Serial keyboard interface
Does anyone know if there is a serial keyboard interface available
for the stamp or does anyone have ideas how it could be done?
Peter Jenkins
Data Analyst/Project Support
ADS Environmental Services
6 Abraham Crescent, Palmerston North, New Zealand
Ph +64-6-3567213
Fax +64-6-3554386
This e-mail and attachments contains information that is
confidential and which may be subject to statutory restrictions on its
use. If you are not the intended recipient, you must not peruse, use, pass
on or copy this message or its attachments. If you have received this
message in error, please advise us by return e-mail, and delete the
message and attachments from your system.
Peter Jenkins
Ph +64-6-3567213
Fax +64-6-3554386
www.nollet.com.au for information.
I think it is a 4 x 4 pad and it is simply serial at 9600, easy to talk to
stamp.
rgds
Chris Anderson
To: <basicstamps@egroups.com>
Sent: Thursday, November 02, 2000 5:41 AM
Subject: [noparse][[/noparse]basicstamps] Serial keyboard interface
> Peter Jenkins
> Ph +64-6-3567213
> Fax +64-6-3554386
input from a keypad up to 4x4 and outputs the key code via serial link
(TTL). I've used these and work great. It gives you the flexibility to use
whatever keypad you want.
Cheers,
Mensaje original
> De: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YF3iduR9_eSguseXSdUXF0Y8vfE3gKzzqn979erjCCWDsitRtpsYGzhhuXE3O9mF_OC1JByr9zQz]fes@g...[/url
> Enviado el: jueves, 02 de noviembre de 2000 0:05
> Para: basicstamps@egroups.com
> Asunto: Re: [noparse][[/noparse]basicstamps] Serial keyboard interface
> There is a serial keypad being released at the moment, contact Ron at
> stamp.
> rgds
> Chris Anderson
> From: <peter.jenkins@a...>
> > Peter Jenkins
> > Ph +64-6-3567213
> > Fax +64-6-3554386
> peruse, use, pass
Rentron.com has an IC for a 10 key, (or less), common buss keypad.
elabinc.com has an IC for a 16 (or less) matrix keypad. Both talk serially
to a Stamp or microcontroller.
Ray McArthur
Sent: Wednesday, November 01, 2000 6:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] Serial keyboard interface
> stamp.
> rgds
> Chris Anderson
> > Peter Jenkins
keyboard, mouse, or keypad. By default the characters come in as normal
ASCII with some characters >$80 for special keys. You can also switch to
cooked mode and read a mouse, or the scan codes right off the keyboard.
Al Williams
AWC
> From: peter.jenkins@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7yXxdbmwtGqpJU3VyTeDObnKHdCOXaElLqX4az7SX-HdA2O70pLt7DDj2S8M5oueT3IpHFOsNPYmPMBDwk8gvWGD9w]peter.jenkins@a...[/url
> Sent: Wednesday, November 01, 2000 3:42 PM
> To: basicstamps@egroups.com
> Peter Jenkins
> Ph +64-6-3567213
> Fax +64-6-3554386
