Connection problem
From the Windows version of the PC software,
Edit
Preferences
Editor Operation
and choose your model of stamp.
D.S.
> To: basicstamps@egroups.com
> From: tdnst4@p...
> Date: Thu, 02 Nov 2000 22:27:38 -0000
> Reply-to: basicstamps@egroups.com
> Subject: [noparse][[/noparse]basicstamps] Connection problem
> Hello,
> Here's a very newbie question for my initial post:
> I have a problem with my connection for my STAMP-1 system. I have it
> connected via my 25 pin parallel port (to pins 2,11,25), and it is
> plugged into the carrier board with the 9V battery attached. However
> whenever I try to run any programs, I keep getting a "ERROR <>
> Hardware not found" message. I can't figure out what the problem is.
> I
> checked all connections with a multimeter, and they seem to be in
> order, but I am pretty ignorant when it comes to port setting on a
> computer. Does anyone know what could be the problem?
> -Tim Nolan
> University of Pittsburgh
Edit
Preferences
Editor Operation
D.S.
> From: tdnst4@p...
> Hello,
> I
> -Tim Nolan
I
-Tim Nolan
specifically for the BS1. (assuming you haven't already done that.)
Then, here is a trick question. . . Is the computer fairly new? If
so, go into the BIOS and see what type of port it actually is.
The coices will be somethng like:
normal
bi-directional
ECC
EPP
and variations.
Try normal and bi-directional and see what happens.
Another stupid question. . .
Do you have a printer? What brand and model? Some of them wish to
stay connected and 'talking' to a printer, and if you have one of
these it may be jacking with the parallel port trying to 'talk' to
the printer as you are trying to talk to the stamp.
Doug
> From: tdnst4@p...
> Date: Fri, 03 Nov 2000 16:50:21 -0000
> Subject: [noparse][[/noparse]basicstamps] Re: Re: Connection problem
> Thanks DS, but the windows version doesn't seem to run on the parallel
> port, or with the STAMP-1. I am using the DOS version, as the only
> version I can find for the BS-1 device.
> I still can't connect, is there a way to debug the connection in the
> DOS program?
> > Edit
> > Preferences
> > Editor Operation
> > D.S.
DOS program?
> Edit
> Preferences
> Editor Operation
> D.S.
