 THEN ONE
> IF IN1=1 THEN TWO
> 'DEBUG "0",CR
> GOTO START
> ONE:
> debug "At One",cr
> IF IN1=1 THEN THREE
> DEBUG "1",CR
> 'PAUSE 1500
> GOTO START
> TWO:
> debug "At Two",cr
> IF IN0=1 THEN THREE
> DEBUG "2",CR
> 'PAUSE 1500
> GOTO START
> THREE:
> debug "At Three",cr
> DEBUG "3",CR
> 'PAUSE 1500
> GOTO START
