At 11/3/2000 07:45 PM, you wrote:
>How can I read inputs P12, P13, P14 and P15 as a one instruction parallel
>read?
>Thanx
>Jay
Jay -
Page 214 in the Basic Stamp II Manual shows a memory map with all the data
area and pin names. INA, INB, INC, IND represent each quad, so P12-P15 =
IND as shown in the third column "Nibble Names".
This is a Page with a great deal of importance, and aids in the
understanding of how the internals of the BS-II are constructed.
MH
To: <basicstamps@egroups.com>
Sent: Friday, November 03, 2000 11:03 PM
Subject: Re: [noparse][[/noparse]basicstamps] Parallel Read
> >read?
> >Thanx
> >Jay
> Jay -
> Hope that is what you were seeking.
> Regards,
> Bruce Bates
At 11/3/2000 11:04 PM, you wrote:
>Better call than mine. = )
Just easier to remember : )
>MH
>From: "Bruce Bates" <bvbates@u...>
> > >read?
> > >Thanx
> > >Jay
> > Jay -
> > Regards,
> > Bruce Bates
Where is the best place to get some info on the "bitwise anding", I've heard
of it but after seeing your discussion it looks as if it may save me a lot
of code reading 4 inputs.
thanks in advance,
Chris
Sent: Saturday, November 04, 2000 12:04 PM
> Use the
> varname=ins & %1111000000000000
> That will read the state of the Pins and the bitwise AND will drop all the
> other pins that are unused. Hope that helps.
> MH
> From: "Jay Kay" <pcb4u@e...>
> Sent: Friday, November 03, 2000 10:45 PM
> Subject: [noparse][[/noparse]basicstamps] Parallel Read
parallel
> > read?
> > Thanx
> > Jay
Read Bruce's response... using ins.nibd is much easier, takes less code
space and i would think is faster. There is not a lot on bitwise operatiors
in the stamp manual but here is a brief description...
Bitwise And If both bits are "1" then the result is a 1
1 & 1 = 1
1 & 0 = 0
0 & 0 = 0
0 & 1 = 0
Bitwise OR If either bit is a "1" then the output will be true
0 | 1 = 1
1 | 1 = 1
0 | 0 = 0
Exclusive Or (Xor) If either bit is a "1" then the result is "1". If
both bits are 1 then the result is "0"
1 ^ 0 = 1
1 ^ 1 = 0
0 ^ 0 = 0
0 ^ 1 = 1
So a binary expression of
variable= 10011001 | 01100110 (result is 11111111)
Hope that helps.
MH
Sent: Friday, November 03, 2000 11:46 PM
heard
> thanks in advance,
> Chris
> From: Michael Hendricks <mjh80@b...>
> > Use the
the
> > MH
> parallel
> > > read?
> > > Thanx
> > > Jay
Many thanks...
Sent: Saturday, November 04, 2000 1:06 PM
operatiors
> 1 & 1 = 1
> 1 & 0 = 0
> 0 & 0 = 0
> 0 & 1 = 0
> 0 | 1 = 1
> 1 | 1 = 1
> 0 | 0 = 0
If
> 1 ^ 0 = 1
> 1 ^ 1 = 0
> 0 ^ 0 = 0
> 0 ^ 1 = 1
> Hope that helps.
> MH
> From: "Chris Anderson" <fes@g...>
> heard
lot
> > thanks in advance,
> > Chris
> > > Use the
> the
> > > MH
> > parallel
> > > > read?
> > > > Thanx
> > > > Jay
>read?
>Thanx
>Jay
Jay -
Bruce Bates
MH
> read?
> Thanx
> Jay
MH
> >read?
> >Thanx
> >Jay
> Jay -
> Regards,
> Bruce Bates
>MH
> > >read?
> > >Thanx
> > >Jay
> > Jay -
> > Regards,
> > Bruce Bates
thanks in advance,
Chris
> Use the
> MH
parallel
> > read?
> > Thanx
> > Jay
1 & 1 = 1
1 & 0 = 0
0 & 0 = 0
0 & 1 = 0
0 | 1 = 1
1 | 1 = 1
0 | 0 = 0
1 ^ 0 = 1
1 ^ 1 = 0
0 ^ 0 = 0
0 ^ 1 = 1
Hope that helps.
MH
heard
> thanks in advance,
> Chris
> > Use the
the
> > MH
> parallel
> > > read?
> > > Thanx
> > > Jay
it doesn't jump right at ya!!
Jay
modified with bit, highbyte, nib, etc just like any other variable...
MH
Sent: Saturday, November 04, 2000 12:24 PM
> Thanks to all with their suggestions on reading parallel data. To a new
user
> Jay
operatiors
> 1 & 1 = 1
> 1 & 0 = 0
> 0 & 0 = 0
> 0 & 1 = 0
> 0 | 1 = 1
> 1 | 1 = 1
> 0 | 0 = 0
If
> 1 ^ 0 = 1
> 1 ^ 1 = 0
> 0 ^ 0 = 0
> 0 ^ 1 = 1
> Hope that helps.
> MH
> heard
lot
> > thanks in advance,
> > Chris
> > > Use the
> the
> > > MH
> > parallel
> > > > read?
> > > > Thanx
> > > > Jay
