A/D project
I'd like to work up a small A/D project. Microchip make stamps with
the A/D inbuilt which sounds great. Is it wise to have some external
regulator to limit the voltage the chip experiences or can I hook the
signal straight uo to the chip.
Thanks in advance
Grant McPherson
Home of the ROVER remote control
www.ozsonic.com
Thanks in advance
Grant McPherson
www.ozsonic.com
CMOS doesn't like over-voltage, so it's good to buffer the signal. I use
a 0 to 5 volt rail-to-rail op amp for that purpose into a 12-bit A/D
converter. Zero is offset to about 2.048 volts with the 12 bits spanning
4.096 volts. I use the PIC to "watch" the drifting signal voltage and
trigger an analog reset towards 2 volts when the voltage gets close to
either rail. The net effect resembles a pong game, with the signal always
bouncing off a rail before it saturates there.
Dennis
To: basicstamps@egroups.com <basicstamps@egroups.com>
Date: Wednesday, November 08, 2000 2:47 PM
Subject: [noparse][[/noparse]basicstamps] A/D project
>Thanks in advance
>Grant McPherson
>www.ozsonic.com
