serin from labview
Group,
Somewhere out there, I have seen a reference to serial port interface
between the Stamp and LabView. I have a project that talks to the Serial
Send from Scott Edwards and even likes Hyperterminal ( no hardware likes
Hyperterminal! ) but it chokes when receiving command strings from
LabView. These are simple one and two character commands. Does anyone out
there have any experience using SERIN 16 commands from a host computer
running LabView?
thanks,
running LabView?
thanks,
Try to place a timedelay between the sending of the bytes from Labview.
Sometimes the PC software sends uot the bytes faster than the BS2 can resive
them.
/Magnus Ohlson
To: <basicstamps@egroups.com>
Sent: Tuesday, November 07, 2000 11:54 PM
Subject: [noparse][[/noparse]basicstamps] serin from labview
> Group,
> running LabView?
> thanks,
> Mike
I assume you output device on the labview is set for rs232 output ?
please provide a little more info - if you got hyprtterm to work there is NO
reason you cant get labview to work - probably serial port configuration
richard
Sent: Tuesday, November 07, 2000 4:54 PM
> Group,
> running LabView?
> thanks,
> Mike
We have tried pacing without much luck.
At 06:29 AM 11/8/00 +0100, you wrote:
>Hi
>resive them.
>/Magnus Ohlson
Thanks for your reply. I did the instrument development in my shop and sent
it away. The end user has the current Parallax's editor, Scott Edwards
Serial Out program, Hyperterminal and even an old DOS version of ProComm
working with the Stamp board at his end. The problem comes when he tries to
issue his one and two character commands from LabView (Ver 5, I think).
Some of the characters make it through, some don't. My code sends him an
"*" after the stamp receives a valid command. It seems that characters are
randomly lost in the transmission. I thought that some experienced LabView
hacker, would have an "Oh, that old serial Stamp problem .... " answer for me.
At 09:12 AM 11/8/00 -0600, you wrote:
>I have experience with lab view and with stamps but no the two together
>richard
>Group,
>running LabView?
>thanks,
>Mike
Mike,
I used a basic stampII in a project where the stamp was used as a process
controller. The basic idea was to have a design that could be controlled from
a manual chassis as well as labview. I must sadly report that the stamp's
reliability wasn't good, in fact, it would send extra characters randomly
(verified
with a serial data analyzer). I'm not saying it can't be done. In this
instance it
didn't work for me. I suspect I was pushing the stamp to it's maximum capacity
or beyond, or there was an interaction between commands that set up the
problem.
My suggested approach to your task would be to insure that you verify all
communications starting with a single character, then two, and so on. A baud
rate burst of multiple characters may overwhelm the stamp unless you use
a small delay to pace the rate of the incoming characters. I doubt your
problems will be with labview, but you must conform labview to the limitations
of the stamp.
Greg Hensley
I appreciate you comments and, I agree sadly, the conclusion that there may
be no quick fix and that the "rough edges" of the Stamp's serial
communication my be my undoing.
I have suggested to the end user that he add a pacing delay between
characters. He isn't happy about this, because he is looking for a time
related event and I had all ready made him accept the variability of using
a serial input for his control.
Thanks again to all who have given comment to this problem.
>Mike,
>(verified
>instance it
>problem.
>of the stamp.
>Greg Hensley
_________________________________
Mike Walsh
walsh@i...
California Institute of Technology
Biology Electronics Shop
MS 216-76
Pasadena, CA 91125
626-395-6825 , FAX 626-584-1654
237 Beckman Behavioral Biology Bldg.
