Cermetek modem code
anyone that has a simple piece of code already written to save me a
little time that works with the CERMETEK modem module from Parallax?
I need the following:
1. when switch is closed, dial a preset number to another computer
with hyperterminal or similar
2. when connected, download stored data from a serial eeprom and a
stamp that is connected by a cord to the modem module with another
stamp (II) as tye modem controller
3. when finished, reset signal sent to device that clears eeprom and
then hangs up.
Know this is simple, but if someone out there in STAMPLAND has
something I can use, would apprecite it
then hangs up.
Go to this site and you can get a sample code for the BS connecting to a cermetek.
http://www.ednmag.com/ednmag/reg/download/files/.../di2411.tx
Chuck Sieveking
DAT Services
Portland OR
From:·· mocenter@erols.com [noparse]/noparse][url=mailto:mocenter@erols.com]mailto:mocenter@erols.com[/url
Sent:·· Monday, November 06, 2000 12:12 PM
To:···· basicstamps@egroups.com
Subject:······· [noparse][[/noparse]basicstamps] CERMETEK MODEM CODE
· anyone that has a simple piece of code already written to save me a
then hangs up.
If you click on the box to register with EDN you can then do the registering process and then you'll have access to the code. Registering is free.
Chuck Sieveking
DAT Services
Portland OR
From:·· norman doty [noparse]/noparse][url=mailto:normdoty@hotmail.com]mailto:normdoty@hotmail.com[/url
Sent:·· Monday, November 06, 2000 12:50 PM
Subject:······· RE: [noparse][[/noparse]basicstamps] CERMETEK MODEM CODE
hey chuck, id like to check out the code also, but i need a login and
password to access the site.
>From: "Sieveking, Charles" <charles.sieveking@dat.com>
>Reply-To: basicstamps@egroups.com
>To: "'basicstamps@egroups.com'" <basicstamps@egroups.com>
>Subject: RE: [noparse][[/noparse]basicstamps] CERMETEK MODEM CODE
>Date: Mon, 6 Nov 2000 12:23:03 -0800
>······ ······· Go to this site and you can get a sample code for the BS
><http://www.ednmag.com/ednmag/reg/download/files/.../di2411.tx>
>······ ······· Chuck Sieveking
>······ ······· DAT Services
>······ ······· Portland OR
>······ ······· ······· ······· From:·· mocenter@erols.com
>······ ······· ······· ······· Sent:·· Monday, November 06, 2000 12:12 PM
>······ ······· ······· ······· To:···· basicstamps@egroups.com
>······ ······· ······· ······· Subject:······· [noparse][[/noparse]basicstamps] CERMETEK MODEM
>CODE
>······ ······· ······· ······· · anyone that has a simple piece of code
>······ ······· ······· ······· little time that works with the CERMETEK
>······ ······· ······· ······· I need the following:
>······ ······· ······· ······· 1. when switch is closed, dial a preset
>······ ······· ······· ······· with hyperterminal or similar
>······ ······· ······· ······· 2. when connected, download stored data from
>······ ······· ······· ······· stamp that is connected by a cord to the
>······ ······· ······· ······· stamp (II) as tye modem controller
>······ ······· ······· ······· 3. when finished, reset signal sent to
>······ ······· ······· ······· then hangs up.
>······ ······· ······· ······· Know this is simple, but if someone out
>······ ······· ······· ······· something I can use, would apprecite it
>······ ······· ······· ······· Thanks
>······ ······· ······· ······· Mike
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
>From: "Sieveking, Charles" <charles.sieveking@d...>
> Chuck Sieveking
> DAT Services
> Portland OR
> From: mocenter@e...
>[noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ijXmVRgpmfVknHxDpWNYNwQmg9Nhbn7JNDDuW-bTVZaJ5rtz8kWmAuioONz7Upw4BJpd30GvoVTw]mocenter@e...[/url
> Sent: Monday, November 06, 2000 12:12 PM
> Subject: [noparse][[/noparse]basicstamps] CERMETEK MODEM
>CODE
> then hangs up.
> Thanks
> Mike
